IKEA Tradfri Gateway with other Zigbee devices
I understand that the IKEA Tradfri system uses a standards compliant Zigbee implementation. would it be technically possible to use the Tradfri gateway to control other Zigbee devices such as the Xiaomi Door/Window Sensor, Button and Temperature/Humidity sensors? If yes, is anyone working on implementing this?
Hello this is a pertinent question ! Any one may suppor ?
No, it’s not possible. Tradfri Gateway is locked down to only support ikea bulbs. So does Osram with Lightify (and Lightify bulbs).
The only Gateway supporting other brands is the Phillips Hue Bridge. I run Ikea and Lightify bulbs trough it.
I had a similar problem.
But I found a solution. Tradfri Gateway is not absolutely locked.
You can add other zigbee device to Ikea Tradfri Gateway, but then you need to add this device for example Google Home and use the device here. In app Ikea you cant manage device.
This article helps me => https://anandpr.medium.com/home-automation-ikea-trĂĄdfri-gateway-with-lidl-smart-plug-769336f40c19
Might help for someone
