ImperiHome binding 2.0
I’ve been reading the documentation and have not been able to get the kwh displayed properly other than with a generic device. How can I display it with the electric meter and link it to the watts?
The only way to show both values on the same widget is using a composite widget, either the Comp. sensor or Sensors sliding. For this to work it’s not required to link the items in openHAB.
If you still want to do that, this works for me:
Number  P_LVR_TV_Current          "TV huidig verbruik [%.1f W]"                           (Wattage)               ["iss:room:Living room", "iss:type:DevElectricity", "iss:link:kwh:P_LVR_TV_Usage"]    { channel="zwave:device:1:node4:sensor_power" }
Number  P_LVR_TV_Usage            "TV totaal verbruik [%.1f KWh]"                         (PowerUsage)            ["iss:room:Living room", "iss:type:DevElectricity", "iss:link:watt:P_LVR_TV_Current"] { channel="zwave:device:1:node4:meter_kwh" }
After updating for Openhab 2.3 Imperihab is not working anymore. I had to add it as a new “Object”, in the Imperihome software, guess that the system ID changed with the update, but the list of devices is empty. Anyone with the same problem?
thanks
Strange, haven’t seen that in my install. The system ID should remain the same and at the very least all your devices should remain intact. I suspect something else is off.
Can you check if the add-on endpoints are working as expected?
http://your-openhab.local/imperihome/iss/system
http://your-openhab.local/imperihome/iss/devices
Thanks for the quick response.
You where right to the point, endpoinis are not reachable on a browser, but the Imperihome software can find the system, just not the devices, bit odd. Only other problem I had updating was with “wifiled” add-on, so I´m using version 2.4 of it, and I had to reinstall the persistences, don´t know if it relates in any how.
I have noting wrong in the log with imperihab, and I tried to uninstall reboot and install it again but it did not worked. Any suggestions.
You changed to URL to use a local host/IP, right? :sweat_smile:
Did you install a version of the add-on manually in the past? Make sure there’s no jar file for Imperihome in the addons dir of openHAB.
You can check the status of the add-on using the Karaf console. Use SSH to open it (ssh openhab@localhost -p 8101) and find the bundle status:
list | grep -i imperihome
This should look something like this:
228 │ Active │ 80 │ 2.4.0.201805280907 │ ImperiHome Integration Service
If the status is not ‘active’ then you may have an installation problem.
Hi
I did changed the IP, but forgot to use the port, my bad! :sweat_smile:
So I got system “{“id”:“Openhab2.3”,“apiVersion”:1}” and devices “{“devices”:}” Endpoints working.
On Karaf I got this answer:
262 │ Active │ 80 │ 2.3.0 │ ImperiHome Integration Service
I guess it`s ok too.
I´m haven’t changed my .item file after update. But I had problems before with item tags, to be more specific I use tags for Imperihab and for Google Assistant, they look like this [“Lighting”, “iss:type:DevSwitch”, “iss:room:Terraço”], some version of the GA was not compatible with having wall the tags together, so for a week a had to chose using ether imperihab or GA.
You have the .jar for the 2.2 so I can text if the same problem is now on imperhab`s side?
The /devices response is empty, so that’s why Imperihome can’t find any devices. I suspect the changes to tags caused this.
Can you double-check the tags and syntax of your items files? No errors while loading them? You can trigger a reload by just re-saving a file.
If you set the log-level of org.openhab.io.imperihome to debug, you should see logging like this when saving an items file (probably with other stuff in between):
Found item <name> with ISS tags: [<bla>,<bla>]
Setting initial state of <name> to <state>
Item parsed to device: <device data>
If you don’t see this, or errors are logged, you might get a clue where to look.
OK,
I got no erros when starting the system, but as I save again my item file I have this warn for all itens with tags. As I stated before, I haven`t change my item file during or after update.
[WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:Squeezebox_PlayList in ManagedMetadataProviderImpl, because it does not exists
Thanks for all the help.
I’m having same problem after upgrade to 2.3 release.
Devices are empty:
{“devices”:}
System response is:
{“id”:“openhab”,“apiVersion”:1}
Tags working with Alexa and Google home and all tags are working…
I see same errors when saving item file:
[WARN ] [thome.core.common.registry.AbstractManagedProvider] - Could not update element with key _tags:livingroomLight in ManagedMetadataProviderImpl, because it does not exists.
[DEBUG] [hab.io.imperihome.internal.processor.ItemProcessor] - Processing item updated event
and when opening imperiHome:
[DEBUG] [penhab.io.imperihome.internal.ImperiHomeApiServlet] - 0:0:0:0:0:0:0:1: GET /imperihome/iss/devices
[DEBUG] [.io.imperihome.internal.handler.DevicesListHandler] - Device list response: DeviceList{devices=}
[DEBUG] [penhab.io.imperihome.internal.ImperiHomeApiServlet] - 127.0.0.1: GET /imperihome/iss/devices
I have opened an issue: https://github.com/openhab/openhab2-addons/issues/3656
@pdegeus, @Ahiel
After trying everything I know, analyzing every log and double checking all my files, I decided to start from scratch, doing things step by step on a new system. I was able to copy my files and install only the Impeihab add-on, after that I got a populated “devices” list, I thought the problem was solved, but after system restart the list was empty again. So I took my old system back and tried to uninstall Imperihab, reboot and install it again, and now I have Imperihab back working, but only until next reboot. Any suggestions? could we schedule a Imperihab service restart after Openhab reboot?
Sorry for being silent for a while, I’ve been busy at home (it’s a boy! :smiley:).
Unfortunately I don’t have the problem on my installation, so it’s a bit hard to find the issue. I’m running the latest snapshot version.
Can anyone post a full debug level log from the start of openhab to requesting the devices list from the add-on when the issue occurs? I may be able to spot the issue that way.
Congratulations!!
Can you try it on 2.3 release (maybe there is a fix in the snapshot)?
Congratulations!!
I don´t know how to get that full debug, but I see nothing on the logs, other than Imperihab is loading before most of Openhab services. Now I see that only installing and uninstalling the add-on does the trick, for now my workaround is to do that after every reboot.
I really need that log :slight_smile:
Check out Logging | openHAB.
Set the loglevel using log:set DEBUG org.openhab.io.imperihome, shutdown openHAB, clear the log files and start it again. After starting up and requesting the devices list post all the created logs.
Ok, I tried, see if you need more:
17:14:27.585 [INFO ] [t.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
17:14:28.897 [DEBUG] [org.openhab.io.imperihome ] - BundleEvent [unknown:512] - org.openhab.io.imperihome
17:14:30.353 [INFO ] [e.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘A’.
17:14:30.362 [INFO ] [e.core.internal.i18n.I18nProviderImpl] - Location set to ‘’.
17:14:30.369 [INFO ] [e.core.internal.i18n.I18nProviderImpl] - Locale set to ‘’.
17:14:32.389 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.25.30:8080
17:14:32.394 [INFO ] [i.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.25.30:8443
17:14:32.939 [DEBUG] [org.openhab.io.imperihome ] - ServiceEvent REGISTERED - {javax.servlet.http.HttpServlet}={service.id=220, service.bundleid=271, service.scope=bundle, service.config.category=io, system.id=Openhab2.3, service.pid=org.openhab.imperihome, service.config.label=ImperiHome Integration, component.name=org.openhab.imperihome, service.config.description.uri=io:imperihome, component.id=52} - org.openhab.io.imperihome
17:14:32.962 [DEBUG] [org.openhab.io.imperihome ] - BundleEvent STARTING - org.openhab.io.imperihome
17:14:32.976 [DEBUG] [org.openhab.io.imperihome ] - BundleEvent STARTED - org.openhab.io.imperihome
17:14:33.033 [INFO ] [.imperihome.internal.ImperiHomeConfig] - Configuration updated
17:14:33.092 [DEBUG] [home.internal.processor.ItemProcessor] - Processing allItemsChanged event
17:14:33.124 [DEBUG] [org.openhab.io.imperihome ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.version=2.3.0, osgi.web.contextpath=/, service.id=221, osgi.web.symbolicname=org.openhab.io.imperihome, service.bundleid=271, service.scope=singleton, osgi.web.contextname=default} - org.openhab.io.imperihome
17:14:33.174 [INFO ] [erihome.internal.ImperiHomeApiServlet] - Started ImperiHome integration service at /imperihome/iss
17:14:33.934 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 1430662c-6a95-428a-8b81-2730d487cf41, base URL = http://localhost:8080)
17:14:45.133 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘Andre.items’
17:14:45.358 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.383 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.399 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.409 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.418 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.429 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.440 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.450 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.464 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.474 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.483 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.493 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.502 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.511 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.520 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.529 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.545 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.554 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.562 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.571 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.579 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.587 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.597 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.605 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.614 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.623 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.631 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.639 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.647 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.656 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.665 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.674 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.682 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.691 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.700 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.709 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.719 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.783 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.792 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.801 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.809 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.818 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.826 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.835 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.843 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.852 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.861 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.869 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.878 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.887 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.895 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.905 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.913 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.922 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.931 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.939 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.948 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.956 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.966 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.974 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.983 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.991 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:45.998 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.007 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.015 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.024 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.033 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.041 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.049 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.057 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.065 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.073 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.081 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.088 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.097 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.104 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.112 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.120 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.128 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.135 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.143 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.151 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.160 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.168 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.181 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.190 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.199 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.208 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.217 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.226 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.240 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.249 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.258 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.267 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.277 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.286 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.296 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.305 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.315 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.324 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.333 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.342 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.350 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.359 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.369 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.377 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.386 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.394 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.403 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.411 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.419 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.428 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.437 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.445 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.453 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.462 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.471 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.479 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.488 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.496 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.505 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.513 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.521 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.529 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.537 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.545 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.553 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.561 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.569 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.577 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.585 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.596 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.605 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.614 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.622 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.631 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.640 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.649 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.658 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.667 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.676 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.685 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.693 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.703 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.718 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.727 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.737 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.746 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.754 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.763 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.770 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.778 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.786 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.795 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.803 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.811 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.819 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.828 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.836 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.845 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.852 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.860 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.868 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.876 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.939 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.948 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.957 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.964 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.972 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.979 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.986 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:46.994 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.001 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.007 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.015 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.022 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.029 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.035 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.042 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.049 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.056 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.062 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.069 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.075 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.083 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.090 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.097 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.104 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.113 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.121 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:47.358 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘teste.items’
17:14:47.372 [DEBUG] [home.internal.processor.ItemProcessor] - Processing item added event
17:14:48.826 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
17:14:48.892 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘mapdb.persist’
17:14:51.768 [INFO ] [rthome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
17:15:00.012 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model ‘s’
17:15:02.655 [DEBUG] [erihome.internal.ImperiHomeApiServlet] - 192.168.25.15: GET /imperihome/iss/devices
17:15:02.667 [DEBUG] [e.internal.handler.DevicesListHandler] - Device list response: DeviceList{devices=}
Thanks! That helps. My add-on the getting the tags for each item from openHAB and according to this log, no tags starting with ‘iss:’ are found.
This is either a bug in openHAB or an issue with your items. Do you edit your items using the web interface or keep them in one or more .items files? If the latter, can you post a few examples of your items?
Regardless of how you edit, can you post (part of) the output of http://[your-openHAB]/rest/items?recursive=false, containing some of the items containing ISS tags?
@pdegeus
Just updated to latest 2.4 snapshot #1302 (coming fra an old 2.3 snapshot release #1260), the binding loads fine but it doesn’t output any items to imperihome
Item:
Number   TM_Fe_Stue_Vegg    "Temperatur [%.2f C]"  (Netatmo,gGraphSql,gPersistMysqlTimed,gTemperatureInside) [ "iss:type:DevTemperature" ]  { netatmo="weather=xx#Temperature", expire="3h" }
Number   TM_Kj_Utside_Vegg  "Temperatur [%.2f °C]"  (Netatmo,gGraphSql,gPersistMysqlTimed,TempSensorOutside) ["iss:type:DevTempHygro", "iss:link:hygro:FM_Kj_Utside_Vegg"] { netatmo="weather=xx#Temperature", expire="3h"  }
Number   FM_Kj_Utside_Vegg   "Fuktighet [%.2f %%]"  (Netatmo,gGraphSql,gPersistMysqlTimed,gHumidityInside) ["iss:type:DevHygrometry"] {netatmo="weather=xx#Humidity"}
Debug (after saving the items file):
2018-06-23 13:34:09.147 [DEBUG] [rihome.internal.ImperiHomeApiServlet] - 192.168.1.103: GET /imperihome/iss/devices
2018-06-23 13:34:09.151 [DEBUG] [.internal.handler.DevicesListHandler] - Device list response: DeviceList{devices=[]}
2018-06-23 13:34:10.593 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'weather.items'
2018-06-23 13:34:10.614 [DEBUG] [ome.internal.processor.ItemProcessor] - Processing item updated event
2018-06-23 13:34:10.626 [DEBUG] [ome.internal.processor.ItemProcessor] - Processing item updated event
2018-06-23 13:34:10.652 [DEBUG] [ome.internal.processor.ItemProcessor] - Processing item updated event
2018-06-23 13:34:10.956 [DEBUG] [rihome.internal.ImperiHomeApiServlet] - 192.168.1.103: GET /imperihome/iss/devices
2018-06-23 13:34:10.959 [DEBUG] [.internal.handler.DevicesListHandler] - Device list response: DeviceList{devices=[]}
Anyone else using this binding successfully on snapshot (2.4)?
