since I have changes (with a new installation on Rpi4) to OH3 I have problems with Influx as well as Mosquitto.
2021-10-08 16:25:16.252 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.178.113'. Next attempt in 60000ms
2021-10-08 16:25:16.255 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.178.113' with clientid 3de734c1-1034-43e6-a981-f9db8d39d852
2021-10-08 16:24:23.065 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'mqtt:broker:Mqtt_Home' updated: OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED.
2021-10-08 16:24:23.067 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'mqtt:topic:Basic1_thg' updated: OFFLINE (BRIDGE_OFFLINE)
2021-10-08 16:24:23.068 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'mqtt:topic:Basic2_thg' updated: OFFLINE (BRIDGE_OFFLINE)
2021-10-08 16:24:23.069 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'mqtt:topic:BasicR3_thg' updated: OFFLINE (BRIDGE_OFFLINE)
2021-10-08 16:24:23.071 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'mqtt:topic:TH_thg' updated: OFFLINE (BRIDGE_OFFLINE)
Mosquito:
MQTT Things will not go online and by typing
openhabian@openhabian:~ $ mosquitto
I got following message:
1633703369: mosquitto version 1.5.7 starting
1633703369: Using default config.
1633703369: Opening ipv4 listen socket on port 1883.
1633703369: Error: Address already in use
When I stop the Mosquitto service:
root@openhabian:/# systemctl stop mosquitto.service
and type in:
Mosquitto starts :
1633703527: mosquitto version 1.5.7 starting
1633703527: Using default config.
1633703527: Opening ipv4 listen socket on port 1883.
1633703527: Opening ipv6 listen socket on port 1883.
1633703529: New connection from …
And the MQTT Things are online .
But this is not permanent running. After I reboot OH I have to repeat the procedure above.
Influx DB:
The behavior is similar but more complex. After starting OH Influx is not working.
2021-10-08 16:20:08.522 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': java.net.ConnectException: Failed to connect to /192.168.178.113:8086
2021-10-08 16:21:00.181 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
When I type:
root@openhabian:/# influx
I got this Message:
Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
Please check your connection settings and ensure 'influxd' is running.
And with:
root@openhabian:/# influxd
I got this Message:
8888888 .d888 888 8888888b. 888888b.
888 d88P" 888 888 "Y88b 888 "88b
888 888 888 888 888 888 .88P
888 88888b. 888888 888 888 888 888 888 888 888 8888888K.
888 888 "88b 888 888 888 888 Y8bd8P' 888 888 888 "Y88b
888 888 888 888 888 888 888 X88K 888 888 888 888
888 888 888 888 888 Y88b 888 .d8""8b. 888 .d88P 888 d88P
8888888 888 888 888 888 "Y88888 888 888 8888888P" 8888888P"
2021-10-08T14:36:19.520884Z info InfluxDB starting {"log_id": "0X45B0l0000", "version": "1.8.9", "branch": "1.8", "commit": "d9b56321d579"}
2021-10-08T14:36:19.520968Z info Go runtime {"log_id": "0X45B0l0000", "version": "go1.13.8", "maxprocs": 4}
run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
With the following process I get Influx running:
root@openhabian:/# sudo systemctl stop influxdb
2021-10-08T14:37:49.771197Z info InfluxDB starting {"log_id": "0X45GXIl000", "version": "1.8.9", "branch": "1.8", "commit": "d9b56321d579"}
2021-10-08T14:37:49.771269Z info Go runtime {"log_id": "0X45GXIl000", "version": "go1.13.8", "maxprocs": 4}
2021-10-08T14:37:49.874680Z info Using data dir {"log_id": "0X45GXIl000", "service": "store", "path": "/var/lib/influxdb/data"}
2021-10-08T14:37:49.874942Z info Compaction settings {"log_id": "0X45GXIl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
2021-10-08T14:37:49.875125Z info Open store (start) {"log_id": "0X45GXIl000", "service": "store", "trace_id": "0X45GXhl000", "op_name": "tsdb_open", "op_event": "start"}
2021-10-08T14:37:49.893451Z info Opened file {"log_id": "0X45GXIl000", "engine": "tsm1", "service": "filestore", "path": "/var/lib/influxdb/data/_internal/monitor/29/000000002-000000002.tsm", "id": 0, "duration": "0.987ms"}
But when I stop this “Influxd” with “contr. + C” than also Influx DB stops.
Further marks:
When Influx DB is running I am sometimes not able to go in to Influx:
Another worst thing is: with the above-mentioned process Influx DB was 10 days running. I was able to see all data in Grafana. After reboot of the Rasp. all data were lost.
Here I found also good Information (but w/o success):
root@openhabian:/# influxdb.service
bash: influxdb.service: command not found
root@openhabian:/# systemctl list-units | grep influxdb
opt-zram-influxdb.bind.mount loaded active mounted /opt/zram/influxdb.bind
var-lib-influxdb.mount loaded active mounted /var/lib/influxdb
Additionally, I had the problem that frotail hangs up. Here I just solve it with a reboot. But this is may be another problem!?
Hope some of you can help me…
