InfluxDB docker running with one simple forwarded port 8086->8086
I guess this is probably more a Docker/Synology/… issue, but all my research was unfortunately unsuccessful. Perhaps someone here has come across the same problem.
Thank you @Wolfgang_S for your suggestion. I had to modify the command as the influx process is hidden behind docker-proxy. I did this from the host system.
As you can see the only port the influx docker listens to is 8086.
Hello Tobias,
is the MDT interface a router or a simple gateway?
A KNX/IP gateway allows only one connection.
I am using knxd in a docker environment to enhance my Hager KNX IP Gateway with routing function.
Apart from that I have a similar setup as you: MariaDB server and openhab run in a docker container.
The reason why I mention this: Could it be that something else is accessing the MDT Interface which you don’t expect?
I had such phenomena when running the Group monitor in ETS and knxd solved this.
Regards
Marco
Thank you @marco_hoefle for the idea. The MDT IP interface is in fact a simple gateway. But the influxdb does not interact with it at all.
But I’ll see if using an external knxd instance could be a workaround for the issue.
I hope I can find some time to test this out - such experiments do not fit very well into the typical “after work, after kids/family, one hour spare time before bed”-evenings.
I know, that’s why I get up early on Sunday mornings
I attached my Docker Build and Run files, just rename the file to knxd.tar.gz
in knx.ini use the IP address of your gateway,
