InfluxDB2: Data storage
Hi everyone,
after searching without finding any result I decide to write down my solution for storing fetched data into the InfluxDB2 database using InfluxDB line protocol and OpenHAB’s HTTP actions.
For doing so, I add a simple rule for each data point I wanted to store in InfluxDB.
InfluxDb.rules
rule "Set Temperature - Thermal collectors"
    Item Collector_Temp changed  or
    Time cron "0 0 * * * ?" //everyHour
    //Server URL
    val url = "http://<InfluxDbServerIp>:8086/api/v2/write?org=YouOrganization&bucket=YourBucket&precision=s"
    //Timestamp
    val timestamp = Collector_Time.state
    //alternatively using the system time
    //val timestamp = now.toInstant.getEpochSecond()
    //Data
    //Using InfluxDB line protocol (https://docs.influxdata.com/influxdb/cloud/reference/syntax/line-protocol/)/line_protocol_tutorial/
    val data = "Collector_Temp,Sensor=Collector temperatur=" + (Collector_Temp.state as Number).toString.replace(' °C','') + " " + timestamp
    //Header information
    val headers = newHashMap("Authorization" -> "Token <YoutAuthenticationToken>")
    //Send HTTP post Request
    sendHttpPostRequest(url, "text/plain", data, headers, 5000)
In the above snipped I changed the following user specified values:
  • <InfluxDbServerIp>
  • YouOrganization
  • YourBucket
  • <YoutAuthenticationToken>
I would prefer a more convenient way for storing my data, unfortunately, I did not build a whole understanding of persistence in Openhab till now.
Maybe one will have a hint or o better solution for doing this. If so, I am glad to hear about it.
Best regards
Stephan
Collector_Temp.persist("influxdb")
thank you for the quick hint!
Now I recognized, that I should have also change the InfluxDB config file (services/influxdb.cfg), as the documentation denotes:
InfluxDB (0.9 and newer) Persistence - Configuration. This file changed kind of massively regarding to V1.8.
With doing so I can still use the Persistence Configuration file as got used to doing with Influx DB V1.8. It’s like magic!
Best regards
Stephan
