Innogy SmartHome - "Unexcepted API error: Remote access not allowed"
Hi there,
I installed @oliver_kuhl 's Innogy SmartHome beta1.
Thanks for this great work! :vulcan_salute:
Everythings works like a charm, but now I’m getting following error messages:
innogy.log
2017-10-27 10:30:54.472 [INFO ] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2017-10-27 10:30:54.476 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
2017-10-27 10:31:17.714 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.io.transport.mdns.discovery.MDNSDiscoveryParticipant}={component.name=org.eclipse.smarthome.binding.innogysmarthome.discovery.bridge, component.id=189, service.id=314, service.bundleid=212, service.scope=bundle} - org.openhab.binding.innogysmarthome
2017-10-27 10:31:17.830 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME04'
2017-10-27 10:31:17.831 [INFO ] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2017-10-27 10:31:17.861 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=319, service.bundleid=212, service.scope=singleton} - org.openhab.binding.innogysmarthome
2017-10-27 10:31:17.878 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.innogysmarthome, component.id=190, service.id=316, service.bundleid=212, service.scope=bundle} - org.openhab.binding.innogysmarthome
2017-10-27 10:31:17.895 [DEBUG] [org.openhab.binding.innogysmarthome ] - BundleEvent STOPPING - org.openhab.binding.innogysmarthome
2017-10-27 10:31:17.902 [DEBUG] [org.openhab.binding.innogysmarthome ] - BundleEvent STOPPED - org.openhab.binding.innogysmarthome
2017-10-27 10:32:32.621 [DEBUG] [org.openhab.binding.innogysmarthome ] - BundleEvent STARTING - org.openhab.binding.innogysmarthome
2017-10-27 10:32:32.653 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.io.transport.mdns.discovery.MDNSDiscoveryParticipant}={component.name=org.eclipse.smarthome.binding.innogysmarthome.discovery.bridge, component.id=189, service.id=314, service.bundleid=212, service.scope=bundle} - org.openhab.binding.innogysmarthome
2017-10-27 10:32:32.816 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.innogysmarthome, component.id=190, service.id=316, service.bundleid=212, service.scope=bundle} - org.openhab.binding.innogysmarthome
2017-10-27 10:32:32.833 [DEBUG] [org.openhab.binding.innogysmarthome ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=317, service.bundleid=212, service.scope=singleton} - org.openhab.binding.innogysmarthome
2017-10-27 10:32:32.859 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome BridgeHandler...
2017-10-27 10:32:32.897 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Config [clientId=24635748, clientSecret=no secret, authCode=null, accessToken=[mySecretToken :) ], refreshToken=[mySecretToken :) ]
2017-10-27 10:32:33.040 [DEBUG] [ery.InnogyBridgeDiscoveryParticipant] - Found innogy bridge via mDNS:SMARTHOME04 v4:[] v6:[]
2017-10-27 10:32:33.072 [DEBUG] [ery.InnogyBridgeDiscoveryParticipant] - Found innogy bridge via mDNS:SMARTHOME04 v4:[/192.168.178.4] v6:[/2003:df:53ca:7900:59e:769e:2ae5:b402, /2003:df:53ca:7900:21a:22ff:fe00:f6ed, /fe80:0:0:0:21a:22ff:fe00:f6ed]
2017-10-27 10:32:33.146 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2017-10-27 10:32:33.600 [ERROR] [marthome.handler.InnogyBridgeHandler] - Unexcepted API error: Remote access not allowed. Access is allowed only from the SHC device network.
2017-10-27 10:32:33.610 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME04'
2017-10-27 10:32:33.654 [INFO ] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2017-10-27 10:32:33.656 [INFO ] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2017-10-27 10:32:33.659 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
I configured my binding correctly, according to yesterday when everything worked fine :innocent:
Both, openhab server and the SHC, are in the same network, but openhab via WLAN and the HSC via LAN.
Might this be the hole problem? :thinking:
This is not a binding issue. Some people reported it depends on IP address change, iirc. And somehow the innogy hotline can help. It could depend on the remote access service. I never had this error personally…
Thanks Olli!
I contacted innogy support and got the following answer, unfortunately in German:
Innogy support answer
Da Sie von Nutzung der API sprechen gehen wir davon aus, dass Sie u. U. diefalsche Anmeldeseite nutzen.
Der Einstieg über den Browser läuft über die Seite:
https://innogy-smarthome.de
und nicht über die api.services/….
I haven’t really solved the problem, but I restart the SHC every morning now… :confused:
Do I need to activate the (chargeable) innogy mobile access? :thinking:
I think they misunderstood and the answer does not help. It seems like the subscription service could have something todo with it. However, I do not have it activated as far as I know but I never get this error.
You can PM me yout innogy username, the last date/timestamp when you got the error message and I can ask the developer team about it.
Regards
Nice, thanks!
I’ve got the same problem now too. From one day to the other
"Remote access not allowed. Access is allowed only from the SHC device network."
I have ordered the mobile-subscription after it was deactivated, but that didn’t help either…
Any news on this, @oliver_kuhl ?
The innogy support can’t help.
I just payed for mobile access… :roll_eyes:
“solved” the problem and everything is working fine.
I payed for it 36 hours ago, access via browser / handyapp from external networks is working, but the innogy-binding isn’t :frowning:
I got the hint from the innogy developers that the IP address is stored in the access token. I’ll try to implement an automatic token refresh when the “Remote access not allowed” error occurs.
I changed the binding to refresh the tokens now. As I do not have the problem, I cannot test it. So please try it:
http://www.ollie.in/wp-content/uploads/2018/02/org.openhab.binding.innogysmarthome-2.3.0-SNAPSHOT-180209.jar
Thanks!
I have since today the same problem. I installed (at least I tried) the Version 2.3.0 you provided with the link above.
When starting openhab the following error is logged:
2018-03-02 18:52:53.046 [ERROR] [org.openhab.binding.innogysmarthome ] - [binding.innogysmarthome] Cannot register Component
org.osgi.service.component.ComponentException: The component name 'binding.innogysmarthome' has already been registered by Bundle 230 (org.openhab.binding.innogysmarthome) as Component of Class org.openhab.binding.innogysmarthome.internal.InnogyHandlerFactory
	at org.apache.felix.scr.impl.ComponentRegistry.checkComponentName(ComponentRegistry.java:222) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.loadDescriptor(BundleComponentActivator.java:448) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialize(BundleComponentActivator.java:315) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:268) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:388) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1253) [8:org.apache.felix.fileinstall:3.5.8]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1225) [8:org.apache.felix.fileinstall:3.5.8]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:512) [8:org.apache.felix.fileinstall:3.5.8]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:361) [8:org.apache.felix.fileinstall:3.5.8]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:312) [8:org.apache.felix.fileinstall:3.5.8]
A view lines later, there is still the error:
2018-03-02 18:52:54.245 [hingStatusInfoChangedEvent] - 'innogysmarthome:bridge:SMARTHOME05' changed from INITIALIZING to OFFLINE (COMMUNICATION_ERROR): Remote access not allowed. Access is allowed only from the SHC device network.
Looking at the karaf console, their is only one bundle listed
openhab> bundle:list|grep -i innogy
230 │ Active   │  80 │ 2.3.0.201802091047     │ innogy SmartHome Binding
Any ideas what to do?
Jens
Mache Probleme lösen sich von selbst :wink:
The Problem is gone. I didn‘t do anything.
So I guess the problem was on the innogy side.
Thx
Jens
I had the same problem here as well and it simply disappeared after some undefined time. I have no clue.
Can anyone say if the “remote access not allowed” error is gone now?
This error is also gone. But not with the update I installed on Friday. As I wrote, it just disappeared today. So I am not sure if the problem with my installations was even triggerd by the same reason as the problem of the initial thread owner.
Ah okay. Please have an eye on this. If I did it correctly, the binding should now restart and load a new access-token, which then should work and allow the remote access.
This problem still exists for me. Sometimes it works, but when my IP changes it stops working. Sometimes it starts working again after a couple of hours. In this example it tried from 5 am to connect but it didn’t suceed until 1:30 pm
2018-03-06 05:04:27.221 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client…
2018-03-06 05:04:27.268 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
SmartHome client. 2018-03-06 13:33:59.446 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client... 2018-03-06 13:34:00.563 [INFO ] [marthome.handler.InnogyBridgeHandler] - Starting innogy websocket. 2018-03-06 13:34:00.788 [INFO ] [gysmarthome.internal.InnogyWebSocket] - Connected to innogy WebSocket. 2018-03-06 13:34:05.337 [INFO ] [ernal.manager.DeviceStructureManager] - Devices loaded. Device structure manager ready.
Can you please enable debug logging for some more details and send me the logs again, when the error occurs? Thx!
Although I’ve added this line to my logging cfg “log4j.logger.org.openhab.binding.innogysmarthome = DEBUG” I don’t get any more than these lines:
2018-03-09 17:15:32.809 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-09 17:15:33.166 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-09 17:15:33.220 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
2018-03-09 17:15:33.420 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
Any ideas?
Which OH version do you use? Since 2.2 the syntax changed:
log4j2.logger.org_openhab_binding_innogysmarthome.level = DEBUG
log4j2.logger.org_openhab_binding_innogysmarthome.name = org.openhab.binding.innogysmarthome
Thanks a lot. That’s the output:
2018-03-11 15:34:08.042 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome BridgeHandler...
2018-03-11 15:34:08.042 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy config: Config [clientId=24635748, clientSecret=no secret, redirectUrl=https://www.ollie.in/innogy-smarthome-token/, authCode=, accessToken=eyJ0eXAiOi...-__V-gQmHw, refreshToken=47b18...d9bda]
2018-03-11 15:34:08.042 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-11 15:34:08.042 [DEBUG] [arthome.internal.client.InnogyClient] - Initializing innogy SmartHome Session...
2018-03-11 15:34:08.374 [DEBUG] [arthome.internal.client.InnogyClient] - [1] Statuscode is NOT OK: 403
2018-03-11 15:34:08.374 [DEBUG] [arthome.internal.client.InnogyClient] - Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Remote access not allowed. Dropping access token and reinitializing binding...
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 0 seconds.
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Unexcepted API error: Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome BridgeHandler...
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME10'
2018-03-11 15:34:08.374 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy config: Config [clientId=24635748, clientSecret=no secret, redirectUrl=https://www.ollie.in/innogy-smarthome-token/, authCode=, accessToken=eyJ0eXAiOi...-__V-gQmHw, refreshToken=47b18...d9bda]
2018-03-11 15:34:08.374 [DEBUG] [arthome.internal.client.InnogyClient] - Uninitializing innogy SmartHome Session...
2018-03-11 15:34:08.374 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-11 15:34:08.374 [DEBUG] [arthome.internal.client.InnogyClient] - Initializing innogy SmartHome Session...
2018-03-11 15:34:08.411 [DEBUG] [arthome.internal.client.InnogyClient] - [2] Statuscode is NOT OK: 404
2018-03-11 15:34:08.411 [DEBUG] [arthome.internal.client.InnogyClient] - Session not found: ErrorResponse [code=2012, description=Session not found, messages=[Session not found: e76ce0b5232b46bb8bd004c78babf7dc]]
2018-03-11 15:34:08.411 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2018-03-11 15:34:08.411 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2018-03-11 15:34:08.411 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
2018-03-11 15:34:08.543 [DEBUG] [arthome.internal.client.InnogyClient] - [1] Statuscode is NOT OK: 403
2018-03-11 15:34:08.543 [DEBUG] [arthome.internal.client.InnogyClient] - Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Remote access not allowed. Dropping access token and reinitializing binding...
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 0 seconds - ignored: already triggered in 119 seconds.
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Unexcepted API error: Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME10'
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2018-03-11 15:34:08.558 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2018-03-11 15:34:08.558 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
2018-03-11 15:36:08.565 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome BridgeHandler...
2018-03-11 15:36:08.566 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy config: Config [clientId=24635748, clientSecret=no secret, redirectUrl=https://www.ollie.in/innogy-smarthome-token/, authCode=, accessToken=eyJ0eXAiOi...-__V-gQmHw, refreshToken=47b18...d9bda]
2018-03-11 15:36:08.567 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-11 15:36:08.567 [DEBUG] [arthome.internal.client.InnogyClient] - Initializing innogy SmartHome Session...
2018-03-11 15:36:08.818 [DEBUG] [arthome.internal.client.InnogyClient] - [1] Statuscode is NOT OK: 403
2018-03-11 15:36:08.818 [DEBUG] [arthome.internal.client.InnogyClient] - Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Remote access not allowed. Dropping access token and reinitializing binding...
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 0 seconds.
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Unexcepted API error: Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome BridgeHandler...
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy config: Config [clientId=24635748, clientSecret=no secret, redirectUrl=https://www.ollie.in/innogy-smarthome-token/, authCode=, accessToken=eyJ0eXAiOi...-__V-gQmHw, refreshToken=47b18...d9bda]
2018-03-11 15:36:08.818 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME10'
2018-03-11 15:36:08.818 [DEBUG] [arthome.internal.client.InnogyClient] - Uninitializing innogy SmartHome Session...
2018-03-11 15:36:08.818 [INFO ] [marthome.handler.InnogyBridgeHandler] - Initializing innogy SmartHome client...
2018-03-11 15:36:08.818 [DEBUG] [arthome.internal.client.InnogyClient] - Initializing innogy SmartHome Session...
2018-03-11 15:36:08.872 [DEBUG] [arthome.internal.client.InnogyClient] - [2] Statuscode is NOT OK: 404
2018-03-11 15:36:08.872 [DEBUG] [arthome.internal.client.InnogyClient] - Session not found: ErrorResponse [code=2012, description=Session not found, messages=[Session not found: e76ce0b5232b46bb8bd004c78babf7dc]]
2018-03-11 15:36:08.872 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2018-03-11 15:36:08.872 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2018-03-11 15:36:08.872 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
2018-03-11 15:36:09.088 [DEBUG] [arthome.internal.client.InnogyClient] - [1] Statuscode is NOT OK: 403
2018-03-11 15:36:09.104 [DEBUG] [arthome.internal.client.InnogyClient] - Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Remote access not allowed. Dropping access token and reinitializing binding...
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 0 seconds - ignored: already triggered in 119 seconds.
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Unexcepted API error: Remote access not allowed. Access is allowed only from the SHC device network.
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Disposing innogy SmartHome bridge handler 'SMARTHOME10'
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - innogy SmartHome bridge handler shut down.
2018-03-11 15:36:09.104 [DEBUG] [marthome.handler.InnogyBridgeHandler] - Scheduling reinitialize in 120 seconds.
2018-03-11 15:36:09.104 [ERROR] [marthome.handler.InnogyBridgeHandler] - Error initializing innogy SmartHome client.
