After my last restart, I am constantly seeing the error: “modem database download unsuccessful, restarting!”
I am running OH 2.5.5-1 (Release build). I am also using the new Insteon binding. This was a fresh install after the new Insteon binding was released (no insteon-plm binding on the system). This setup worked for the last month or so with no problems until yesterday when I restarted openhab2.
Hardware - RPI4
Insteon HUB (2245-222)
About 48 Insteon devices.
I read the other posts, which seem to be around the PLM and the PLM binding. I did try raising the Modem DB Retry Timeout up from the default to 180, then 300 and finally 600 seconds. None of that worked.
Do you have any suggestions on how to troubleshoot or resolve this problem?
After the problem started, I tried upgrading to the latest release (2.5.5-1). I ensured the OS patches were up to date. I even rebooted the RPI to ensure there was nothing holding things up on the device. No luck. Ideas?
The hub has a PLM inside of it, and the older ones contained capacitors that fail. It can be repaired using basic soldering skills. If you google for “Insteon hub repair” or “Insteon PLM repair”, you should find all sorts of info. I think Insteon might replace them as well, if you have the proper documentation: https://www.insteon.com/support-knowledgebase/2015/10/20/migrating-to-a-new-insteon-hub.
Hi Rob
First thanks for all the efforts that you and your friends put in making this add-on so successful.
I’m having the same issue, getting the same warning, however, I see partial list of devices and I’m also able to control them through OH, are you sure this error is caused by bad capacitors ?
I’ve also tried HA, In this case all of the devices are fetched up, but I couldn’t not control them.
My setup is pretty big, I have more than 128 devices, using the new Insteon app (Beta) I’m able to control all of them and very fast.
One thing that I’ve found is that the modem DB retry timeout has no effect, even though I increased it to the maximum, I can still see in the debug log that the fail occurs every 2 min:
2020-05-30 18:42:56.382 [WARN ] [steon.internal.device.ModemDBBuilder] - modem database download unsuccessful, restarting!
2020-05-30 18:42:56.384 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2020-05-30 18:44:56.389 [WARN ] [steon.internal.device.ModemDBBuilder] - modem database download unsuccessful, restarting!
Since I’ve invested so much in Insteon (as mentioned, hundreds of devices), I would like to know if replacing the hub with plm modem (which one? usb? serial?) will solve many of these issues ?
thanks again
Oz
Hi Oz,
The modem database download code has been refactored, and the modem DB retry logic has been removed. Can you try installing 2.5.6-SNAPSHOT and see how it works?
Rob
Thanks for prompt response !
I’ll give it a try and let you know
Oz.
Your welcome, let me know how it goes.
Seems like the problem is solved, I can see all of my devices listed in the inbox.
Thank you so much for the support
Now I just have to see how I can make the open/close 2444-222 modules to control my blinds and I can start automate my house
thanks !!
I’m back to trying to figure this out again. Why do I constantly get these messages:
2020-07-31 19:44:39.118 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting!
2020-07-31 19:47:01.323 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting!
I have upgraded to 2.5.7-1.
Have searched the community sites and tried changing my port configuration to: /hub2/{user}:{pw}@{addr}:{port},modemDbRetryTimeoutSeconds=300
in order to extend the database read timeout, but that hasn’t helped. I am hard pressed to believe my hub is failing since I can control things through the Insteon App and also through OpenHab. So what can I do to help resolve this?
Please turn on debug logging and share it with me. The code was refactored a couple of releases ago and read timeout parameter has been removed. It now errors out if it hasn’t received a message in 30 seconds. From what you’ve provided, it looks like you are still running a older binding.
After turning on debug and seeing that the debug created was way to large to post, I did some more digging. I started up Insteon Terminal and it also couldn’t get the database. Started analyzing my setup and network and found a couple of problems.
1 - I had a device that wouldn’t respond even to the Insteon App. I removed the device (thankfully it was a plugin module).
2 - Turns out I still had an Openhab lab setup plugged into my network, so I had an extra system requesting information. I shut it down.
After that, I restarted my main system and low and behold, my modem database download issue seems to have gone away.
This will definitely cause problems.
Hi all,
I am currently using OH2 on a Windows 10 platform using Insteon binding 2.5.12.
A few days ago, my old Insteon Hub 2242-222 broke down. I just bought a used Hub 2245-222 to replace it. I went on to relearn my Insteon devices using the Insteon phone app. This turned out to work fine: my devices do respond to commands sent through the Insteon app,
Unfortunately, there is a problem on the OH side. I am getting the following error message in the OH log:
022-01-07 17:00:32.065 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-07 17:00:46.784 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnecte
Does this mean that the used 2245-222 hub I just bought is bad and needs to be repaired or replaced?
Many thanks in advance for your help.
Pierre
Using both the Insteon app and the openHAB Insteon binding at the same time is not supported. See Known Limitations and Issues.
Thanks a lot for your assistance.
With my legacy hub, I could use the phone app without any problems.
Thus, I understand that I should now delete all the devices that were linked using my phone app and relink them in a different way. The binding doc mentions that Houselinc will wipe out the existing modem database upon its first use. Would that be a good way to go for the relinkink process?
Thanks again for your help.
I tried using Houselinc, but I was not able to get it to connect to my Hub. Upon starting, it fails to find the hub and when I try to use the “Let me configure manually my computer interface” it shows me a menu of devices that does not include my hub number (2245-222). If I then choose any of the available numbers (e.g. 2245-422) and provide my hub’s local address it fails to find it.
I suppose I could try the “Insteon Terminal” programs, but appaently I would have to install Ubuntu on my WQindows machine for that purpose.
Is there any other way to link my devices on the hub?
I don’t know of any other way to configure your devices other than using insteon terminal. You can install Windows Subsystem for Linux (WSL) and then you should be able to use insteon terminal.
I’m also suspecting you are running into this issue [insteon] add a read timeout when getting data from the Insteon 2245-222 hub by robnielsen · Pull Request #10708 · openhab/openhab-addons · GitHub that was fixed in 3.1, so the error is not very useful.
You could try turning on debug logging and then we can get more details on what is gong on. (see Logging | openHAB) Specifically the command you’d want to set is:
log:set DEBUG org.openhab.binding.insteon
Thanks for your input.
Here is a log with DEBUG activated. Note that I haven’t yet deleted the devices I had created using the phone app. I suppose I should do that now?
2022-01-09 09:56:06.612 [WARN ] [org.apache.karaf.shell.ssh.Activator] - Error starting activator
java.lang.IllegalStateException: Service not tracked for class interface org.osgi.service.cm.ConfigurationAdmin
at org.apache.karaf.util.tracker.BaseActivator.getTrackedService(BaseActivator.java:369) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.ensureStartupConfiguration(BaseActivator.java:154) ~[bundleFile:?]
at org.apache.karaf.shell.ssh.Activator.doStart(Activator.java:96) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:312) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:1.8.0_201]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_201]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_201]
2022-01-09 09:56:07.169 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Montreal'.
2022-01-09 09:56:07.171 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '45.8352722,-72.4041412'.
2022-01-09 09:56:09.866 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2022-01-09 09:56:10.172 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2022-01-09 09:56:10.243 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'paradox.things'
2022-01-09 09:56:10.249 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'smartthings.things'
2022-01-09 09:56:10.253 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zigbee.things'
2022-01-09 09:56:10.258 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'tesla.things' has errors, therefore ignoring it: [1,77]: Number expected.
2022-01-09 09:56:10.270 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.things'
2022-01-09 09:56:11.525 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rachio.rules'
2022-01-09 09:56:11.846 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'chauffage.rules'
2022-01-09 09:56:12.546 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2022-01-09 09:56:12.653 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-01-09 09:56:13.617 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): CreateProcess error=2, Le fichier spécifié est introuvable)
2022-01-09 09:56:13.686 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2022-01-09 09:56:13.927 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): CreateProcess error=2, Le fichier spécifié est introuvable)
2022-01-09 09:56:14.001 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2022-01-09 09:56:14.142 [DEBUG] [covery.InsteonDeviceDiscoveryService] - Initializing InsteonNetworkDiscoveryService
2022-01-09 09:56:14.147 [DEBUG] [ternal.handler.InsteonNetworkHandler] - Starting Insteon bridge
2022-01-09 09:56:14.149 [DEBUG] [ding.insteon.internal.InsteonBinding] - port = '/hub/192.168.2.230:25105'
2022-01-09 09:56:14.159 [DEBUG] [ding.insteon.internal.InsteonBinding] - device poll interval set to 120 seconds
2022-01-09 09:56:14.160 [DEBUG] [ding.insteon.internal.InsteonBinding] - dead device timeout set to 1200 seconds
2022-01-09 09:56:14.179 [DEBUG] [eon.internal.device.DeviceTypeLoader] - loaded 47 devices:
2022-01-09 09:56:14.179 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000041 ->pk:0x000041|model:2484DWH8|desc:KeypadLinc Countdown Timer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.180 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0A ->pk:F00.00.0A|model:2852-222|desc:Leak Sensor|features:contact=LeakSensorContact:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.180 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0D ->pk:F00.00.0D|model:2634-222|desc:On/Off Dual-Band Outdoor Module|features:beep=Beep:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups
2022-01-09 09:56:14.180 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000049 ->pk:0x000049|model:2843-222|desc:Wireless Open/Close Sensor|features:contact=GenericContact:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.180 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0C ->pk:F00.00.0C|model:2476D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.180 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0B ->pk:F00.00.0B|model:2672-422|desc:LED Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.181 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000068 ->pk:0x000068|model:2472D|desc:OutletLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:ramprate=RampRate:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff|groups:ext_group=ledbrightness,ramprate
2022-01-09 09:56:14.181 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000045 ->pk:0x000045|model:2413U|desc:PowerLinc 2413U USB modem|features:broadcastonoff=GroupBroadcastOnOff|groups
2022-01-09 09:56:14.181 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x00004A ->pk:0x00004A|model:2842-222|desc:Motion Sensor|features:lightlevelabovethreshold=WirelessMotionSensorLightLevelAboveThreshold:data=MotionSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime:lowbattery=WirelessMotionSensorLowBattery|groups
2022-01-09 09:56:14.181 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.01 ->pk:F00.00.01|model:2477D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:ramprate=RampRate:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff:onlevel=OnLevel|groups:ext_group=ledbrightness,ramprate,onlevel
2022-01-09 09:56:14.181 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.23 ->pk:F00.00.23|model:2487S|desc:KeypadLinc On/Off 8-Button Scene Control |features:manualchangebuttone=ManualChangeButton5:manualchangebuttond=ManualChangeButton4:manualchangebuttong=ManualChangeButton7:manualchangebuttonf=ManualChangeButton6:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:manualchangebuttonc=ManualChangeButton3:keypadbuttonc=KeyPadButton3:manualchangebuttonb=ManualChangeButton2:loadswitchmanualchange=LoadSwitchManualChange:loadswitchfastonoff=LoadSwitchFastOnOff:fastonoffbuttonb=FastOnOffButton2:fastonoffbuttonc=FastOnOffButton3:fastonoffbuttond=FastOnOffButton4:fastonoffbuttone=FastOnOffButton5:fastonoffbuttonf=FastOnOffButton6:fastonoffbuttong=FastOnOffButton7:fastonoffbuttonh=FastOnOffButton8:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchangebuttonh=ManualChangeButton8:loadswitch=LoadSwitchButton|groups:manualchange_button_group=manualchangebuttonb,manualchangebuttonc,manualchangebuttond,manualchangebuttone,manualchangebuttonf,manualchangebuttong,manualchangebuttonh:fastonoff_button_group=fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond,fastonoffbuttone,fastonoffbuttonf,fastonoffbuttong,fastonoffbuttonh:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.22 ->pk:F00.00.22|model:2982-222|desc:Insteon Smoke Bridge|features:notification=ReceiveBroadcast:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.21 ->pk:F00.00.21|model:2441V|desc:Insteon Thermostat Adaptor for Venstar|features:fanmode=VenstarFanMode:iscooling=VenstarIsCooling:heatsetpoint=VenstarHeatSetPoint:tempfahrenheit=VenstarTemperatureFahrenheit:coolsetpoint=VenstarCoolSetPoint:humidity=VenstarHumidity:lastheardfrom=GenericLastTime:systemmode=VenstarSystemMode:isheating=VenstarIsHeating|groups:data1b_group=coolsetpoint,heatsetpoint,systemmode,fanmode,tempfahrenheit,humidity,isheating,iscooling
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.20 ->pk:F00.00.20|model:2342-222|desc:Mini Remote (8 Button)|features:buttond=RemoteButton3:buttone=RemoteButton6:buttonb=RemoteButton1:buttonc=RemoteButton4:buttonh=RemoteButton7:buttonf=RemoteButton5:buttong=RemoteButton8:lastheardfrom=GenericLastTime:buttona=RemoteButton2|groups
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.05 ->pk:F00.00.05|model:2456D3|desc:LampLinc V2|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.04 ->pk:F00.00.04|model:2876S|desc:ICON Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.03 ->pk:F00.00.03|model:2845-222|desc:Hidden Door Sensor|features:data=HiddenDoorSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.182 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.02 ->pk:F00.00.02|model:2477S|desc:SwitchLinc Switch|features:fastonoff=FastOnOff:beep=Beep:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups:ext_group=ledbrightness
2022-01-09 09:56:14.183 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.24 ->pk:F00.00.24|model:2844-222|desc:Motion Sensor II|features:lightlevelabovethreshold=WirelessMotionSensorLightLevelAboveThreshold:data=MotionSensor2Data:tamperswitch=WirelessMotionSensor2TamperSwitch:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime:lowbattery=WirelessMotionSensorLowBattery|groups
2022-01-09 09:56:14.183 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.09 ->pk:F00.00.09|model:2458-A1|desc:MorningLinc RF Lock Controller|features:switch=GenericSwitch|groups
2022-01-09 09:56:14.183 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.08 ->pk:F00.00.08|model:2452-222|desc:DIN Rail Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.184 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.07 ->pk:F00.00.07|model:2453-222|desc:DIN Rail On/Off|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.184 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.06 ->pk:F00.00.06|model:2442-222|desc:Micro Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.184 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000051 ->pk:0x000051|model:2486DWH8|desc:KeypadLinc Dimmer - 8 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:keypadbuttonc=KeyPadButton3:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 09:56:14.184 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000050 ->pk:0x000050|model:2486DWH6|desc:KeypadLinc Dimmer - 6 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttona=KeyPadButton3:keypadbuttond=KeyPadButton6:keypadbuttonb=KeyPadButton4:keypadbuttonc=KeyPadButton5:lastheardfrom=GenericLastTime:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 09:56:14.184 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1B ->pk:F00.00.1B|model:2635-222|desc:On/Off Module|features:beep=Beep:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1A ->pk:F00.00.1A|model:2475SDB|desc:In-LineLinc Relay|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1F ->pk:F00.00.1F|model:2477SA1|desc:220V 30-amp Load Controller N/O|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000039 ->pk:0x000039|model:2663-222|desc:On/Off Outlet|features:bottomoutlet=BottomOutlet:lastheardfrom=GenericLastTime:topoutlet=GenericSwitch|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1E ->pk:F00.00.1E|model:2674-222|desc:LED Bulb (recessed)|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1D ->pk:F00.00.1D|model:2456S3|desc:ApplianceLinc|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.185 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000037 ->pk:0x000037|model:2486D|desc:KeypadLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 09:56:14.186 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1C ->pk:F00.00.1C|model:2475F|desc:FanLinc Module|features:fan=FanLincFan:lightdimmer=GenericDimmer:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.186 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.12 ->pk:F00.00.12|model:2466S|desc:ToggleLinc Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 09:56:14.197 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.11 ->pk:F00.00.11|model:2466D|desc:ToggleLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2022-01-09 09:56:14.197 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.10 ->pk:F00.00.10|model:2342-2|desc:Mini Remote|features:buttond=RemoteButton4:buttonb=RemoteButton2:buttonc=RemoteButton3:lastheardfrom=GenericLastTime:buttona=RemoteButton1|groups
2022-01-09 09:56:14.197 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.03 ->pk:X00.00.03|model:X10 motion sensor|desc:Generic X10 motion sensor|features:contact=X10Contact|groups
2022-01-09 09:56:14.197 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.16 ->pk:F00.00.16|model:2334-232|desc:Keypad Dimmer Switch, 8-Button |features:manualchangebuttone=ManualChangeButton5:beep=Beep:manualchangebuttond=ManualChangeButton4:manualchangebuttong=ManualChangeButton7:manualchangebuttonf=ManualChangeButton6:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:manualchangebuttonc=ManualChangeButton3:keypadbuttonc=KeyPadButton3:manualchangebuttonb=ManualChangeButton2:ledbrightness=LEDBrightness:ledonoff=LEDOnOff:fastonoff=LoadDimmerFastOnOff:ramprate=RampRate:fastonoffbuttonb=FastOnOffButton2:fastonoffbuttonc=FastOnOffButton3:fastonoffbuttond=FastOnOffButton4:fastonoffbuttone=FastOnOffButton5:manualchange=ManualChange:fastonoffbuttonf=FastOnOffButton6:fastonoffbuttong=FastOnOffButton7:fastonoffbuttonh=FastOnOffButton8:onlevel=OnLevel:loaddimmer=LoadDimmerButton:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchangebuttonh=ManualChangeButton8:rampdimmer=LoadDimmerRamp|groups:manualchange_button_group=manualchangebuttonb,manualchangebuttonc,manualchangebuttond,manualchangebuttone,manualchangebuttonf,manualchangebuttong,manualchangebuttonh:fastonoff_button_group=fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond,fastonoffbuttone,fastonoffbuttonf,fastonoffbuttong,fastonoffbuttonh:ext_group=ledbrightness,ramprate,onlevel:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.02 ->pk:X00.00.02|model:X10 dimmer|desc:Generic X10 Dimmer without preset|features:dimmer=X10Dimmer:switch=X10Switch|groups
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.15 ->pk:F00.00.15|model:2334-232|desc:Keypad Dimmer Switch, 6-Button |features:beep=Beep:keypadbuttona=KeyPadButton3:manualchangebuttond=ManualChangeButton6:keypadbuttond=KeyPadButton6:manualchangebuttona=ManualChangeButton3:keypadbuttonb=KeyPadButton4:manualchangebuttonc=ManualChangeButton5:keypadbuttonc=KeyPadButton5:manualchangebuttonb=ManualChangeButton4:ledbrightness=LEDBrightness:ledonoff=LEDOnOff:onlevel=OnLevel:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:ramprate=RampRate:fastonoffbuttonb=FastOnOffButton4:fastonoffbuttonc=FastOnOffButton5:lastheardfrom=GenericLastTime:fastonoffbuttond=FastOnOffButton6:manualchange=ManualChange:rampdimmer=LoadDimmerRamp:fastonoffbuttona=FastOnOffButton3|groups:manualchange_button_group=manualchangebuttona,manualchangebuttonb,manualchangebuttonc,manualchangebuttond:fastonoff_button_group=fastonoffbuttona,fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond:ext_group=ledbrightness,ramprate,onlevel:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.01 ->pk:X00.00.01|model:X10 switch|desc:any simple X10 switch|features:switch=X10Switch|groups
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.14 ->pk:F00.00.14|model:2487S|desc:KeypadLinc On/Off 6-Button Scene Control |features:keypadbuttona=KeyPadButton3:manualchangebuttond=ManualChangeButton6:keypadbuttond=KeyPadButton6:manualchangebuttona=ManualChangeButton3:keypadbuttonb=KeyPadButton4:manualchangebuttonc=ManualChangeButton5:keypadbuttonc=KeyPadButton5:manualchangebuttonb=ManualChangeButton4:loadswitchmanualchange=LoadSwitchManualChange:loadswitchfastonoff=LoadSwitchFastOnOff:fastonoffbuttonb=FastOnOffButton4:fastonoffbuttonc=FastOnOffButton5:lastheardfrom=GenericLastTime:fastonoffbuttond=FastOnOffButton6:loadswitch=LoadSwitchButton:fastonoffbuttona=FastOnOffButton3|groups:manualchange_button_group=manualchangebuttona,manualchangebuttonb,manualchangebuttonc,manualchangebuttond:fastonoff_button_group=fastonoffbuttona,fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.13 ->pk:F00.00.13|model:2672-222|desc:LED Bulb|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer_3435|groups
2022-01-09 09:56:14.198 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.19 ->pk:F00.00.19|model:2457D2|desc:LampLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff|groups
2022-01-09 09:56:14.199 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.18 ->pk:F00.00.18|model:2441TH|desc:Insteon Thermostat|features:humidityhigh=ThermostatHumidityHigh:stage1duration=ThermostatStage1Duration:humiditylow=ThermostatHumidityLow:systemmode=ThermostatSystemMode:isheating=ThermostatIsHeating:fanmode=ThermostatFanMode:iscooling=ThermostatIsCooling:heatsetpoint=ThermostatHeatSetPoint:coolsetpoint=ThermostatCoolSetPoint:temperature=ThermostatTemperatureFahrenheit:humidity=ThermostatHumidity:lastheardfrom=GenericLastTime:acdelay=ThermostatACDelay:backlightduration=ThermostatBackLightDuration|groups:data1b_group=humidityhigh,humiditylow,stage1duration:data2_group=coolsetpoint,heatsetpoint,systemmode,fanmode,isheating,iscooling,temperature,humidity:data1_group=backlightduration,acdelay
2022-01-09 09:56:14.199 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x00001A ->pk:0x00001A|model:2450|desc:IO Link|features:contact=IOLincContact:lastheardfrom=GenericLastTime:switch=IOLincSwitch|groups
2022-01-09 09:56:14.199 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.17 ->pk:F00.00.17|model:2423A1|desc:iMeter Solo Power Meter|features:meter=PowerMeter:lastheardfrom=GenericLastTime|groups
2022-01-09 09:56:14.247 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:236CF9 address = 23.6C.F9 productKey = F00.00.05 channels = fastOnOff, lastHeardFrom, dimmer, manualChange
2022-01-09 09:56:14.250 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 09:56:14.250 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 09:56:14.251 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 09:56:14.254 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347F5 address = 33.47.F5 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 09:56:14.257 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:D1 address = D.1 productKey = X00.00.01 channels = switch
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatHumidityHigh(0:1:2)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatHumidityLow(0:1:2)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatStage1Duration(0:1:2)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatCoolSetPoint(0:1:3)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 09:56:14.262 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatHeatSetPoint(0:1:3)
2022-01-09 09:56:14.263 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 09:56:14.263 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatSystemMode(0:1:3)
2022-01-09 09:56:14.263 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatFanMode(0:1:3)
2022-01-09 09:56:14.263 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatIsHeating(0:0:3)
2022-01-09 09:56:14.264 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatIsCooling(0:0:3)
2022-01-09 09:56:14.264 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatTemperatureFahrenheit(0:0:2)
2022-01-09 09:56:14.264 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatHumidity(0:0:2)
2022-01-09 09:56:14.266 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 09:56:14.266 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1_group connected feature: ThermostatBackLightDuration(0:1:2)
2022-01-09 09:56:14.268 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1_group connected feature: ThermostatACDelay(0:1:2)
2022-01-09 09:56:14.270 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347A5 address = 33.47.A5 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 09:56:14.278 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:2B8D15 address = 2B.8D.15 productKey = F00.00.0C channels = fastOnOff, lastHeardFrom, dimmer, manualChange
2022-01-09 09:56:14.280 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:394B3E address = 39.4B.3E productKey = F00.00.02 channels = beep, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, switch
2022-01-09 09:56:14.283 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 09:56:14.283 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 09:56:14.283 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 09:56:14.288 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555 address = 32.F5.55 productKey = F00.00.18 channels = isHeating, humidityLow, humidity, acDelay, lastHeardFrom, fanMode, stage1Duration, backlightDuration, systemMode, coolSetPoint, temperature, humidityHigh, isCooling, heatSetPoint
2022-01-09 09:56:14.290 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:C2c address = C.2 productKey = X00.00.01 channels = switch
2022-01-09 09:56:14.292 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 09:56:14.295 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:33FF3A address = 33.FF.3A productKey = F00.00.02 channels = beep, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, switch
2022-01-09 09:56:14.295 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:27D986 address = 27.D9.86 productKey = F00.00.1B channels = beep, lastHeardFrom, ledOnOff, switch
2022-01-09 09:56:14.300 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:259705 address = 25.97.05 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 09:56:14.979 [INFO ] [mekit.internal.HomekitChangeListener] - Created 19 HomeKit items.
2022-01-09 09:56:15.974 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2022-01-09 09:56:15.976 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:236CF9:dimmer
2022-01-09 09:56:15.977 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:236CF9:dimmer feature = dimmer parameters = {}
2022-01-09 09:56:15.977 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:3347F5:dimmer
2022-01-09 09:56:15.977 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347F5:dimmer feature = dimmer parameters = {}
2022-01-09 09:56:15.977 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:D1:switch
2022-01-09 09:56:15.977 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:D1:switch feature = switch parameters = {}
2022-01-09 09:56:15.978 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:3347A5:dimmer
2022-01-09 09:56:15.978 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347A5:dimmer feature = dimmer parameters = {}
2022-01-09 09:56:15.978 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:394B3E:switch
2022-01-09 09:56:15.978 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:394B3E:switch feature = switch parameters = {}
2022-01-09 09:56:15.978 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:2B8D15:dimmer
2022-01-09 09:56:15.978 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:2B8D15:dimmer feature = dimmer parameters = {}
2022-01-09 09:56:15.979 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:isHeating
2022-01-09 09:56:15.979 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:isHeating feature = isheating parameters = {}
2022-01-09 09:56:15.979 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:humidity
2022-01-09 09:56:15.979 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:humidity feature = humidity parameters = {}
2022-01-09 09:56:15.979 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:backlightDuration
2022-01-09 09:56:15.979 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:backlightDuration feature = backlightduration parameters = {}
2022-01-09 09:56:15.980 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:systemMode
2022-01-09 09:56:15.980 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:systemMode feature = systemmode parameters = {}
2022-01-09 09:56:15.980 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:temperature
2022-01-09 09:56:15.980 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:temperature feature = temperature parameters = {}
2022-01-09 09:56:15.980 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:heatSetPoint
2022-01-09 09:56:15.980 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:heatSetPoint feature = heatsetpoint parameters = {}
2022-01-09 09:56:15.980 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:C2c:switch
2022-01-09 09:56:15.981 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:C2c:switch feature = switch parameters = {}
2022-01-09 09:56:15.981 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:33FF3A:switch
2022-01-09 09:56:15.981 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:33FF3A:switch feature = switch parameters = {}
2022-01-09 09:56:15.981 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:27D986:switch
2022-01-09 09:56:15.981 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:27D986:switch feature = switch parameters = {}
2022-01-09 09:56:15.981 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:259705:dimmer
2022-01-09 09:56:15.981 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:259705:dimmer feature = dimmer parameters = {}
2022-01-09 09:56:16.073 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid 3ca66c98-4ea7-442e-b5df-bc55d4f3e81c
2022-01-09 09:56:16.082 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.2.3' with clientid d79e9697-44fb-4448-8f76-90d4ec145a42
2022-01-09 09:56:16.215 [INFO ] [nal.communication.CommunicationState] - Login - Login to IP150 - OK
2022-01-09 09:56:16.302 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.3:8080
2022-01-09 09:56:16.302 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.3:8443
2022-01-09 09:56:16.336 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2022-01-09 09:56:16.371 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2022-01-09 09:56:16.404 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2022-01-09 09:56:16.854 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 7424d7f9-d34e-4f60-a3d6-7fa17f64f06e, base URL = http://localhost:8080)
2022-01-09 09:56:17.513 [INFO ] [nal.communication.CommunicationState] - Successfully established communication with the panel.
2022-01-09 09:56:20.179 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 09:56:20.180 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 09:56:20.188 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 09:56:20.188 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 09:56:20.207 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 09:56:20.207 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 09:56:20.210 [DEBUG] [ding.insteon.internal.InsteonBinding] - devices: 11 configured, 0 polling, msgs received: 0
2022-01-09 09:56:20.210 [DEBUG] [nding.insteon.internal.driver.Poller] - starting poll thread.
2022-01-09 09:56:23.735 [INFO ] [doxalarm.internal.model.ParadoxPanel] - Paradox system is supported. Panel data retrieved=ParadoxInformation [panelType=EVO192, serialNumber=05086F2A, applicationVersion=Version: 7.1.4, hardwareVersion=Version: 0.10, bootloaderVersion=Version: 1.0.15]
2022-01-09 09:56:24.393 [DEBUG] [nternal.handler.InsteonDeviceHandler] - channel insteon:device:home:32F555:heatSetPoint was triggered with the command 18
2022-01-09 09:56:24.394 [DEBUG] [nsteon.internal.device.InsteonDevice] - processing command 18 features: 17
2022-01-09 09:56:24.398 [DEBUG] [steon.internal.device.CommandHandler] - NumberCommandHandler: sent msg to change level to 18
2022-01-09 09:56:24.400 [DEBUG] [ding.insteon.internal.InsteonBinding] - found binding config for channel insteon:device:home:32F555:heatSetPoint
2022-01-09 09:56:24.400 [DEBUG] [.internal.device.RequestQueueManager] - starting request queue thread
2022-01-09 09:56:24.401 [DEBUG] [nsteon.internal.device.InsteonDevice] - qe taken off direct: ThermostatHeatSetPoint(1:1:3) OUT:Cmd:0x62|toAddress:32.F5.55|messageFlags:0x1F=DIRECT:3:3|command1:0x6D|command2:0x24|userData1:0x00|userData2:0x00|userData3:0x00|userData4:0x00|userData5:0x00|userData6:0x00|userData7:0x00|userData8:0x00|userData9:0x00|userData10:0x00|userData11:0x00|userData12:0x00|userData13:0x00|userData14:0x6F|
2022-01-09 09:56:24.401 [DEBUG] [nsteon.internal.device.InsteonDevice] - next request queue processed in 2000 msec, quiettime = 2000
2022-01-09 09:56:26.407 [DEBUG] [.internal.device.RequestQueueManager] - device queue for 32.F5.55 is empty!
2022-01-09 09:56:42.378 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'PDF': Could not cast NULL to java.lang.Number; line 75, column 45, length 39
2022-01-09 09:56:50.471 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 09:56:50.472 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 09:57:05.214 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 09:57:05.214 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 09:57:05.215 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 09:57:05.216 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 09:57:05.216 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 09:57:05.216 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 09:57:05.219 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 09:57:05.219 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 09:57:05.219 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 09:57:05.223 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 09:57:05.223 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 09:57:05.224 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 09:57:05.224 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 09:57:35.525 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 09:57:35.526 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 09:57:50.230 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 09:57:50.231 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 09:57:50.232 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 09:57:50.232 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 09:57:50.233 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 09:57:50.233 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 09:57:50.237 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 09:57:50.237 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 09:57:50.238 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 09:57:50.244 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 09:57:50.244 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 09:57:50.244 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 09:57:50.245 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
Using my phone app, I have now deleted all entries that I had created previously. As far as I can tell, the hub database is now completely empty. However, I have not yet deleted from my OH instance the insteon things that had been created months ago for the legacy hub. I am not sure whether or not this is needed.
The current log file looks pretty much the same to me (see below). I am also attaching further below a copy of the error messages that are getting posyed on my OH console.
2022-01-09 11:34:21.287 [WARN ] [org.apache.karaf.shell.ssh.Activator] - Error starting activator
2022-01-09 11:34:21.852 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Montreal'.
2022-01-09 11:34:21.854 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '45.8352722,-72.4041412'.
2022-01-09 11:34:24.646 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2022-01-09 11:34:24.969 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2022-01-09 11:34:25.047 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'paradox.things'
2022-01-09 11:34:25.053 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'smartthings.things'
2022-01-09 11:34:25.058 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zigbee.things'
2022-01-09 11:34:25.063 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'tesla.things' has errors, therefore ignoring it: [1,77]: Number expected.
2022-01-09 11:34:25.069 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.things'
2022-01-09 11:34:25.828 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2022-01-09 11:34:26.461 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rachio.rules'
2022-01-09 11:34:26.820 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'chauffage.rules'
2022-01-09 11:34:27.622 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2022-01-09 11:34:28.770 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): CreateProcess error=2, Le fichier spécifié est introuvable)
2022-01-09 11:34:28.793 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2022-01-09 11:34:29.072 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): CreateProcess error=2, Le fichier spécifié est introuvable)
2022-01-09 11:34:29.381 [DEBUG] [covery.InsteonDeviceDiscoveryService] - Initializing InsteonNetworkDiscoveryService
2022-01-09 11:34:29.387 [DEBUG] [ternal.handler.InsteonNetworkHandler] - Starting Insteon bridge
2022-01-09 11:34:29.392 [DEBUG] [ding.insteon.internal.InsteonBinding] - port = '/hub/192.168.2.230:25105'
2022-01-09 11:34:29.462 [DEBUG] [ding.insteon.internal.InsteonBinding] - device poll interval set to 120 seconds
2022-01-09 11:34:29.462 [DEBUG] [ding.insteon.internal.InsteonBinding] - dead device timeout set to 1200 seconds
2022-01-09 11:34:29.488 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2022-01-09 11:34:29.499 [DEBUG] [eon.internal.device.DeviceTypeLoader] - loaded 47 devices:
2022-01-09 11:34:29.499 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000041 ->pk:0x000041|model:2484DWH8|desc:KeypadLinc Countdown Timer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0A ->pk:F00.00.0A|model:2852-222|desc:Leak Sensor|features:contact=LeakSensorContact:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0D ->pk:F00.00.0D|model:2634-222|desc:On/Off Dual-Band Outdoor Module|features:beep=Beep:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000049 ->pk:0x000049|model:2843-222|desc:Wireless Open/Close Sensor|features:contact=GenericContact:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0C ->pk:F00.00.0C|model:2476D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.0B ->pk:F00.00.0B|model:2672-422|desc:LED Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.500 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000068 ->pk:0x000068|model:2472D|desc:OutletLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:ramprate=RampRate:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff|groups:ext_group=ledbrightness,ramprate
2022-01-09 11:34:29.501 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000045 ->pk:0x000045|model:2413U|desc:PowerLinc 2413U USB modem|features:broadcastonoff=GroupBroadcastOnOff|groups
2022-01-09 11:34:29.501 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x00004A ->pk:0x00004A|model:2842-222|desc:Motion Sensor|features:lightlevelabovethreshold=WirelessMotionSensorLightLevelAboveThreshold:data=MotionSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime:lowbattery=WirelessMotionSensorLowBattery|groups
2022-01-09 11:34:29.501 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.01 ->pk:F00.00.01|model:2477D|desc:SwitchLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:ramprate=RampRate:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff:onlevel=OnLevel|groups:ext_group=ledbrightness,ramprate,onlevel
2022-01-09 11:34:29.501 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.23 ->pk:F00.00.23|model:2487S|desc:KeypadLinc On/Off 8-Button Scene Control |features:manualchangebuttone=ManualChangeButton5:manualchangebuttond=ManualChangeButton4:manualchangebuttong=ManualChangeButton7:manualchangebuttonf=ManualChangeButton6:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:manualchangebuttonc=ManualChangeButton3:keypadbuttonc=KeyPadButton3:manualchangebuttonb=ManualChangeButton2:loadswitchmanualchange=LoadSwitchManualChange:loadswitchfastonoff=LoadSwitchFastOnOff:fastonoffbuttonb=FastOnOffButton2:fastonoffbuttonc=FastOnOffButton3:fastonoffbuttond=FastOnOffButton4:fastonoffbuttone=FastOnOffButton5:fastonoffbuttonf=FastOnOffButton6:fastonoffbuttong=FastOnOffButton7:fastonoffbuttonh=FastOnOffButton8:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchangebuttonh=ManualChangeButton8:loadswitch=LoadSwitchButton|groups:manualchange_button_group=manualchangebuttonb,manualchangebuttonc,manualchangebuttond,manualchangebuttone,manualchangebuttonf,manualchangebuttong,manualchangebuttonh:fastonoff_button_group=fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond,fastonoffbuttone,fastonoffbuttonf,fastonoffbuttong,fastonoffbuttonh:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 11:34:29.501 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.22 ->pk:F00.00.22|model:2982-222|desc:Insteon Smoke Bridge|features:notification=ReceiveBroadcast:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.502 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.21 ->pk:F00.00.21|model:2441V|desc:Insteon Thermostat Adaptor for Venstar|features:fanmode=VenstarFanMode:iscooling=VenstarIsCooling:heatsetpoint=VenstarHeatSetPoint:tempfahrenheit=VenstarTemperatureFahrenheit:coolsetpoint=VenstarCoolSetPoint:humidity=VenstarHumidity:lastheardfrom=GenericLastTime:systemmode=VenstarSystemMode:isheating=VenstarIsHeating|groups:data1b_group=coolsetpoint,heatsetpoint,systemmode,fanmode,tempfahrenheit,humidity,isheating,iscooling
2022-01-09 11:34:29.502 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.20 ->pk:F00.00.20|model:2342-222|desc:Mini Remote (8 Button)|features:buttond=RemoteButton3:buttone=RemoteButton6:buttonb=RemoteButton1:buttonc=RemoteButton4:buttonh=RemoteButton7:buttonf=RemoteButton5:buttong=RemoteButton8:lastheardfrom=GenericLastTime:buttona=RemoteButton2|groups
2022-01-09 11:34:29.504 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.05 ->pk:F00.00.05|model:2456D3|desc:LampLinc V2|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.504 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.04 ->pk:F00.00.04|model:2876S|desc:ICON Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.03 ->pk:F00.00.03|model:2845-222|desc:Hidden Door Sensor|features:data=HiddenDoorSensorData:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.02 ->pk:F00.00.02|model:2477S|desc:SwitchLinc Switch|features:fastonoff=FastOnOff:beep=Beep:ledbrightness=LEDBrightness:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups:ext_group=ledbrightness
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.24 ->pk:F00.00.24|model:2844-222|desc:Motion Sensor II|features:lightlevelabovethreshold=WirelessMotionSensorLightLevelAboveThreshold:data=MotionSensor2Data:tamperswitch=WirelessMotionSensor2TamperSwitch:contact=WirelessMotionSensorContact:lastheardfrom=GenericLastTime:lowbattery=WirelessMotionSensorLowBattery|groups
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.09 ->pk:F00.00.09|model:2458-A1|desc:MorningLinc RF Lock Controller|features:switch=GenericSwitch|groups
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.08 ->pk:F00.00.08|model:2452-222|desc:DIN Rail Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.505 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.07 ->pk:F00.00.07|model:2453-222|desc:DIN Rail On/Off|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.06 ->pk:F00.00.06|model:2442-222|desc:Micro Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000051 ->pk:0x000051|model:2486DWH8|desc:KeypadLinc Dimmer - 8 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:keypadbuttonc=KeyPadButton3:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000050 ->pk:0x000050|model:2486DWH6|desc:KeypadLinc Dimmer - 6 Button|features:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:keypadbuttona=KeyPadButton3:keypadbuttond=KeyPadButton6:keypadbuttonb=KeyPadButton4:keypadbuttonc=KeyPadButton5:lastheardfrom=GenericLastTime:manualchange=ManualChange:rampdimmer=LoadDimmerRamp|groups:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1B ->pk:F00.00.1B|model:2635-222|desc:On/Off Module|features:beep=Beep:lastheardfrom=GenericLastTime:ledonoff=LEDOnOff:switch=GenericSwitch|groups
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1A ->pk:F00.00.1A|model:2475SDB|desc:In-LineLinc Relay|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.506 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1F ->pk:F00.00.1F|model:2477SA1|desc:220V 30-amp Load Controller N/O|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.507 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000039 ->pk:0x000039|model:2663-222|desc:On/Off Outlet|features:bottomoutlet=BottomOutlet:lastheardfrom=GenericLastTime:topoutlet=GenericSwitch|groups
2022-01-09 11:34:29.507 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1E ->pk:F00.00.1E|model:2674-222|desc:LED Bulb (recessed)|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2022-01-09 11:34:29.507 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1D ->pk:F00.00.1D|model:2456S3|desc:ApplianceLinc|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.507 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x000037 ->pk:0x000037|model:2486D|desc:KeypadLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer|groups
2022-01-09 11:34:29.507 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.1C ->pk:F00.00.1C|model:2475F|desc:FanLinc Module|features:fan=FanLincFan:lightdimmer=GenericDimmer:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.508 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.12 ->pk:F00.00.12|model:2466S|desc:ToggleLinc Switch|features:lastheardfrom=GenericLastTime:switch=GenericSwitch|groups
2022-01-09 11:34:29.508 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.11 ->pk:F00.00.11|model:2466D|desc:ToggleLinc Dimmer|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer|groups
2022-01-09 11:34:29.508 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.10 ->pk:F00.00.10|model:2342-2|desc:Mini Remote|features:buttond=RemoteButton4:buttonb=RemoteButton2:buttonc=RemoteButton3:lastheardfrom=GenericLastTime:buttona=RemoteButton1|groups
2022-01-09 11:34:29.508 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.03 ->pk:X00.00.03|model:X10 motion sensor|desc:Generic X10 motion sensor|features:contact=X10Contact|groups
2022-01-09 11:34:29.508 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.16 ->pk:F00.00.16|model:2334-232|desc:Keypad Dimmer Switch, 8-Button |features:manualchangebuttone=ManualChangeButton5:beep=Beep:manualchangebuttond=ManualChangeButton4:manualchangebuttong=ManualChangeButton7:manualchangebuttonf=ManualChangeButton6:keypadbuttond=KeyPadButton4:keypadbuttone=KeyPadButton5:keypadbuttonb=KeyPadButton2:manualchangebuttonc=ManualChangeButton3:keypadbuttonc=KeyPadButton3:manualchangebuttonb=ManualChangeButton2:ledbrightness=LEDBrightness:ledonoff=LEDOnOff:fastonoff=LoadDimmerFastOnOff:ramprate=RampRate:fastonoffbuttonb=FastOnOffButton2:fastonoffbuttonc=FastOnOffButton3:fastonoffbuttond=FastOnOffButton4:fastonoffbuttone=FastOnOffButton5:manualchange=ManualChange:fastonoffbuttonf=FastOnOffButton6:fastonoffbuttong=FastOnOffButton7:fastonoffbuttonh=FastOnOffButton8:onlevel=OnLevel:loaddimmer=LoadDimmerButton:keypadbuttonh=KeyPadButton8:lastheardfrom=GenericLastTime:keypadbuttonf=KeyPadButton6:keypadbuttong=KeyPadButton7:manualchangebuttonh=ManualChangeButton8:rampdimmer=LoadDimmerRamp|groups:manualchange_button_group=manualchangebuttonb,manualchangebuttonc,manualchangebuttond,manualchangebuttone,manualchangebuttonf,manualchangebuttong,manualchangebuttonh:fastonoff_button_group=fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond,fastonoffbuttone,fastonoffbuttonf,fastonoffbuttong,fastonoffbuttonh:ext_group=ledbrightness,ramprate,onlevel:button_group=keypadbuttonb,keypadbuttonc,keypadbuttond,keypadbuttone,keypadbuttonf,keypadbuttong,keypadbuttonh
2022-01-09 11:34:29.509 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.02 ->pk:X00.00.02|model:X10 dimmer|desc:Generic X10 Dimmer without preset|features:dimmer=X10Dimmer:switch=X10Switch|groups
2022-01-09 11:34:29.509 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.15 ->pk:F00.00.15|model:2334-232|desc:Keypad Dimmer Switch, 6-Button |features:beep=Beep:keypadbuttona=KeyPadButton3:manualchangebuttond=ManualChangeButton6:keypadbuttond=KeyPadButton6:manualchangebuttona=ManualChangeButton3:keypadbuttonb=KeyPadButton4:manualchangebuttonc=ManualChangeButton5:keypadbuttonc=KeyPadButton5:manualchangebuttonb=ManualChangeButton4:ledbrightness=LEDBrightness:ledonoff=LEDOnOff:onlevel=OnLevel:loaddimmer=LoadDimmerButton:fastonoff=LoadDimmerFastOnOff:ramprate=RampRate:fastonoffbuttonb=FastOnOffButton4:fastonoffbuttonc=FastOnOffButton5:lastheardfrom=GenericLastTime:fastonoffbuttond=FastOnOffButton6:manualchange=ManualChange:rampdimmer=LoadDimmerRamp:fastonoffbuttona=FastOnOffButton3|groups:manualchange_button_group=manualchangebuttona,manualchangebuttonb,manualchangebuttonc,manualchangebuttond:fastonoff_button_group=fastonoffbuttona,fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond:ext_group=ledbrightness,ramprate,onlevel:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 11:34:29.509 [DEBUG] [eon.internal.device.DeviceTypeLoader] - X00.00.01 ->pk:X00.00.01|model:X10 switch|desc:any simple X10 switch|features:switch=X10Switch|groups
2022-01-09 11:34:29.509 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.14 ->pk:F00.00.14|model:2487S|desc:KeypadLinc On/Off 6-Button Scene Control |features:keypadbuttona=KeyPadButton3:manualchangebuttond=ManualChangeButton6:keypadbuttond=KeyPadButton6:manualchangebuttona=ManualChangeButton3:keypadbuttonb=KeyPadButton4:manualchangebuttonc=ManualChangeButton5:keypadbuttonc=KeyPadButton5:manualchangebuttonb=ManualChangeButton4:loadswitchmanualchange=LoadSwitchManualChange:loadswitchfastonoff=LoadSwitchFastOnOff:fastonoffbuttonb=FastOnOffButton4:fastonoffbuttonc=FastOnOffButton5:lastheardfrom=GenericLastTime:fastonoffbuttond=FastOnOffButton6:loadswitch=LoadSwitchButton:fastonoffbuttona=FastOnOffButton3|groups:manualchange_button_group=manualchangebuttona,manualchangebuttonb,manualchangebuttonc,manualchangebuttond:fastonoff_button_group=fastonoffbuttona,fastonoffbuttonb,fastonoffbuttonc,fastonoffbuttond:button_group=keypadbuttona,keypadbuttonb,keypadbuttonc,keypadbuttond
2022-01-09 11:34:29.509 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.13 ->pk:F00.00.13|model:2672-222|desc:LED Bulb|features:fastonoff=FastOnOff:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:rampdimmer=RampDimmer_3435|groups
2022-01-09 11:34:29.515 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.19 ->pk:F00.00.19|model:2457D2|desc:LampLinc Dimmer|features:fastonoff=FastOnOff:beep=Beep:lastheardfrom=GenericLastTime:manualchange=ManualChange:dimmer=GenericDimmer:ledonoff=LEDOnOff|groups
2022-01-09 11:34:29.515 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.18 ->pk:F00.00.18|model:2441TH|desc:Insteon Thermostat|features:humidityhigh=ThermostatHumidityHigh:stage1duration=ThermostatStage1Duration:humiditylow=ThermostatHumidityLow:systemmode=ThermostatSystemMode:isheating=ThermostatIsHeating:fanmode=ThermostatFanMode:iscooling=ThermostatIsCooling:heatsetpoint=ThermostatHeatSetPoint:coolsetpoint=ThermostatCoolSetPoint:temperature=ThermostatTemperatureFahrenheit:humidity=ThermostatHumidity:lastheardfrom=GenericLastTime:acdelay=ThermostatACDelay:backlightduration=ThermostatBackLightDuration|groups:data1b_group=humidityhigh,humiditylow,stage1duration:data2_group=coolsetpoint,heatsetpoint,systemmode,fanmode,isheating,iscooling,temperature,humidity:data1_group=backlightduration,acdelay
2022-01-09 11:34:29.515 [DEBUG] [eon.internal.device.DeviceTypeLoader] - 0x00001A ->pk:0x00001A|model:2450|desc:IO Link|features:contact=IOLincContact:lastheardfrom=GenericLastTime:switch=IOLincSwitch|groups
2022-01-09 11:34:29.516 [DEBUG] [eon.internal.device.DeviceTypeLoader] - F00.00.17 ->pk:F00.00.17|model:2423A1|desc:iMeter Solo Power Meter|features:meter=PowerMeter:lastheardfrom=GenericLastTime|groups
2022-01-09 11:34:29.547 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatHumidityHigh(0:1:2)
2022-01-09 11:34:29.547 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatHumidityLow(0:1:2)
2022-01-09 11:34:29.547 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1b_group connected feature: ThermostatStage1Duration(0:1:2)
2022-01-09 11:34:29.556 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 11:34:29.557 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 11:34:29.557 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 11:34:29.557 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:27D986 address = 27.D9.86 productKey = F00.00.1B channels = beep, lastHeardFrom, ledOnOff, switch
2022-01-09 11:34:29.563 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatCoolSetPoint(0:1:3)
2022-01-09 11:34:29.557 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 11:34:29.563 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatHeatSetPoint(0:1:3)
2022-01-09 11:34:29.563 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 11:34:29.563 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatSystemMode(0:1:3)
2022-01-09 11:34:29.563 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatFanMode(0:1:3)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatIsHeating(0:0:3)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatIsCooling(0:0:3)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatTemperatureFahrenheit(0:0:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: RampRate(0:1:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data2_group connected feature: ThermostatHumidity(0:0:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: OnLevel(0:1:2)
2022-01-09 11:34:29.564 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1_group connected feature: ThermostatBackLightDuration(0:1:2)
2022-01-09 11:34:29.565 [DEBUG] [nsteon.internal.device.InsteonDevice] - data1_group connected feature: ThermostatACDelay(0:1:2)
2022-01-09 11:34:29.567 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347A5 address = 33.47.A5 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 11:34:29.588 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:259705 address = 25.97.05 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 11:34:29.589 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 11:34:29.592 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347F5 address = 33.47.F5 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
2022-01-09 11:34:29.609 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:394B3E address = 39.4B.3E productKey = F00.00.02 channels = beep, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, switch
2022-01-09 11:34:29.610 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:2B8D15 address = 2B.8D.15 productKey = F00.00.0C channels = fastOnOff, lastHeardFrom, dimmer, manualChange
2022-01-09 11:34:29.611 [DEBUG] [nsteon.internal.device.InsteonDevice] - ext_group connected feature: LEDBrightness(0:1:2)
2022-01-09 11:34:29.613 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555 address = 32.F5.55 productKey = F00.00.18 channels = isHeating, humidityLow, humidity, acDelay, lastHeardFrom, fanMode, stage1Duration, backlightDuration, systemMode, coolSetPoint, temperature, humidityHigh, isCooling, heatSetPoint
2022-01-09 11:34:29.614 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:236CF9 address = 23.6C.F9 productKey = F00.00.05 channels = fastOnOff, lastHeardFrom, dimmer, manualChange
2022-01-09 11:34:29.756 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:D1 address = D.1 productKey = X00.00.01 channels = switch
2022-01-09 11:34:29.758 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:C2c address = C.2 productKey = X00.00.01 channels = switch
2022-01-09 11:34:29.774 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:33FF3A address = 33.FF.3A productKey = F00.00.02 channels = beep, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, switch
2022-01-09 11:34:30.716 [INFO ] [mekit.internal.HomekitChangeListener] - Created 19 HomeKit items.
2022-01-09 11:34:30.822 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2022-01-09 11:34:30.842 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:27D986:switch
2022-01-09 11:34:30.843 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:27D986:switch feature = switch parameters = {}
2022-01-09 11:34:30.843 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:3347A5:dimmer
2022-01-09 11:34:30.843 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347A5:dimmer feature = dimmer parameters = {}
2022-01-09 11:34:30.843 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:259705:dimmer
2022-01-09 11:34:30.844 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:259705:dimmer feature = dimmer parameters = {}
2022-01-09 11:34:30.844 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:3347F5:dimmer
2022-01-09 11:34:30.844 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:3347F5:dimmer feature = dimmer parameters = {}
2022-01-09 11:34:30.844 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:394B3E:switch
2022-01-09 11:34:30.844 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:394B3E:switch feature = switch parameters = {}
2022-01-09 11:34:30.844 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:2B8D15:dimmer
2022-01-09 11:34:30.845 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:2B8D15:dimmer feature = dimmer parameters = {}
2022-01-09 11:34:30.845 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:isHeating
2022-01-09 11:34:30.845 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:isHeating feature = isheating parameters = {}
2022-01-09 11:34:30.845 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:humidity
2022-01-09 11:34:30.845 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:humidity feature = humidity parameters = {}
2022-01-09 11:34:30.845 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:backlightDuration
2022-01-09 11:34:30.846 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:backlightDuration feature = backlightduration parameters = {}
2022-01-09 11:34:30.846 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:systemMode
2022-01-09 11:34:30.846 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:systemMode feature = systemmode parameters = {}
2022-01-09 11:34:30.846 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:temperature
2022-01-09 11:34:30.846 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:temperature feature = temperature parameters = {}
2022-01-09 11:34:30.846 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:32F555:heatSetPoint
2022-01-09 11:34:30.847 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:32F555:heatSetPoint feature = heatsetpoint parameters = {}
2022-01-09 11:34:30.847 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:236CF9:dimmer
2022-01-09 11:34:30.847 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:236CF9:dimmer feature = dimmer parameters = {}
2022-01-09 11:34:30.847 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:D1:switch
2022-01-09 11:34:30.847 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:D1:switch feature = switch parameters = {}
2022-01-09 11:34:30.847 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:C2c:switch
2022-01-09 11:34:30.848 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:C2c:switch feature = switch parameters = {}
2022-01-09 11:34:30.848 [DEBUG] [ding.insteon.internal.InsteonBinding] - adding listener for channel insteon:device:home:33FF3A:switch
2022-01-09 11:34:30.848 [DEBUG] [nternal.handler.InsteonDeviceHandler] - insteon:device:home:33FF3A:switch feature = switch parameters = {}
2022-01-09 11:34:31.281 [INFO ] [nal.communication.CommunicationState] - Login - Login to IP150 - OK
2022-01-09 11:34:31.920 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid df689237-cd52-4bf0-a8d2-64bc60d6ff7d
2022-01-09 11:34:31.930 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.2.3' with clientid 447f3dba-b8f1-472b-8fa0-0a6a634ea441
2022-01-09 11:34:32.138 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.3:8080
2022-01-09 11:34:32.138 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.3:8443
2022-01-09 11:34:32.175 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2022-01-09 11:34:32.201 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2022-01-09 11:34:32.238 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2022-01-09 11:34:32.687 [INFO ] [nal.communication.CommunicationState] - Successfully established communication with the panel.
2022-01-09 11:34:32.702 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 7424d7f9-d34e-4f60-a3d6-7fa17f64f06e, base URL = http://localhost:8080)
2022-01-09 11:34:35.490 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:34:35.492 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:34:35.499 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:34:35.499 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:34:35.526 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:34:35.527 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:34:35.532 [DEBUG] [ding.insteon.internal.InsteonBinding] - devices: 11 configured, 0 polling, msgs received: 0
2022-01-09 11:34:35.532 [DEBUG] [nding.insteon.internal.driver.Poller] - starting poll thread.
2022-01-09 11:34:38.794 [INFO ] [doxalarm.internal.model.ParadoxPanel] - Paradox system is supported. Panel data retrieved=ParadoxInformation [panelType=EVO192, serialNumber=05086F2A, applicationVersion=Version: 7.1.4, hardwareVersion=Version: 0.10, bootloaderVersion=Version: 1.0.15]
2022-01-09 11:34:42.642 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'PDF': Could not cast NULL to java.lang.Number; line 75, column 45, length 39
2022-01-09 11:35:05.770 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:35:05.771 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:35:20.533 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:35:20.534 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:35:20.536 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:35:20.537 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:35:20.537 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:35:20.537 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:35:20.542 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:35:20.543 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:35:20.544 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:35:20.549 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:35:20.550 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:35:20.550 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:35:20.551 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:35:50.797 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:35:50.798 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:36:05.557 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:36:05.558 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:36:05.559 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:36:05.559 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:36:05.560 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:36:05.560 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:36:05.566 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:36:05.567 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:36:05.568 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:36:05.576 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:36:05.581 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:36:05.582 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:36:05.583 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:36:35.602 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:36:35.604 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:36:50.588 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:36:50.589 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:36:50.590 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:36:50.590 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:36:50.590 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:36:50.591 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:36:50.595 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:36:50.595 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:36:50.596 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:36:50.602 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:36:50.602 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:36:50.602 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:36:50.603 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:37:20.877 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:37:20.878 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:37:35.609 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:37:35.611 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:37:35.611 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:37:35.611 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:37:35.612 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:37:35.612 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:37:35.619 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:37:35.620 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:37:35.621 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:37:35.628 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:37:35.628 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:37:35.628 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:37:35.629 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:38:05.662 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:38:05.663 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:38:20.636 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:38:20.637 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:38:20.638 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:38:20.638 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:38:20.639 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:38:20.639 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:38:20.647 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:38:20.648 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:38:20.649 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:38:20.657 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:38:20.657 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:38:20.657 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:38:20.658 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:38:50.720 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:38:50.721 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:39:05.665 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:39:05.666 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:39:05.667 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:39:05.667 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:39:05.668 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:39:05.669 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:39:05.677 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:39:05.678 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:39:05.679 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:39:05.685 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:39:05.687 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:39:05.687 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:39:05.688 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:39:35.696 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
2022-01-09 11:39:35.697 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:39:50.695 [DEBUG] [binding.insteon.internal.driver.Port] - got an io exception in the reader thread
2022-01-09 11:39:50.696 [WARN ] [binding.insteon.internal.driver.Port] - port /hub/192.168.2.230:25105 disconnected
2022-01-09 11:39:50.697 [DEBUG] [binding.insteon.internal.driver.Port] - reader thread exiting!
2022-01-09 11:39:50.697 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for read thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:39:50.697 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x69|
2022-01-09 11:39:50.698 [DEBUG] [binding.insteon.internal.driver.Port] - waiting for write thread to exit for port /hub/192.168.2.230:25105
2022-01-09 11:39:50.705 [DEBUG] [binding.insteon.internal.driver.Port] - all threads for port /hub/192.168.2.230:25105 stopped.
2022-01-09 11:39:50.706 [DEBUG] [ding.insteon.internal.InsteonBinding] - starting to poll /hub/192.168.2.230:25105
2022-01-09 11:39:50.707 [DEBUG] [binding.insteon.internal.driver.Port] - starting port /hub/192.168.2.230:25105
2022-01-09 11:39:50.712 [DEBUG] [binding.insteon.internal.driver.Port] - clearing modem db!
2022-01-09 11:39:50.712 [DEBUG] [binding.insteon.internal.driver.Port] - starting writer...
2022-01-09 11:39:50.712 [DEBUG] [binding.insteon.internal.driver.Port] - starting reader...
2022-01-09 11:39:50.713 [DEBUG] [binding.insteon.internal.driver.Port] - writing (0): OUT:Cmd:0x60|
2022-01-09 11:40:20.773 [WARN ] [steon.internal.device.ModemDBBuilder] - Modem database download was unsuccessful, restarting! No messages were received, the PLM or hub might be broken. If this continues see 'Known Limitations and Issues' in the Insteon binding documentation.
openhab> Exception in thread "Insteon /hub/192.168.2.230:25105 Writer" java.lang.NullPointerException
at org.openhab.binding.insteon.internal.driver.IOStream.write(IOStream.java:80)
at org.openhab.binding.insteon.internal.driver.Port$IOStreamWriter.run(Port.java:466)
at java.lang.Thread.run(Unknown Source)
/hub/
is for the 2242-222 hub. Try using the below format for the 2245-222 hub:
/hub2/my_user_name:my_password@192.168.1.100:25105
I think you can link the devices using the insteon app. Just make sure to not use both the app and OH at the same time.
Oh my god! How can I have missed that in the binding doc? Apologies for having wasted your time.
Everything is now working normally with my new hub
I did use the Insteon app to repopulate my hub database. It works fine and happens to be substantially easier for someone like me… I will make sure to avoid using the app and OH at the same time.
Huge thanks!
Pierre
