Interested in hardware
On Debian type machines such folders have a group with group rwx permissions so all one needs do is add openhab to that group to grant it rights. CentOS doesn’t work like this? That’s unfortunate. It is rather unfortunate because running OH (or any such service for that matter) as root is not a great answer from a security perspective.
This isn’t a new method. OH is a Java program. Java and make don’t usually play well together. OH’s packaging and delivery is pretty standard for Java type projects.
The OH community also suffers a little from Debian myopia. All the docs and scripts and packages are focused on apt. This makes sense because perhaps the most popular platform upon which OH is run is a Raspberry Pi, or a similar type of machine, which runs a Debian based Linux (i.e. Raspbian). With Ubuntu being the second most popular support for other types of Linux, OS X, and Windows is not as strong.
However, I would say that I’m sure the community would welcome someone to submit an RPM build to the build scripts.
That is a treach for OH 1.5. So much has changed that what is on that thread is unlikely to address your specific problem. Those node.xml files are automatically generated by the binding based on the data in the zwave database. Chris asked the submitter to append some to that file just to see if there was a problem with the database entry for that device. Essentially the XML tells the functional part of the binding what that node is capable of and configuration parameters. Manually editing that file is not a permanent solution.
And for the record, those files are located in userdata/zwave
So OH is a lot like Linux. There is a core which you can think of like the Kernel. Then there are addons which run on the core. Pretty much all of the addons are written by third parties. So there is going to be a lot of inconsistency in the amount of documentation written, quality of that documentation, and how much fiddling is required to get things to work. These addons are like all the programs that run on Linux.
So you admitted above you usually do not RTFM. So have you spent any time reading at http://docs.openhab.org/ ?
These are indeed incomplete but they do give a relatively high overview of all the pieces and concepts and how they fit together. Unfortunately, OH is not very self documenting nor is it intuitive how to set everything up. Skipping the docs is really not going to lead to a happy experience.
I can’t answer specifically to your specific problems with mariadb and mysql. I know some people have made it work but I have no experience with it. The first link above is how I set up my persistence and the second one is to the OH 1.x wiki which is a good source of info since the 2.0 persistence docs are unfinished. But for the most part, based on some things I’ve seen on this forum, MariaDB and MySQL are not compatible. You have to use the same binding as the DB.
There are several UIs in OH. I agree this is causing some confusion. PaperUI and Habmin are intended to be administration UIs. Sitemaps which get defined by .sitemap files are for configuing BasicUI and ClassicUI. HabPanel has its own browser based set and configuration. I don’t know much about CometVisu.
At this time, neither PaperUI nor Habmin are capable of creating sitemaps.
I completely agree. I’m firmly in the camp that PaperUI, in its current state, causes more problems than it solved. Until PaperUI or Habmin can do EVERYTHING and do it well I would make it optional, not the default thing that comes up. I’ve had to help a lot of people and have even run into problems myself because of the way PaperUI does things and hides things.
My recommendation is to use text files for everything (turning off simple mode in PaperUI) except auto-discovery of Things and installation of addons.
The inconsistency and bifurcated configuration is really causing problems.
That sounds like a bug. That shouldn’t happen. But again, I don’t recommend using PaperUI for this anyway so I’m not sure if this is a known bug or something new. It is worth a new thread to discuss and perhaps opening an issue.
