Hey guys after a lot of research I finally figured out how to integrate the Wyze Cam2 into Openhab’s Habpanel. Wyze cam’s are some of the best and cheapest IP cams on the market for the price.
Since these camera’s do not currently support RTSP without hacking the firmware it will not natively connect into your system. The work around comes with the Android App TinyCam Pro which is 3.99 on Google Play.
Once downloaded and configured to your cameras you can then turn on the web server which will broadcast your camera’s on your local network. I happen to have an android device that I leave on all the time as a bridge for other items so it was no extra cost to get this going. Once your web server is up and running on Tinycam Pro you can the start to configure it into Habpanel.
- Open your webserver on your laptop or desktop browser.
- Right click on the feed you want to implement
- Click Inspect element
- Copy the url
- Paste the URL into the HABPANEL Camera Feed Widget.
