Internet Radio - I need your help!
Have an internet radio? I need your help!
I am currently migrating the internet radio binding from openhab 1.x to Eclipse Smarthome (including openhab 2).
In order to properly implement the Discovery Service (the radio is automatically listed as a new thing e.g. in the Paper UI), I need some information from owners of internet radios:
  1. If your internet radio is connected to your network, it is most likely discoverable
  2. Please download UPnP Tester (Windows), and install it; didn’t try such a tool for Mac/Linux…
  3. Run it (may take a while) and check the resulting list for a device that looks like your internet radio
  4. Select it and click ‘Properties’, make a screenshot and post it here
This is mine:
Thank you :grinning:
My Internet Radio has the properties below:
This is my Hama IR110
Thanks, I added your radios to the list of supported devices (untested of course, because I don’t own them).
The corresponding pull request: Initial version of FS internet radio binding. by paphko · Pull Request #429 · eclipse-archived/smarthome · GitHub
I have a Pinell Supersound II which I manage to connect after some research and it works as expected. However it uses a special port for the fsapi, 2244. I don’t know if that is the same port for all Pinell radios. I found it by using Wireshark to locate the SSDP Notify messages. The output from the UPnP tester is as follows (I use a more recent version than you)
Generated on: Thursday, February 11, 2016 10:57:58.
Devices and Services
±+ TTMicro AS Pinell Supersound (Device)
| Manufacturer: TTMicro AS
| ModelURL: “http://www.ttmicro.no/”
| FriendlyName: Hemma
| PresentationUrl: “http://192.168.0.161/web”
| ManufacturerUrl: “http://www.ttmicro.no/”
| UDN: uuid:3dcc7100-f76c-11dd-87af-002261015b9d
| DeviceType: urn:schemas-upnp-org:device:MediaRenderer:1
| SerialNumber: 0808120023341f270100120dffff8dff
| ModelNumber: Pinell Supersound
| ModelName: Pinell Supersound
| Description: Digital Radio
±+ AVTransport (Service)
±+ ConnectionManager (Service)
±+ RenderingControl (Service)
I hope your discovery service will find the radio but also the fsapi port.
@TorstenO Thank you for the information!
I’ll add your model as soon as I find some time :slightly_smiling:
Here is Superconnect,
In Progress: https://github.com/eclipse/smarthome/pull/3047
Roberts Stream 93i Radio
My Radio: Auna Connect 150
Location http://192.168.2.203:8080/dd.xml
UDN uuid:3dcc7100-f76c-11dd-87af-00226124ca30
DeviceType urn:schemas-upnp-org:device:MediaRenderer:1
BaseAdress http://192.168.2.203:8080/dd.xml
FriendlyName Connect 150 00226124ca30
Manufacturer AUNA
ManufacturerUrl http://www.auna.de/
ModelDescription 2.1CH Internet radio with FM/DAB/DAB+
ModelName Connect 150
ModelNumber 10028154 & 10028155
ModelUrl http://www.auna.de/
SerialNumber 0f060b1016251f2701013205ffff0aff
Presentation http://192.168.2.203:8080/web
This information was collected under Ubuntu Linux with the tool gupnp (from package gupnp-tools) .
Maybe you could include this in your opening post for other linux users?
I translated the property names from my german locale to match the ones in your screenshots as best as I could.
I’ve added both of these now I have the time
Roberts Stream 93i
Auna Connect 150
Great, thank you @garthy!
Is there a reason why we have to add the known items. Couldn’t we just support any fsradio but use these values as known​ to work?
Do you mean that we should list all upnp devices and propose them as internet radios? At least in my case, I found 17 upnp devices although I have just 7 physical devices on my network (e.g. NAS, Kodi, Sonos, router, TV, etc.). And only one single device is a frontier silicon internet radio. So we should not present all potential devices to the user.
For a proper discovery, we must go one step further and try to connect to each device to see whether it is a potentially compatible device that implements the frontier silicon API. This could take quite a while, especially if some devices do not respond so we run into timeouts. Or maybe you have a better idea?
If all radio devices share (partly)a common description, this could be used for filtering.
From the screenshots above, all devices share “radio” in the UPnP ModelDescription tag.
Agree, that would be nice, but this is not the case.
False. See 3rd post (HAMA IR110).
Ah, ok, I did not see this :frowning:
can you add the following devices? This devices used sync and unsync options for multiroom. is this item planed in this binding?
thanks a lot
Hey @paphko,
I only have a Mac and no clue how to get some upnp inspector (it seems there is nothing available in the last years).
So, which of the information is needed most? I have some Silvercest devices like @gravidigit (see above).
WLAN Box: ModelName SMRS 35A1
WLAN Soundbar: ModelName SMRB 40A1
Is that enough?
Thanks!
My Roberts stream83i, which is currently not being accessed by the binding, produced the following data.
Description: ir-mmi-FS2026-0200-0305_Stream83i_V2.2.15.EX21499-V1.00
FriendlyName: Stream 83i 002261aea81c
Manufacturer: Roberts Radio Limited
ManufacturerUrl: http://www.robertsradio.co.uk/
ModelName: Stream 83i
ModelNumber: Stream 83i
ModelURL: http://www.robertsradio.co.uk/
PresentationUrl: http://xxx.xxx.xx.27/web
SerialNumber: 0b060a1124331f2701009e02ffff6dff
UDN: uuid:3dcc7100-f76c-11dd-87af-002261aea81c
Default pin is 1234
http://xxx.xxx.xx.27/fsapi/CREATE_SESSION?pin=1234
did not result in an error but only showed an blank page
