Intertechno LAN gateway
I know there is an intertechno binding, but it seems to me to be for directly connected 433MHz transmitters.
I have a bunch of these intertechno relay socket things hanging around doing nothing useful, and I have a LAN gateway. I know this is sort of been figured out (via this PHP thing called Connair). But I don’t really understand exactly what or how i would send something if I wanted to do it directly via Openhab. (I was thinking that maybe it could be done with something like CURL, assuming I could figure out the correct code for each switch…). Has anyone else played with this?
best,
matt
Hi Matt
the Intertechno CURL binding did not work for me neither. I have the Intertechno LAN gateway ITGW-433 and PAR-1500 wall sockets.
You can send ON/OFF with an external script. The ITGW-433 accepts commands only via UDP.
There are basic values to be set with which the whole message will be built.
Put the senditgw433.py script into /opt/openhab/customfiles. Python should be installed by default on the Raspberry Pi.
  1. find the ITGW’s IP address and put it into the script senditgw433.py
  2. add the addon org.openhab.binding.exec-1.8.2.jar (or any other version of course) to the addon folder.
  3. create the Switch item for the wall socket:
    Switch IT_PAR1500_A1 "PAR-1500 A1" <button> {exec=">[OFF:/usr/bin/python /opt/openhab/customfiles/senditgw433.py A 1 off] >[ON:/usr/bin/python /opt/openhab/customfiles/senditgw433.py A 1 on]"}
  4. The code is pretty simple. When the OFF (or ON) commands are received, openhab will execute the python script senditgw433.py with 3 arguments.
    Argument 1 is the master address (A), arg. 2 is the slave address (1), and arg. 3 the state to switch to (ON/OFF).
  5. add the item to the sitemap:
    Switch item=IT_PAR1500_A1 mappings=[ON="ON", OFF="OFF"]
  6. put the script into /opt/openhab/customfiles/ of your installation, or wherever you want and modify the path in the item file.
  7. copy-paste the script and name it senditgw433.py (or whatever and …you know)
#!/usr/bin/python
import socket import sys
UDP_IP = "192.168.200.4" UDP_PORT = 49880
#################### Basic values ########################
lo = "4," hi = "12," seqLo = "4,12,4,12," # lo + hi + lo + hi seqFl = "4,12,12,4," # lo + hi + hi + lo h = "4,12,12,4," # = seqFl l = "4,12,4,12," # = seqLo ToggleOn = "4,12,12,4,4,12,12,4," # = h + h ToggleOff = "4,12,12,4,4,12,4,12," # = h + l additional = "4,12,4,12,4,12,12,4," # = l + h headITGW = "0,0,6,11125,89,26,0," tx433version = "1," sPeedITGW = "125,"
tailITGW = tx433version + sPeedITGW + "0"
#################### Master ########################
if sys.argv[1] == "A": Master = l + l + l + l elif sys.argv[1] == "B": Master = h + l + l + l elif sys.argv[1] == "C": Master = l + h + l + l elif sys.argv[1] == "D": Master = h + h + l + l elif sys.argv[1] == "E": Master = l + l + h + l elif sys.argv[1] == "F": Master = h + l + h + l elif sys.argv[1] == "G": Master = l + h + h + l elif sys.argv[1] == "H": Master = h + h + h + l elif sys.argv[1] == "I": Master = l + l + l + h elif sys.argv[1] == "J": Master = h + l + l + h elif sys.argv[1] == "K": Master = l + h + l + h elif sys.argv[1] == "L": Master = h + h + l + h elif sys.argv[1] == "M": Master = l + l + h + h elif sys.argv[1] == "N": Master = h + l + h + h elif sys.argv[1] == "O": Master = l + h + h + h elif sys.argv[1] == "P": Master = h + h + h + h
#################### Slave ########################
if sys.argv[2] == "1": Slave = l + l + l + l elif sys.argv[2] == "2": Slave = h + l + l + l elif sys.argv[2] == "3": Slave = l + h + l + l elif sys.argv[2] == "4": Slave = h + h + l + l elif sys.argv[2] == "5": Slave = l + l + h + l elif sys.argv[2] == "6": Slave = h + l + h + l elif sys.argv[2] == "7": Slave = l + h + h + l elif sys.argv[2] == "8": Slave = h + h + h + l elif sys.argv[2] == "9": Slave = l + l + l + h elif sys.argv[2] == "10": Slave = h + l + l + h elif sys.argv[2] == "11": Slave = l + h + l + h elif sys.argv[2] == "12": Slave = h + h + l + h elif sys.argv[2] == "13": Slave = l + l + h + h elif sys.argv[2] == "14": Slave = h + l + h + h elif sys.argv[2] == "15": Slave = l + h + h + h elif sys.argv[2] == "16": Slave = h + h + h + h
#################### Toggle ########################
if sys.argv[3] == "on": Toggle = ToggleOn elif sys.argv[3] == "off": Toggle = ToggleOff
MESSAGE = headITGW + Master + Slave + additional + Toggle + tailITGW
print "UDP target IP:", UDP_IP print "UDP target port:", UDP_PORT print "message:", MESSAGE
sock = socket.socket(socket.AF_INET, # Internet socket.SOCK_DGRAM) # UDP sock.sendto(MESSAGE, (UDP_IP, UDP_PORT))
The good thing with OH2 is that you can really split all configs into their own files.
So here what I did; it can surely be optimized.
intertechno.things
every switch needs to be added
exec:command:intertechnoN2 [command="/usr/bin/python /opt/openhab/customfiles/send2itgw433.py N 2 %2$s", interval=0, timeout=5, autorun=true]
exec:command:intertechnoP14 [command="/usr/bin/python /opt/openhab/customfiles/send2itgw433.py P 14 %2$s", interval=0, timeout=5, autorun=true]
intertechno.items
String IntertechnoN2		"Tankraum Licht"		<button>	(InitOO2)	{channel="exec:command:intertechnoN2:input", autoupdate="true"}
String IntertechnoP14		"Sternenkette"			<button>				{channel="exec:command:intertechnoP14:input", autoupdate="true"}
The script itself stayed the same (sorry, I didn’t realize it looked crappy above)
senditgw433.py
    #!/usr/bin/python
    import socket
    import sys
    UDP_IP          = "192.168.10.249"
    UDP_PORT        = 49880
    lo              = "4,"
    hi              = "12,"
    tx433version    = "1,"
    sPeedITGW       = "125,"
    #tailITGW       = "1,125,0"                      # = tx433version + ',' + sPeedITGW + "0"
            Toggle = ToggleOn
            Toggle = ToggleOff
    # MESSAGE = headITGW + master + slave + additional + on/off + tailITGW
In the rules.rules file, the Intertechno switches can be controlled with
sendCommand(IntertechnoN2, "ON")
sendCommand(IntertechnoP14, "OFF")
The binding “Exec Binding” needs to be added to the PaperUI, then those 2 switches will appear in the Inbox.
Hope it helped
I try to connect my Intertechno LAN gateway to OpenHAB 2.5.10
I have in my things:
Thing exec:command:intertechnoB1 [command="/usr/bin/python /etc/openhab2/services/senditgw433.py B 1 %2$s", interval=0, timeout=5, autorun=true]
Then I added to /etc/openhab2/misc/exec.whitelist:
And I installed in PaperUI: Add-ons → Transformations → RegEx TRansformation
I also installed in PaperUI: Add-ons → Bindings → Exec Binding
Now I have no Error in the log Files.
My item is:
String Wohnzimmer_Deckenlampe "Wohnzimmer Deckenlampe" <light> {channel="exec:command:intertechnoB1:input", autoupdate="true"}
My sitemap is:
Switch item=Wohnzimmer_Deckenlampe mappings=[ON="ON", OFF="OFF"]
Nothing happens when I use the switch.
When I connect via ssh to my raspberrypi and enter this:
/usr/bin/python /etc/openhab2/services/senditgw433.py B 1 on
the blue light at the LAN gateway blinks blue and it works!
When I use the app it works fine.
Can someone help me?
Hi Georg,
at Thing level, you have to enable the “autorun” option. And you also should link the “run” channel.
For more stability, I do not use the “autorun”, and I pass also the maser and salve code to python by the input channel.
var eventItem = this.event.itemName;
logger.debug("Event item:  " + eventItem);
logger.debug("newState:  " + state);
var switchCode = [];
switch (eventItem) {
  case "EGBueroLicht":
    switchCode.push("B");
    switchCode.push("16");
    break;
  default:
    logger.error("No event item found: " + eventItem);
    break;
// rollershutter can also set to 'STOP'. At intertechno a stop is triggered by repeating the command
if (state == STOP) {
  var last_cmd = items.EGKueITGW_Eingabewert.split(",");
  logger.debug("last_cmd: " + last_cmd);
  logger.debug("switchCode: " + switchCode)
  if (last_cmd[0] == switchCode[0] // make sure, it's the same IT device code
       && last_cmd[1] == switchCode[1])
    switchCode.push(last_cmd[3]);
  } else { // stopping an other device is not possible
    logger.warn("Not possible to stop!");
} else { // not STOP, rather ON/OFF/UP/DOWN
    switchCode.push(state);
events.sendCommand("EGKueITGW_Eingabewert", switchCode.join(",")); // ON /OFF // DOWN / UP
events.sendCommand("EGKueITGW_Ausfuhrung", ON.toString()); // "ON" to run the py script
