Ip cams in HomeKit Binding
good afternoon, I looked in the posts of the community, but I have not found arguments about the integration of professionale IP Cam (ELMO) in HomeKit binding through OH2.
Does someone knows if it can be done?
Conf: RBpi 3B+, OH2 latest version, KNX and HomeKit Bindings
Thanks in advance
Marco
I don’t think so.
If you want video in Apple’s Homekit you should buy a compatible camera that works directly with Homekit.
For OH2, you can display the video stream in a web page (e.g. using HABPanel)
But you won’t be able to do: Cam -> OH2 -> Homekit
You could also try: IpCamera: New IP Camera Binding
Thank you so much
Marco
Or you can use Node-RED with it’s HomeKit module. It supports much more item type than OH’s binding and you can configure cameras there as well. Never tried it, I don’t know if it works or not.
