Ok, I fully understand the reason and will stay on the implemented functions.
Thank you.
Out of interest what was the use case you wanted it? You can always do the testing and post the info that would help someone implement it faster into a GitHub issue.
Most of the api is contained into a single file here if you do code and can contribute. Each brand is kept in a separate file to keep things easier to maintain.
My gif creation of the latest 2.5.9 binding stops working every few days. With the older version before the big changes, it worked betterâŚ
Now the gif-creation suddenly stops after some time. I don´t get an email with the new gif anymore. When i do a openhab service restart, it works again and i get my gifs inside email.
I don´t know what i can help you, some time ago a few people mentioned this problem and you said, you know where the problem is and fixed it, but since the new version with the big changes, the problem is back again - and i think, the problem is bigger⌠It everytime stops after a few days. When the old error was inside the binding, it sometimes worked weeks until it stopped.
Need more info as I dont recall there ever being an issue.
- Does the file get created, or is there no file?
- What do the logs say?
- Does adding a delay from when the binding says the file is done to when you try and use it help?
My live stream inside openhab is still visible.
Where can i see, if a gif-file is created? Openhab is not sending an email, when the error occurs.
Look at my things-file:
ffmpegOutput="/tmpfs/camera1/"
is this the right place to look?
On log-file it looks good - but i haven´t enabled trace.
Do you think, it could be a problem with the email instead of the ipcam-binding? So i will try to send another email, when the error is back again the next time.
Now for first try i have added a threadsleep(1000) right before the email sending command.
I suggest you to look at the path you specify (/tmpfs/camera1/) if the file exists and is reporting the last time updated
If you have anyother notifications email you can check if this is still working for other events
look at the remaining space on SD, supposing you are using this as a storage media on a reaspberry system
A TMPFS location will run out of space so are you using the filename as âipcamera.gifâ so it gets over written each time? What else gets recorded there? my bet is it is running out of space.
Only this and same filename every time. So id should not run out of space.
When i do a openhab service restart, the tmpfs will be untouched, i think? Because after that it works again for some time.
When i do a whole server reboot, tmpfs will be cleard, but with only a openhab-service reboot, i think it will not be cleared?
I did the tmpfs thing like you described it in your docs, with 20mb.
Now i changed it to 100mb - i will have a look if this caused the problem. My gifs are only about 4mb each, i always use the same gif-name. So i normally 20mb should be enough. I will tryâŚ
The idea was to be able to enable/disables several IVS rules.
What is include into âCrossLineDetection alarm on/offâ is only about the first rule and not the next(s).
I used a workaround in using only one IVS rule.
I will propose something into the github repo later.
correct it should only clear when you reboot. I would run in DEBUG log mode as that should tell you any errors from FFmpeg without flooding the logs too much.
After a few days pause from this I did some further testing.
The camera Reolink C1 PRO, does NOT have a snapshot URL, even though it is given in the ONVIF response. So resorting to ffmpeg is the only option with the current firmware (Nov. 02).
A thing definition like below works fine for me.
Thing ipcamera:onvif:Reolink "Reolink C1 PRO" @ "camera"
ipAddress="192.168.x.y",
username="un",
password="pw",
updateImageWhen=0,
serverPort=10053,
onvifPort=8000,
ptzContinuous=true,
ffmpegOutput="/var/lib/openhab2/camera/camera3/",
ffmpegInput="rtsp://192.168.x.y:554/h264Preview_01_main",
snapshotUrl="ffmpeg"
Since I have an NVR (Hikvision DS-7616NI-K2) that handles both video and images (snapshots) as well as full PTZ for this camera, it would make sense to go via the NVR - since it is continuously recording anyway.
Snapshots and video are working great that route.
However, I am unsuccessful getting the PTZ to function via the NVR and the binding.
Has anyone managed to get PTZ via an Hikvision NVR to function with the binding? I am grateful for any pointers in the right directionâŚ
Just bought 2 Amcrest IP2M-841B-V3.
I added one to openHAB 2.5.9 as Dahua, as mentioned above.
I can see a snapshot image in PaperUI/Control.
Pan/Tilt does not work, at least not with the dimmers in PaperUI. Log:
2020-11-11 18:53:07.044 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:AbsoluteMove
2020-11-11 18:53:07.127 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:AbsoluteMoveResponse/></s:Body></s:Envelope>
I guess, it does not support absolute move.
GotoPreset with a non-existing preset throws Exception:
pcamera.internal.handler.IpCameraHandler@7dee4654': Index: 1, Size: 1
java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.LinkedList.checkElementIndex(LinkedList.java:555) ~[?:1.8.0_202]
at java.util.LinkedList.get(LinkedList.java:476) ~[?:1.8.0_202]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.getXml(OnvifConnection.java:280) ~[?:?]
Going to an existing preset just does nothing. Tried with PaperUI and rule sending command â1â to the gotoPreset channel. Log:
2020-11-11 18:50:56.639 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GotoPreset
2020-11-11 18:50:56.690 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GotoPresetResponse/></s:Body></s:Envelope>
REFRESH to the gotoPreset channel:
2020-11-11 19:00:14.543 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2020-11-11 19:00:14.596 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetPresetsResponse><tptz:Preset token="1"><tt:Name>Preset1</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.88838526912181304" y="0.28192771084337354"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset><tptz:Preset token="2"><tt:Name>Preset2</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.98866855524079322" y="-0.77831325301204812"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset></tptz:GetPresetsResponse></s:Body></s:Envelope>
2020-11-11 19:00:14.596 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:1
2020-11-11 19:00:14.596 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:2
Using Android app tinyCam PRO, PTZ and presets work. Should I switch to type Amcrest for the binding?
No they are indentical in all ways except the alarm stream VS polling. So if alarms are working I would not change as it wont make a difference.
V3 binding has some changes in this area waiting to be merged which also includes the names of your presets show up as what you name them, but thanks for reporting it.
Did you try the presets after doing that? Either you need to send this command or restart the binding/openHAB whenever you create or change the presets. It may be that the camera has an issue when first connecting with ONVIF, if you can send the full handshake of around 10 onvif messages when it first connects that will allow me to look for any issues. The best app to test with is âonvif device managerâ because it supports all 4 of the movement methods and you can switch between them to see what works and does not.
@Daniel_Linder Can you move the camera if you connect it directly and not through the NVR?
Yes, I tried gotoPreset after refresh and even after restart of openHAB.
I tested with onvif device manager and it supports relative and cont PTZ, but not absolute.
So, when I send INCREASE to the dimmer, it works. PTZ solved.
I also captured what ODM (works) and tinyCam (works) send for gotoPreset and what openHAB (does not work) sends. I removed the Password and Nonce tag/information.
ODM:
POST /onvif/ptz_service HTTP/1.1
Content-Type: application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/GotoPreset"
Host: 192.168.0.2
Content-Length: 987
Accept-Encoding: gzip, deflate
Connection: Close
<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>admin</Username><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">2020-11-12T07:04:30.936Z</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GotoPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>MediaProfile000</ProfileToken><PresetToken>1</PresetToken></GotoPreset></s:Body></s:Envelope>
HTTP/1.1 200 OK
Connection: close
Content-Length: 330
openHAB:
charset: utf-8
Host: 192.168.0.2
Connection: close
SOAPAction: "http://www.onvif.org/ver20/ptz/wsdl/GotoPreset"
Content-Length: 1107
<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:a="http://www.w3.org/2005/08/addressing"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>admin</Username><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">2020-11-12T07:06:45.720Z</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GotoPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>MediaProfile000</ProfileToken><PresetToken>1</PresetToken><Speed><PanTilt x="0.0" y="0.0" space=""></PanTilt><Zoom x="0.0" space=""></Zoom></Speed></GotoPreset></s:Body></s:Envelope>
HTTP/1.1 200 OK
Connection: close
Content-Length: 330
tinyCam:
GET /cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=1&arg3=0&arg4=0 HTTP/1.1
User-Agent: Android/10 (Mi 9T Pro) com.alexvas.dvr.pro
Authorization: Digest username="admin", realm="Login to 793623846d3c1ae527c898c9300de054", nonce=".................", uri="/cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=1&arg3=0&arg4=0", response="2f335039f909b212b1abfe370158b111", qop=auth, nc=00000001, cnonce=".................", algorithm=MD5, opaque="8b673a71910181e540e5e1c0b075d23674d18ffd"
Host: 192.168.0.2
Connection: Keep-Alive
This is the log for adding the camera to openHAB (manual mode, auto discover did not find it):
2020-11-12 08:33:39.573 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GotoPreset
2020-11-12 08:33:39.607 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GotoPresetResponse/></s:Body></s:Envelope>
2020-11-12 08:33:40.745 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GotoPreset
2020-11-12 08:33:40.777 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GotoPresetResponse/></s:Body></s:Envelope>
2020-11-12 08:35:35.786 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2020-11-12 08:35:35.805 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Header/><s:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>Manual</tt:DateTimeType><tt:DaylightSavings>false</tt:DaylightSavings><tt:TimeZone><tt:TZ>GMT+01:00</tt:TZ></tt:TimeZone><tt:UTCDateTime><tt:Time><tt:Hour>7</tt:Hour><tt:Minute>35</tt:Minute><tt:Second>41</tt:Second></tt:Time><tt:Date><tt:Year>2020</tt:Year><tt:Month>11</tt:Month><tt:Day>12</tt:Day></tt:Date></tt:UTCDateTime><tt:LocalDateTime><tt:Time><tt:Hour>8</tt:Hour><tt:Minute>35</tt:Minute><tt:Second>41</tt:Second></tt:Time><tt:Date><tt:Year>2020</tt:Year><tt:Month>11</tt:Month><tt:Day>12</tt:Day></tt:Date></tt:LocalDateTime></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></s:Body></s:Envelope>
2020-11-12 08:35:35.805 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2020-11-12 08:35:35.839 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Header/><s:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Analytics><tt:XAddr>http://192.168.0.18/onvif/analytics_service</tt:XAddr><tt:RuleSupport>true</tt:RuleSupport><tt:AnalyticsModuleSupport>true</tt:AnalyticsModuleSupport></tt:Analytics><tt:Device><tt:XAddr>http://192.168.0.18/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:ZeroConfiguration>false</tt:ZeroConfiguration><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS><tt:Extension><tt:Dot11Configuration>false</tt:Dot11Configuration></tt:Extension></tt:Network><tt:System><tt:DiscoveryResolve>false</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>true</tt:SystemLogging><tt:FirmwareUpgrade>true</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>0</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>10</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>20</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>30</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>40</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>42</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>16</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:Extension><tt:HttpFirmwareUpgrade>true</tt:HttpFirmwareUpgrade><tt:HttpSystemBackup>false</tt:HttpSystemBackup><tt:HttpSystemLogging>false</tt:HttpSystemLogging><tt:HttpSupportInformation>false</tt:HttpSupportInformation></tt:Extension></tt:System><tt:IO><tt:InputConnectors>0</tt:InputConnectors><tt:RelayOutputs>0</tt:RelayOutputs><tt:Extension><tt:Auxiliary>false</tt:Auxiliary><tt:AuxiliaryCommands></tt:AuxiliaryCommands><tt:Extension></tt:Extension></tt:Extension></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken><tt:Extension><tt:TLS1.0>false</tt:TLS1.0><tt:Extension><tt:Dot1X>false</tt:Dot1X><tt:SupportedEAPMethod>0</tt:SupportedEAPMethod><tt:RemoteUserHandling>false</tt:RemoteUserHandling></tt:Extension></tt:Extension></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.0.18/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.0.18/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.0.18/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>true</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>6</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:PTZ><tt:XAddr>http://192.168.0.18/onvif/ptz_service</tt:XAddr></tt:PTZ><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.0.18/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>1</tt:AudioSources><tt:AudioOutputs>1</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs></tt:DeviceIO><tt:Extensions><tt:TelexCapabilities><tt:XAddr>http://192.168.0.18/onvif/telecom_service</tt:XAddr><tt:TimeOSDSupport>true</tt:TimeOSDSupport><tt:TitleOSDSupport>true</tt:TitleOSDSupport><tt:PTZ3DZoomSupport>true</tt:PTZ3DZoomSupport><tt:PTZAuxSwitchSupport>true</tt:PTZAuxSwitchSupport><tt:MotionDetectorSupport>true</tt:MotionDetectorSupport><tt:TamperDetectorSupport>true</tt:TamperDetectorSupport></tt:TelexCapabilities></tt:Extensions></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></s:Body></s:Envelope>
2020-11-12 08:35:35.841 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetProfiles
2020-11-12 08:35:35.897 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetProfilesResponse><trt:Profiles token="MediaProfile000" fixed="true"><tt:Name>MediaProfile_Channel1_MainStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"/></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="000"><tt:Name>VideoEncoderConfig_Channel1_MainStream</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>1920</tt:Width><tt:Height>1080</tt:Height></tt:Resolution><tt:Quality>4.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>30</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>4096</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>60</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.0</tt:IPv4Address></tt:Address><tt:Port>40000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioEncoderConfig_Channel1_MainStream</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.0</tt:IPv4Address></tt:Address><tt:Port>40002</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>AnalyticsConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Name="MyCellMotion" Type="tt:CellMotionEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="60"/><tt:ElementItem Name="Layout"><tt:CellLayout Columns="22" Rows="18"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule><tt:AnalyticsModule Name="MyTamper" Type="tt:TamperEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="48"/><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem><tt:ElementItem Name="Transformation"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Name="Region1" Type="tt:CellMotionDetector"><tt:Parameters><tt:SimpleItem Name="MinCount" Value="20"/><tt:SimpleItem Name="AlarmOnDelay" Value="1000"/><tt:SimpleItem Name="AlarmOffDelay" Value="1000"/><tt:SimpleItem Name="ActiveCells" Value="0P8A8A=="/></tt:Parameters></tt:Rule><tt:Rule Name="MyTamperDetector" Type="tt:TamperDetector"><tt:Parameters><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>10</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000" CompressionType=""><tt:Name>MetadataConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration><tt:Extension><tt:AudioOutputConfiguration token="000"><tt:Name>AudioOutputConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:OutputToken>000</tt:OutputToken><tt:SendPrimacy>www.onvif.org/ver20/HalfDuplex/Auto</tt:SendPrimacy><tt:OutputLevel>50</tt:OutputLevel></tt:AudioOutputConfiguration><tt:AudioDecoderConfiguration token="000"><tt:Name>AudioDecoderConfig_Channel1</tt:Name><tt:UseCount>1</tt:UseCount></tt:AudioDecoderConfiguration></tt:Extension></trt:Profiles><trt:Profiles token="MediaProfile001" fixed="true"><tt:Name>MediaProfile_Channel1_SubStream1</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"/></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="001"><tt:Name>VideoEncoderConfig_Channel1_SubStream1</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>480</tt:Height></tt:Resolution><tt:Quality>4.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>30</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>512</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>60</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.1</tt:IPv4Address></tt:Address><tt:Port>40008</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="001"><tt:Name>AudioEncoderConfig_Channel1_SubStream1</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.1</tt:IPv4Address></tt:Address><tt:Port>40010</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>AnalyticsConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Name="MyCellMotion" Type="tt:CellMotionEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="60"/><tt:ElementItem Name="Layout"><tt:CellLayout Columns="22" Rows="18"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule><tt:AnalyticsModule Name="MyTamper" Type="tt:TamperEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="48"/><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem><tt:ElementItem Name="Transformation"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Name="Region1" Type="tt:CellMotionDetector"><tt:Parameters><tt:SimpleItem Name="MinCount" Value="20"/><tt:SimpleItem Name="AlarmOnDelay" Value="1000"/><tt:SimpleItem Name="AlarmOffDelay" Value="1000"/><tt:SimpleItem Name="ActiveCells" Value="0P8A8A=="/></tt:Parameters></tt:Rule><tt:Rule Name="MyTamperDetector" Type="tt:TamperDetector"><tt:Parameters><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>10</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000" CompressionType=""><tt:Name>MetadataConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration><tt:Extension><tt:AudioOutputConfiguration token="000"><tt:Name>AudioOutputConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:OutputToken>000</tt:OutputToken><tt:SendPrimacy>www.onvif.org/ver20/HalfDuplex/Auto</tt:SendPrimacy><tt:OutputLevel>50</tt:OutputLevel></tt:AudioOutputConfiguration></tt:Extension></trt:Profiles></trt:GetProfilesResponse></s:Body></s:Envelope>
2020-11-12 08:35:35.897 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:MediaProfile000
2020-11-12 08:35:35.897 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:MediaProfile001
2020-11-12 08:35:35.898 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSnapshotUri
2020-11-12 08:35:35.898 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStreamUri
2020-11-12 08:35:35.900 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetNodes
2020-11-12 08:35:35.969 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://192.168.0.18/onvifsnapshot/media_service/snapshot?channel=1&subtype=0</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT0S</tt:Timeout></trt:MediaUri></trt:GetSnapshotUriResponse></s:Body></s:Envelope>
2020-11-12 08:35:35.992 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetNodesResponse><tptz:PTZNode FixedHomePosition="false" GeoMove="false" token="000"><tt:Name>PTZNode_Channel1</tt:Name><tt:SupportedPTZSpaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationSpaceFov</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocitySpaceDegrees</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:SupportedPTZSpaces><tt:MaximumNumberOfPresets>25</tt:MaximumNumberOfPresets><tt:HomeSupported>true</tt:HomeSupported><tt:Extension><tt:SupportedPresetTour><tt:MaximumNumberOfPresetTours>8</tt:MaximumNumberOfPresetTours><tt:PTZPresetTourOperation>Start</tt:PTZPresetTourOperation><tt:PTZPresetTourOperation>Stop</tt:PTZPresetTourOperation><tt:PTZPresetTourOperation>Pause</tt:PTZPresetTourOperation></tt:SupportedPresetTour></tt:Extension></tptz:PTZNode></tptz:GetNodesResponse></s:Body></s:Envelope>
2020-11-12 08:35:35.992 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStatus
2020-11-12 08:35:35.996 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurations
2020-11-12 08:35:36.002 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://192.168.0.18:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT0S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></s:Body></s:Envelope>
2020-11-12 08:35:36.053 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>10</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></s:Body></s:Envelope>
2020-11-12 08:35:36.053 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2020-11-12 08:35:36.055 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurationOptions
2020-11-12 08:35:36.055 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:Position><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.15977337110481571" y="0.28192771084337354"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.0078125"/></tt:Position><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>2020-11-12T07:35:41Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></s:Body></s:Envelope>
2020-11-12 08:35:36.101 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetPresetsResponse><tptz:Preset token="1"><tt:Name>Preset1</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.88838526912181304" y="0.28192771084337354"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset><tptz:Preset token="2"><tt:Name>Preset2</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.98866855524079322" y="-0.77831325301204812"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset></tptz:GetPresetsResponse></s:Body></s:Envelope>
2020-11-12 08:35:36.101 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:1
2020-11-12 08:35:36.101 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:2
2020-11-12 08:35:36.104 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativePanTiltTranslationSpacemythtv@backend ~/openHAB $
One reviewer at Amazon noted that some things are not working anymore with 3rd party software for Amcrest cameras after the newest firmware update. Do you have the newest firmware on your Amcrest?
However, gotoPreset works with ODM and tinyCam PRO.
BTW, I also get this exception when openHAB starts:
2020-11-12 07:39:13.850 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:57) ~[?:?]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:42) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.handleCommand(IpCameraHandler.java:1158) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.channelLinked(BaseThingHandler.java:191) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:267) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_202]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_202]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_202]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_202]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_202]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_202]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_202]
A few quick comments.
- Tinycam is using the API for amcrest and not ONVIF and hence it can not be compared.
- Your logs do not make sense, I suspect you have an old JAR in your system as the output does not match what the current code should give.
- Use this jar as it contains a fix for recording to GIF that is not in the merged 2.5.x version
http://www.pcmus.com/openhab/IpCameraBinding/ipcamera-2020-09-22.zip - Clean your cache and tmp to clear out any traces of old jars after putting the above unzipped contents into the addons folder. After this your log on connection should look different and include the date and time of both the openhab server and also the camera.
- I have read a single Amcrest user on the Home Assistant forum complain about the latest firmwares. I use a non V3 version of your camera with the latest and have no issues, but they could be based on different code as Absolute PTZ works here on mine.
- I did get some issues after I last updated my Amcrest firmware and it was fixed after I read and followed the important advice in the readme for the update. This was it needs a factory reset after the update to wipe all settings. After doing that I have no known issues. It makes me wonder if point 5 above is caused by not reading and following the readme.
- Re error on startup. This could be related to points 2 and 4 above. When you manually add a camera I would recommend you delete and re-add if AFTER doing the cache and tmp clean.
- If the above does not solve it, then how long before you move to openHAB V3 as any fixes will only be made for that from now on.
- Did you see the difference in the HTTP request between openHAB and ODM that I wrote?
- I did have standard openHAB 2.5.9.
- Uninstalled the 2.5.9 binding, cleared cache and tmp and installed this version. Now, gotoPreset was no combo box anymore in PaperUI Control after the first try to add the camera. On 2nd try (again cache and tmp cleared), the combo box is there again. Sending 1 to the item still does not have any effect.
- Done.
- Still absolute does not work. Sending INCREASE still works.
- There was no readme. However, I did do a firmware reset now.
- The binding still does not auto discover the camera (ODM does).
- I will move to V3 when itâs final. We could to tests with the 2.5.9 snapshot binding version, so that it is fixed for V3.
Log from manually adding with the snapshot binding and resetted camera:
2020-11-12 10:38:27.062 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2020-11-12 10:38:27.159 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Header/><s:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>Manual</tt:DateTimeType><tt:DaylightSavings>false</tt:DaylightSavings><tt:TimeZone><tt:TZ>GMT-06:00</tt:TZ></tt:TimeZone><tt:UTCDateTime><tt:Time><tt:Hour>16</tt:Hour><tt:Minute>38</tt:Minute><tt:Second>32</tt:Second></tt:Time><tt:Date><tt:Year>2020</tt:Year><tt:Month>11</tt:Month><tt:Day>12</tt:Day></tt:Date></tt:UTCDateTime><tt:LocalDateTime><tt:Time><tt:Hour>10</tt:Hour><tt:Minute>38</tt:Minute><tt:Second>32</tt:Second></tt:Time><tt:Date><tt:Year>2020</tt:Year><tt:Month>11</tt:Month><tt:Day>12</tt:Day></tt:Date></tt:LocalDateTime></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.160 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2020-11-12 10:38:27.255 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Header/><s:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Analytics><tt:XAddr>http://192.168.0.18/onvif/analytics_service</tt:XAddr><tt:RuleSupport>true</tt:RuleSupport><tt:AnalyticsModuleSupport>true</tt:AnalyticsModuleSupport></tt:Analytics><tt:Device><tt:XAddr>http://192.168.0.18/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:ZeroConfiguration>false</tt:ZeroConfiguration><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS><tt:Extension><tt:Dot11Configuration>false</tt:Dot11Configuration></tt:Extension></tt:Network><tt:System><tt:DiscoveryResolve>false</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>true</tt:SystemLogging><tt:FirmwareUpgrade>true</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>0</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>10</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>20</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>30</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>40</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>42</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>16</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:Extension><tt:HttpFirmwareUpgrade>true</tt:HttpFirmwareUpgrade><tt:HttpSystemBackup>false</tt:HttpSystemBackup><tt:HttpSystemLogging>false</tt:HttpSystemLogging><tt:HttpSupportInformation>false</tt:HttpSupportInformation></tt:Extension></tt:System><tt:IO><tt:InputConnectors>0</tt:InputConnectors><tt:RelayOutputs>0</tt:RelayOutputs><tt:Extension><tt:Auxiliary>false</tt:Auxiliary><tt:AuxiliaryCommands></tt:AuxiliaryCommands><tt:Extension></tt:Extension></tt:Extension></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken><tt:Extension><tt:TLS1.0>false</tt:TLS1.0><tt:Extension><tt:Dot1X>false</tt:Dot1X><tt:SupportedEAPMethod>0</tt:SupportedEAPMethod><tt:RemoteUserHandling>false</tt:RemoteUserHandling></tt:Extension></tt:Extension></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.0.18/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.0.18/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.0.18/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>true</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>6</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:PTZ><tt:XAddr>http://192.168.0.18/onvif/ptz_service</tt:XAddr></tt:PTZ><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.0.18/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>1</tt:AudioSources><tt:AudioOutputs>1</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs></tt:DeviceIO><tt:Extensions><tt:TelexCapabilities><tt:XAddr>http://192.168.0.18/onvif/telecom_service</tt:XAddr><tt:TimeOSDSupport>true</tt:TimeOSDSupport><tt:TitleOSDSupport>true</tt:TitleOSDSupport><tt:PTZ3DZoomSupport>true</tt:PTZ3DZoomSupport><tt:PTZAuxSwitchSupport>true</tt:PTZAuxSwitchSupport><tt:MotionDetectorSupport>true</tt:MotionDetectorSupport><tt:TamperDetectorSupport>true</tt:TamperDetectorSupport></tt:TelexCapabilities></tt:Extensions></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.265 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetProfiles
2020-11-12 10:38:27.350 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetProfilesResponse><trt:Profiles token="MediaProfile000" fixed="true"><tt:Name>MediaProfile_Channel1_MainStream</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"/></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="000"><tt:Name>VideoEncoderConfig_Channel1_MainStream</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>1920</tt:Width><tt:Height>1080</tt:Height></tt:Resolution><tt:Quality>4.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>30</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>4096</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>60</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.0</tt:IPv4Address></tt:Address><tt:Port>40000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="000"><tt:Name>AudioEncoderConfig_Channel1_MainStream</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.0</tt:IPv4Address></tt:Address><tt:Port>40002</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>AnalyticsConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Name="MyCellMotion" Type="tt:CellMotionEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="60"/><tt:ElementItem Name="Layout"><tt:CellLayout Columns="22" Rows="18"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule><tt:AnalyticsModule Name="MyTamper" Type="tt:TamperEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="48"/><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem><tt:ElementItem Name="Transformation"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Name="Region1" Type="tt:CellMotionDetector"><tt:Parameters><tt:SimpleItem Name="MinCount" Value="20"/><tt:SimpleItem Name="AlarmOnDelay" Value="1000"/><tt:SimpleItem Name="AlarmOffDelay" Value="1000"/><tt:SimpleItem Name="ActiveCells" Value="0P8A8A=="/></tt:Parameters></tt:Rule><tt:Rule Name="MyTamperDetector" Type="tt:TamperDetector"><tt:Parameters><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000" CompressionType=""><tt:Name>MetadataConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration><tt:Extension><tt:AudioOutputConfiguration token="000"><tt:Name>AudioOutputConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:OutputToken>000</tt:OutputToken><tt:SendPrimacy>www.onvif.org/ver20/HalfDuplex/Auto</tt:SendPrimacy><tt:OutputLevel>50</tt:OutputLevel></tt:AudioOutputConfiguration><tt:AudioDecoderConfiguration token="000"><tt:Name>AudioDecoderConfig_Channel1</tt:Name><tt:UseCount>1</tt:UseCount></tt:AudioDecoderConfiguration></tt:Extension></trt:Profiles><trt:Profiles token="MediaProfile001" fixed="true"><tt:Name>MediaProfile_Channel1_SubStream1</tt:Name><tt:VideoSourceConfiguration token="000"><tt:Name>VideoSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken><tt:Bounds x="0" y="0" width="2048" height="1536"/></tt:VideoSourceConfiguration><tt:AudioSourceConfiguration token="000"><tt:Name>AudioSourceConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>000</tt:SourceToken></tt:AudioSourceConfiguration><tt:VideoEncoderConfiguration token="001"><tt:Name>VideoEncoderConfig_Channel1_SubStream1</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>480</tt:Height></tt:Resolution><tt:Quality>4.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>30</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>512</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>60</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.1</tt:IPv4Address></tt:Address><tt:Port>40008</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:AudioEncoderConfiguration token="001"><tt:Name>AudioEncoderConfig_Channel1_SubStream1</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>AAC</tt:Encoding><tt:Bitrate>64</tt:Bitrate><tt:SampleRate>16</tt:SampleRate><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.0.1</tt:IPv4Address></tt:Address><tt:Port>40010</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:AudioEncoderConfiguration><tt:VideoAnalyticsConfiguration token="000"><tt:Name>AnalyticsConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:AnalyticsEngineConfiguration><tt:AnalyticsModule Name="MyCellMotion" Type="tt:CellMotionEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="60"/><tt:ElementItem Name="Layout"><tt:CellLayout Columns="22" Rows="18"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:CellLayout></tt:ElementItem></tt:Parameters></tt:AnalyticsModule><tt:AnalyticsModule Name="MyTamper" Type="tt:TamperEngine"><tt:Parameters><tt:SimpleItem Name="Sensitivity" Value="48"/><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem><tt:ElementItem Name="Transformation"><tt:Transformation><tt:Translate x="-1" y="-1"/><tt:Scale x="0.0062500000000000003" y="0.0083400000000000002"/></tt:Transformation></tt:ElementItem></tt:Parameters></tt:AnalyticsModule></tt:AnalyticsEngineConfiguration><tt:RuleEngineConfiguration><tt:Rule Name="Region1" Type="tt:CellMotionDetector"><tt:Parameters><tt:SimpleItem Name="MinCount" Value="20"/><tt:SimpleItem Name="AlarmOnDelay" Value="1000"/><tt:SimpleItem Name="AlarmOffDelay" Value="1000"/><tt:SimpleItem Name="ActiveCells" Value="0P8A8A=="/></tt:Parameters></tt:Rule><tt:Rule Name="MyTamperDetector" Type="tt:TamperDetector"><tt:Parameters><tt:ElementItem Name="Field"><tt:PolygonConfiguration><tt:Polygon><tt:Point x="0" y="240"/><tt:Point x="0" y="0"/><tt:Point x="320" y="0"/><tt:Point x="320" y="240"/></tt:Polygon></tt:PolygonConfiguration></tt:ElementItem></tt:Parameters></tt:Rule></tt:RuleEngineConfiguration></tt:VideoAnalyticsConfiguration><tt:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tt:PTZConfiguration><tt:MetadataConfiguration token="000" CompressionType=""><tt:Name>MetadataConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:RuleEngine/CellMotionDetector/Motion</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.2.0.0</tt:IPv4Address></tt:Address><tt:Port>40020</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration><tt:Extension><tt:AudioOutputConfiguration token="000"><tt:Name>AudioOutputConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:OutputToken>000</tt:OutputToken><tt:SendPrimacy>www.onvif.org/ver20/HalfDuplex/Auto</tt:SendPrimacy><tt:OutputLevel>50</tt:OutputLevel></tt:AudioOutputConfiguration></tt:Extension></trt:Profiles></trt:GetProfilesResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.351 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:MediaProfile000
2020-11-12 10:38:27.351 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:MediaProfile001
2020-11-12 10:38:27.351 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSnapshotUri
2020-11-12 10:38:27.353 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStreamUri
2020-11-12 10:38:27.360 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetNodes
2020-11-12 10:38:27.443 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetSnapshotUriResponse><trt:MediaUri><tt:Uri>http://192.168.0.18/onvifsnapshot/media_service/snapshot?channel=1&subtype=0</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT0S</tt:Timeout></trt:MediaUri></trt:GetSnapshotUriResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.462 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetNodesResponse><tptz:PTZNode FixedHomePosition="false" GeoMove="false" token="000"><tt:Name>PTZNode_Channel1</tt:Name><tt:SupportedPTZSpaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationSpaceFov</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocitySpaceDegrees</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:SupportedPTZSpaces><tt:MaximumNumberOfPresets>25</tt:MaximumNumberOfPresets><tt:HomeSupported>true</tt:HomeSupported><tt:Extension><tt:SupportedPresetTour><tt:MaximumNumberOfPresetTours>8</tt:MaximumNumberOfPresetTours><tt:PTZPresetTourOperation>Start</tt:PTZPresetTourOperation><tt:PTZPresetTourOperation>Stop</tt:PTZPresetTourOperation><tt:PTZPresetTourOperation>Pause</tt:PTZPresetTourOperation></tt:SupportedPresetTour></tt:Extension></tptz:PTZNode></tptz:GetNodesResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.463 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStatus
2020-11-12 10:38:27.464 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurations
2020-11-12 10:38:27.478 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:trt="http://www.onvif.org/ver10/media/wsdl"><s:Header/><s:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://192.168.0.18:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT0S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.523 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetConfigurationsResponse><tptz:PTZConfiguration token="000" MoveRamp="0" PresetRamp="0" PresetTourRamp="0"><tt:Name>PTZConfig_Channel1</tt:Name><tt:UseCount>2</tt:UseCount><tt:NodeToken>000</tt:NodeToken><tt:DefaultAbsolutePantTiltPositionSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:DefaultAbsolutePantTiltPositionSpace><tt:DefaultAbsoluteZoomPositionSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:DefaultAbsoluteZoomPositionSpace><tt:DefaultRelativePanTiltTranslationSpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:DefaultRelativePanTiltTranslationSpace><tt:DefaultRelativeZoomTranslationSpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:DefaultRelativeZoomTranslationSpace><tt:DefaultContinuousPanTiltVelocitySpace>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:DefaultContinuousPanTiltVelocitySpace><tt:DefaultContinuousZoomVelocitySpace>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:DefaultContinuousZoomVelocitySpace><tt:DefaultPTZSpeed><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace" x="0.80000001192092896" y="0.80000001192092896"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace" x="0.80000001192092896"/></tt:DefaultPTZSpeed><tt:DefaultPTZTimeout>PT10S</tt:DefaultPTZTimeout><tt:PanTiltLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:Range></tt:PanTiltLimits><tt:ZoomLimits><tt:Range><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:Range></tt:ZoomLimits></tptz:PTZConfiguration></tptz:GetConfigurationsResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.524 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2020-11-12 10:38:27.527 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetConfigurationOptions
2020-11-12 10:38:27.555 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetStatusResponse><tptz:PTZStatus><tt:Position><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.059490084985835745" y="-1.0409638554216865"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.0078125"/></tt:Position><tt:MoveStatus><tt:PanTilt>IDLE</tt:PanTilt><tt:Zoom>IDLE</tt:Zoom></tt:MoveStatus><tt:UtcTime>2020-11-12T16:38:32Z</tt:UtcTime></tptz:PTZStatus></tptz:GetStatusResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.613 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetConfigurationOptionsResponse><tptz:PTZConfigurationOptions><tt:Spaces><tt:AbsolutePanTiltPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:AbsolutePanTiltPositionSpace><tt:AbsoluteZoomPositionSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:AbsoluteZoomPositionSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativePanTiltTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/TranslationSpaceFov</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:RelativePanTiltTranslationSpace><tt:RelativeZoomTranslationSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/TranslationGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:RelativeZoomTranslationSpace><tt:ContinuousPanTiltVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange><tt:YRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:YRange></tt:ContinuousPanTiltVelocitySpace><tt:ContinuousZoomVelocitySpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/VelocityGenericSpace</tt:URI><tt:XRange><tt:Min>-1.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ContinuousZoomVelocitySpace><tt:PanTiltSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/PanTiltSpaces/GenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:PanTiltSpeedSpace><tt:ZoomSpeedSpace><tt:URI>http://www.onvif.org/ver10/tptz/ZoomSpaces/ZoomGenericSpeedSpace</tt:URI><tt:XRange><tt:Min>0.000000</tt:Min><tt:Max>1.000000</tt:Max></tt:XRange></tt:ZoomSpeedSpace></tt:Spaces><tt:PTZTimeout><tt:Min>PT1S</tt:Min><tt:Max>PT250S</tt:Max></tt:PTZTimeout></tptz:PTZConfigurationOptions></tptz:GetConfigurationOptionsResponse></s:Body></s:Envelope>
2020-11-12 10:38:27.617 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetPresetsResponse><tptz:Preset token="1"><tt:Name>Preset1</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.95524079320113331" y="0.90361445783132521"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset></tptz:GetPresetsResponse></s:Body></s:E
Log from linking the gotoPreset item and sending 1 to it:
2020-11-12 10:42:42.538 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetPresets
2020-11-12 10:42:42.566 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GetPresetsResponse><tptz:Preset token="1"><tt:Name>Preset1</tt:Name><tt:PTZPosition><tt:PanTilt space="http://www.onvif.org/ver10/tptz/PanTiltSpaces/PositionGenericSpace" x="-0.95524079320113331" y="0.90361445783132521"/><tt:Zoom space="http://www.onvif.org/ver10/tptz/ZoomSpaces/PositionGenericSpace" x="0.007874015748031496"/></tt:PTZPosition></tptz:Preset></tptz:GetPresetsResponse></s:Body></s:Envelope>
2020-11-12 10:42:42.567 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:1
2020-11-12 10:43:45.837 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GotoPreset
2020-11-12 10:43:45.863 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"><s:Header/><s:Body><tptz:GotoPresetResponse/></s:Body></s:Envelope>
Just made a quick check with the 2nd camera that still has a slightly older firmware. Same behavior.
Snapshot:
http://192.168.0.7:30001/ipcamera.jpg delivers an OLD snapshot image from hours ago. Is this using the native snapshot URL or ffmpeg? <- SOLVED, bug in the camera, have to set snapshot quality to 4 instead of 5, then it works for a while, until it does not anymore. The native snapshot url of the camera returns a HTTP 500 when it happens.
MJPEG stream:
I have set the sub stream to mpjeg and http://192.168.0.7:30001/ipcamera.mjpeg delivers this stream nicely, but it has lower quality (from the camera itself).
HLS stream:
For HLS, I have to enter the rtsp url (rtsp://192.168.0.18:554/cam/realmonitor?channel=1&subtype=0) in the camera thing config. I thought, it would auto discover that. Then, the browser wants to download files when I enter http://192.168.0.7:30001/ipcamera.m3u8. However, this does not work in your Habpanel widget. I can see a 404 for the URL http://192.168.0.7:8090/habpanel/{{config.stream_url}} in the browser console log.
GIF:
ipcamera.gif does not work, I see no ffmpeg related output in the log besides this:
2020-11-12 17:28:31.932 [DEBUG] [pcamera.internal.StreamServerHandler] - Stream Server recieved request GET:/ipcamera.gif
2020-11-12 17:28:31.932 [INFO ] [pcamera.internal.StreamServerHandler] - IpCameras file server could not find the requested file. This may happen if ffmpeg is still creating the file.
I have full control of the camera, if I add it directly, except the fact that it doesnât have snapshot functionality. Via the NVR it is the opposite. Snapshots, but no Ptz.
Did you remove all the DEBUG lines from the log? That is what is making it look different, all lines from the log in TRACE are important including the DEBUG ones and They greatly speed up finding any issues.
Letâs look at only one thing at a time and working out if there is a handshake issue is number one as any issues in there will effect the preset moving and auto detection of URLs and more.
Discovery is done with UDP and it can be a droppped packet causing it, doing multiple scans may be needed to find a camera. I may have made it search 3 times in a single scan in the V3 version.
V3 is already better than V2 and if you have spare time it is worth moving over now. I doubt I will be making massive changes to V2 jar files now the two have already moved apart plus I really need to be finalising code now for it to get merged in time for stable as there is a delay.
Gif needs to be recorded first before you can request it.
Is the channel
{ channel="ipcamera:dahua:CamEingang:updateGif" }
in the items-file still in use? I used this since the old binding, now i´m on 2.5.9 with recording-gif-fix from 09_22. But i can´t find it in the docs anymore.
See here, you have to use an Action now:
