So should I restart binding to get that? I send whatever I have spotted in logs. I guess I do I will try in a second.
I have the newest firmware. I havenât contacted support as yet. I will tryâŠ
EDIT: This is (end of) trace after restart and first request for snapshot:
2021-11-28 14:05:17.076 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : For dependency $002, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.jsp.ie.classid=clsid:8AD9C840-044E-11D1-B3E9-00805F499D93, org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.clientauthneeded=false, service.scope=bundle, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.suffix=), felix.fileinstall.filename=file:/var/lib/openhab/etc/org.ops4j.pax.web.cfg, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.jsp.java.encoding=UTF-8, service.pid=org.ops4j.pax.web, org.ops4j.pax.web.jsp.enable.pooling=true, org.ops4j.pax.web.jsp.log.verbosity.level=WARNING, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, org.ops4j.pax.web.jsp.mapped.file=false, service.id=165, org.ops4j.pax.web.session.cookie=JSESSIONID, org.osgi.service.http.port=8080, org.ops4j.pax.web.jsp.tagpool.max.size=5, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.log.ncsa.dispatch=false, org.ops4j.pax.web.enc.algorithm=PBEWithMD5AndDES, org.ops4j.pax.webssl.cyphersuites.included=[], org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.log.ncsa.format=yyyy_mm_dd.request.log, org.ops4j.pax.web.jsp.keep.generated=true, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.config.file=/usr/share/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.clientauthwanted=false, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.jsp.precompilation=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/var/lib/openhab/tmp/.paxweb4066533524566162522, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.session.timeout=10, service.bundleid=224, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.jsp.check.interval=300, org.ops4j.pax.web.session.cookie.secure=false, org.osgi.service.http.useNIO=true, org.ops4j.pax.webssl.cyphersuites.excluded=[], org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.ssl.keystore=.keystore, org.ops4j.pax.web.jsp.development=true, org.ops4j.pax.web.jsp.debug.info=true, org.ops4j.pax.web.server.showStacks=true}] service: [null]]]
2021-11-28 14:05:17.079 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : getting activate: activate
2021-11-28 14:05:17.079 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Locating method activate in class org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory
2021-11-28 14:05:17.080 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Declared Method org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory.activate([interface org.osgi.service.component.ComponentContext]) not found
2021-11-28 14:05:17.080 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Locating method activate in class org.openhab.core.thing.binding.BaseThingHandlerFactory
2021-11-28 14:05:17.081 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Found activate method: protected void org.openhab.core.thing.binding.BaseThingHandlerFactory.activate(org.osgi.service.component.ComponentContext)
2021-11-28 14:05:17.081 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.manager.ComponentContextImpl]
2021-11-28 14:05:17.082 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : invoked activate: activate
2021-11-28 14:05:17.082 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Set implementation object for component
2021-11-28 14:05:17.083 [DEBUG] [mera.internal.IpCameraHandlerFactory] - bundle org.openhab.binding.ipcamera:3.2.0.202110260847 (308)[org.openhab.binding.ipcamera.internal.IpCameraHandlerFactory(361)] : Changed state from satisfied to active
2021-11-28 14:05:17.252 [DEBUG] [notatedThingActionModuleTypeProvider] - bundle org.openhab.core.automation:3.1.0 (158)[org.openhab.core.automation.thingsupport.AnnotatedThingActionModuleTypeProvider(80)] : invoking bind: addAnnotatedThingActions: parameters [org.openhab.binding.ipcamera.internal.IpCameraActions]
2021-11-28 14:05:17.256 [DEBUG] [aultscope.DefaultScriptScopeProvider] - bundle org.openhab.core.automation.module.script:3.1.0 (160)[org.openhab.core.automation.module.script.internal.defaultscope.DefaultScriptScopeProvider(88)] : invoking bind: addThingActions: parameters [org.openhab.binding.ipcamera.internal.IpCameraActions]
2021-11-28 14:05:17.267 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:generic:b566d3a34d' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2021-11-28 14:05:21.400 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.229:8080/live/jpeg
2021-11-28 14:05:21.401 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:generic:b566d3a34d' changed from INITIALIZING to ONLINE
2021-11-28 14:07:47.334 [DEBUG] [amera.internal.servlet.CameraServlet] - GET:/ipcamera.mjpeg, received from 192.168.1.156
2021-11-28 14:07:47.335 [DEBUG] [amera.internal.servlet.CameraServlet] - First stream requested, opening up stream from camera
2021-11-28 14:07:47.345 [TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.229:8080/live/mjpeg
It looks like itâs opening a stream, but there is no size, no end, so the stream doesnât close like you wrote.
