You need to make sure the ONVIF port is 8080. 3 out of my 4 cameras listed the port number in the web admin interface of the camera. Smells like 8080 is not correct for you.
Yes in the Webinterface I can set the ONVIF port.
It is set to 8080.
Thatās why I donāt understand why it is not working
is there a chance to integrate P2P cameras like Freecam L910?
(http://www.lsvt.com.cn/pro_view.asp?dl_id=192&sort_id=203&shop_id=1915)
I now used a external program to check wether PTZ is working or not. And it is working perfectly.
Any suggestion on how to fix my error? Or how to find out why the binding is not capable of it?
2019-10-27 17:53:10.738 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Following NPE occured when trying to connect to the camera with ONVIF.java.lang.NullPointerException
2019-10-27 17:53:10.747 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Since an NPE occured when asking the camera about PTZ, the PTZ controls will not work. If the camera does not come online, give the camera the wrong ONVIF port number so it can bypass using ONVIF and still come online.
EDIT: @matt1 I could identify the issue why PTZ is not working on my camera it does not support the ABSOLUTE setting but it works with RELATIVE and with CONTINUOUS.
EDIT 2: I tried to setup the HLS Straming but I am getting this error:
IpCameras file server could not find the requested file. This may happen if ffmpeg is still creating the file.
How can I fix that one ? FFMPEG is installed and this is how my settings look like in paperui:
Just found my cctv not showing so had a quick look.
Seems the binding is choosing a random network adaptor to use rather than the default openh one in system settings. Any way to manually change?
I canāt create animated GIF (Dahua camera)
23:27:39.123 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'CameraGarageUpdateGif' received command ON
23:27:39.125 [INFO ] [arthome.event.ItemStatePredictedEvent] - CameraGarageUpdateGif predicted to become ON
23:27:39.126 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.ipcamera.handler.IpCameraHandler@7b7a9a1f': null
at org.openhab.binding.ipcamera.handler.IpCameraHandler.setupFfmpegFormat(IpCameraHandler.java:1031) ~[?:?]
at org.openhab.binding.ipcamera.handler.IpCameraHandler.handleCommand(IpCameraHandler.java:1180) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [133:org.openhab.core:2.5.0.M3]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [133:org.openhab.core:2.5.0.M3]
at com.sun.proxy.$Proxy242.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [184:org.openhab.core.thing:2.5.0.M3]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [184:org.openhab.core.thing:2.5.0.M3]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [133:org.openhab.core:2.5.0.M3]
Things :
Thing ipcamera:DAHUA:001 "CamƩra Garage" [ IPADDRESS="192.168.2.200", GIF_PREROLL=0, GIF_POSTROLL=6, PASSWORD="my_pass", USERNAME="admin", UPDATE_IMAGE=false, IMAGE_UPDATE_EVENTS=0, SERVER_PORT=50001, FFMPEG_OUTPUT="/tmp/camera1/", IP_WHITELIST="(192.168.2.2)(192.168.2.100)"]
Yes this high on the list to fix and no there is no manual way to select it. It will choose the first network that passes a āsitelocalā query. ie uses an internal IP address.
Hi Matt
Thanks for the reply.
Not good when I have 4 adaptors running on my nas
Glad itās on your high priority though, any idea on timeframe?
Cheers
I should have time over Christmas break, not sure how it will be handled as I was trying an automated way to select the network with out doing any pings. It may have to be looking in the logs for a list of cards and then entering a number as a config for people that find the auto method to not work. Can you post why there are four cards and how they are setup? It may help to consider your use case when doing this.
Could you add it as a free text box in the thing config much like the stream url override and wait for an adaptor to come up matching this, ie āserver network addressā?
Iām running openhab on a qnap NAS (ts-451), it has 4 adaptors each of which has a local address assigned as follows:
1: 192.168.6.0/24 - normal lan
2: 192.168.20.0/24 - smart home lan (openhab here)
3: 192.168.4.0/24 - cctv
4: 192.168.0.0 - vpn gateway (using qvpn on NAS for certain traffic)
The other trouble is if I was to add a docker image or a vm this creates a virtual adaptor too, which is what the binding chose (10.0.5.0/24), I believe as this was first to have an address as it didnāt have to query dhcp as itās virtual.
hi all, iām trying to use the binding with my ipcamera Shenzhen. i think a bluecam remark.
the camera reply to this command that i found in an other forum.
Identifier: BLUECOM.GMT
Default ip_address: 192.168.1.250
Default user interface credentials: admin/
Default command credentials: admin/admin
nmap -sN -r -n -p-1-65535
(null scan (TCP flag header is 0) , do not randomize, no DNS resolution, all ports)
-O - enable OS detection
nmap port open results:
6554 - tcp (video streams)
8080 - http-proxy
9527 - tcp (command)
On power up the camera first tries to find 192.168.1.1 and then tries to contact:
116.62.7.175 - Beijing Kuancong
13.58.115.239 - amazon.com - USA
35.177.224.169 - amazon.com - Europe
OCX download www.cam158.com
High and low resolution video streams
ip_address:6554/stream-0
ip_address:6554/stream-1
ip-address:6554
Command port (use login user and password ā configuration and control items)
ip_address:9527/index.htm
ip_address:9527/index1.html
ip_address:9527/jpeg.html
ip_address:9527/snapshot.htm
ip_address:9527/status.htm ā Device status
ip_address:9527/ip.htm ā Basic Network Settings - Obtain IP from DHCP Server (uncheck for manual), http port: 9527
ip_address:9527/wireless.htm ā Wireless LAN - Using Wireless Lan (check) - SSID, Authentication
ip_address:9527/ddns.htm ā DDNS Service activation, parameters
ip_address:9527/Onvif.htm ā ONVIF Stream settings āopenā
ip_address:9527/RTSP.htm ā RTSP Stream āopenā - port 10554 (must be wrong, should be 6554)
ip_address:9527/ptz.htm ā PTZ - not available
ip_address:9527/multidev.htm ā Multi-Device Settings (accessible from Internet)
ip_address:9527/user.htm ā Administrator, Operator, Visitor
ip_address:9527/alias.htm ā Alias Settings - IPCAM
ip_address:9527/datetime.htm ā Timezone, NTP Server
ip_address:9527/recordpath.htm ā Local record path - file length, time, reserved space, cover
ip_address:9527/recordsch.htm ā Record schedule SD card format, capacity, recording options, time schedule
ip_address:9527/voice.htm ā Voice setting (Mute, English, Chinese)
ip_address:9527/alarm.htm ā Motion detect, audio detect, mail notification, upload image, arming time schedule
ip_address:9527/mail.htm ā Mail service settings
ip_address:9527/ftp.htm ā FTP service settings
ip_address:9527/log.htm
ip_address:9527/ipc_reboot_dev.cgi?next_url=reboot.htm
ip_address:9527/ipc_reset.cgi?next_url=rebootme.htm
ip_address:9527/upgrade.htm ā Upgrade Device Firmware, Embedded Web UI (Browse)
ip_address:9527/get_ipc_status.cgi
ip_address:9527/ipc_control_video.cgi?loginuse=admin&loginpas=admin¶m=xxxx&value=yyyy
param=18&value=1
param=17&value=1
param=14&value=0 PIR off
param=14&value=1 PIR on
ip_address:9527/ipc_control_ptz.cgi
ip_address:9527/get_ipc_params.cgi
ip_address:9527/get_ipc_encode_params.cgi
ip_address:9527/get_ipc_factory_param.cgi
ip_address:9527/get_ipc_record.cgi
ip_address:9527/videostream.cgi?loginuse=admin&loginpas=admin -
ip_address:9527/snapshot.cgi?loginuse=admin&loginpas=admin - get jpeg image (704x576)
Get a jpeg image (for motion detection)
curl āhttp://192.168.1.250:9527/snapshot.cgi?loginuse=admin&loginpas=adminā -o test.jpeg
get_status.cgi? -> admin/ - reset
login.cgi
get_camera_params.cgi
public.cgi
get_ipc_loginmessage.cgi
jquery/jquery.min.js
public.js
This is my configuration
and this is the openhabās log⦠the camera is online but not images, not moving etcā¦
2019-11-08 10:27:42.701 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Sending camera: GET: http://192.168.0.22/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:42.733 [TRACE] [ipcamera.internal.MyNettyAuthHandler] - MyNettyAuthHandler is now setup for GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:42.739 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Have re-opened the closed channel:0 GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:42.751 [TRACE] [ing.ipcamera.handler.IpCameraHandler] - DefaultHttpResponse(decodeResult: failure(java.lang.IllegalArgumentException: a header name cannot contain the following prohibited characters: =,;: \t\r\n\v\f: ,), version: HTTP/1.1)
HTTP/1.1 200 OK
Server: GoaHead
2019-11-08 10:27:42.802 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - commonCameraHandler closed channel:0 URL:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:47.701 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Sending camera: GET: http://192.168.0.22/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:47.726 [TRACE] [ipcamera.internal.MyNettyAuthHandler] - MyNettyAuthHandler is now setup for GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:47.729 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Have re-opened the closed channel:0 GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:47.739 [TRACE] [ing.ipcamera.handler.IpCameraHandler] - DefaultHttpResponse(decodeResult: failure(java.lang.IllegalArgumentException: a header name cannot contain the following prohibited characters: =,;: \t\r\n\v\f: ,), version: HTTP/1.1)
HTTP/1.1 200 OK
Server: GoaHead
2019-11-08 10:27:47.791 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - commonCameraHandler closed channel:0 URL:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:52.648 [vent.ItemStateChangedEvent] - Azimuth changed from 153.9958881237165 ° to 154.24468189742086 °
2019-11-08 10:27:52.661 [vent.ItemStateChangedEvent] - Elevation changed from 23.964394694529478 ° to 24.04038843790722 °
2019-11-08 10:27:52.670 [vent.ItemStateChangedEvent] - Diffuse_Radiation changed from 105.94218879750758 W/m² to 106.08175261299178 W/m²
2019-11-08 10:27:52.678 [vent.ItemStateChangedEvent] - Total_Radiation changed from 267.8630844990612 W/m² to 269.08593069868414 W/m²
2019-11-08 10:27:52.701 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Sending camera: GET: http://192.168.0.22/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:52.715 [TRACE] [ipcamera.internal.MyNettyAuthHandler] - MyNettyAuthHandler is now setup for GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:52.719 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Have re-opened the closed channel:0 GET:/snapshot.cgi?loginuse=admin&loginpas=admin
2019-11-08 10:27:52.729 [TRACE] [ing.ipcamera.handler.IpCameraHandler] - DefaultHttpResponse(decodeResult: failure(java.lang.IllegalArgumentException: a header name cannot contain the following prohibited characters: =,;: \t\r\n\v\f: ,), version: HTTP/1.1)
HTTP/1.1 200 OK
Server: GoaHead
2019-11-08 10:27:52.781 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - commonCameraHandler closed channel:0 URL:/snapshot.cgi?loginuse=admin&loginpas=admin
What iām wrong? Someone could help me?
HIgher Resolution on SnapShot Images
Iāve been running this binding for a few years now; works fantastic! I have the HIKVision system connected to it and Iād like to get better resolution on the SnapShot image item.
My 8 cameras are setup in PaperUI tied through a NVR.
Is this possible? If so, how?
Best, Jay
Hi. I upgraded to the newest version of the binding and created two things that connect to Hikvision cameras. The resolution of the camera picture is 4K, downloaded picture sizes are around 250k each, update interval 4s. The problem is that after a few hours all java heap is consumed and OH stops working. Also, the ongoing load is above 115% of 4-core RPI (while without the IP camera things it is 15%). Something apparently is consuming memory and CPU time. How can I help to diagnose that?
@ppieczul
You need to turn off the image channel from updating, I find it halves the CPU load and also stops a memory leak. This is covered in the readme for the binding and as it literally turns off 1 line of code that sends the snapshot to the Openhab Image item I am certain this is in the Openhab framework and not the binding. The Image item was never designed to take large pictures changing often.
@jwiseman
Ask HIK support, it will be a change in the cameras settings.
anyone knows if this binding supports the motion detection of Foscam fi9902p? It should right? As I see it, itās the new model of the fi9900P.
Thanks and best regards
Daniel
If the camera has the Foscam HD api implemented then it should work. The older non HD cameras have not been implemented into the binding unless we get a volunteer to do the work. DISCLAIMER: Since I donāt work for foscam you need to do your own research. See the first post of this thread that explains what is implemented for each brand as you may want to purchase a different camera based on what features you need.
Hi, i“m looking for a good cam for my front door. I have seen some cams on aliexpress. dahua ipc-hdw4433c-a has 4MP, 2,8mm lens and an angle of view of 81°.
Another cam, KingCam cam with 4MP has 2,8mm lens too, but angle of view is 120°.
(disadvantage, it doesnĀ“t provide mjpeg stream, only h264/h265. So not easy to use in openhabā¦)
Can somebody tell me, why the difference in angle of view is so big - even with the same lens?
Anybody knows the dahua cam? Is the angle of view really only 81° with the 2,8mm lens?
If you want the ability to trigger a door latch to remote open the door or to use the cameras alarm terminals for doorbell operations then you will need the right dahua model. So much more automation is possible if U stick to cams with an API that this binding supports.
A fish eye lens may explain the view difference or it may be a typo as the specs in AliExpress often are wrong.
Hello Matt could you check my post please
I canāt get my camera working correctly.
Regards,
Salexes
clould you please share yout settings. I have the same cameras and i can not get them works
2019-11-16 17:11:09.374 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera Dispose() called.
2019-11-16 17:11:09.382 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera restarting.
2019-11-16 17:11:09.419 [me.event.ThingUpdatedEvent] - Thing 'ipcamera:ONVIF:93595891' has been updated.
2019-11-16 17:11:10.425 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Following NPE occured when trying to connect to the camera with ONVIF.java.lang.NullPointerException
2019-11-16 17:11:10.428 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Since an NPE occured when asking the camera about PTZ, the PTZ controls will not work. If the camera does not come online, give the camera the wrong ONVIF port number so it can bypass using ONVIF and still come online.
2019-11-16 17:11:10.430 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL.
2019-11-16 17:15:50.983 [hingStatusInfoChangedEvent] - 'ipcamera:ONVIF:93595891' changed from OFFLINE (CONFIGURATION_ERROR): Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL. to UNINITIALIZED
2019-11-16 17:15:51.015 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera Dispose() called.
2019-11-16 17:15:51.017 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera restarting.
2019-11-16 17:15:51.032 [hingStatusInfoChangedEvent] - 'ipcamera:ONVIF:93595891' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2019-11-16 17:15:51.841 [hingStatusInfoChangedEvent] - 'ipcamera:ONVIF:93595891' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2019-11-16 17:15:52.869 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL.
2019-11-16 17:15:52.873 [hingStatusInfoChangedEvent] - 'ipcamera:ONVIF:93595891' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL.
2019-11-16 17:18:06.874 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera Dispose() called.
2019-11-16 17:18:06.877 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - ipCamera restarting.
2019-11-16 17:18:06.902 [me.event.ThingUpdatedEvent] - Thing 'ipcamera:ONVIF:93595891' has been updated.
2019-11-16 17:18:07.901 [ERROR] [ing.ipcamera.handler.IpCameraHandler] - Camera failed to report a valid Snaphot URL, try over-riding the Snapshot URL auto detection by entering a known URL.
Thanks a lot!
