I’m trying a clean install of 2.5.12 to make the log4j change, but the first run is failing now. Is there some online resource needed for the install missing now? This used to work so well.
This is a straight unzip the the 2.5.12 binary, run with zulu 1.8 java.
This is the error I get on first run.
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91)
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72)
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457)
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452)
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224)
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062)
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Suppressed: java.io.IOException: Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
... 3 more
Caused by: java.io.IOException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.paper:jar:[2.5.0,2.6): [Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in local (/storage/local/openhab-versions/2.5.12/userdata/tmp/mvn), Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:780)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565)
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52)
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60)
... 7 more
Suppressed: shaded.org.eclipse.aether.transfer.MetadataNotFoundException: Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in local (/storage/local/openhab-versions/2.5.12/userdata/tmp/mvn)
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolve(DefaultMetadataResolver.java:220)
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolveMetadata(DefaultMetadataResolver.java:178)
at shaded.org.apache.maven.repository.internal.DefaultVersionRangeResolver.getVersions(DefaultVersionRangeResolver.java:198)
at shaded.org.apache.maven.repository.internal.DefaultVersionRangeResolver.resolveVersionRange(DefaultVersionRangeResolver.java:148)
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveVersionRange(DefaultRepositorySystem.java:232)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolveLatestVersionRange(AetherBasedResolver.java:1060)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:765)
... 12 more
Suppressed: shaded.org.eclipse.aether.transfer.MetadataNotFoundException: Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in openhab (https://openhab.jfrog.io/openhab/libs-release/)
at shaded.org.eclipse.aether.connector.basic.MetadataTransportListener.transferFailed(MetadataTransportListener.java:48)
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368)
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75)
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642)
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:235)
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver$ResolveTask.run(DefaultMetadataResolver.java:580)
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver$1.execute(DefaultMetadataResolver.java:500)
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolve(DefaultMetadataResolver.java:355)
... 12 more
Caused by: shaded.org.eclipse.aether.resolution.VersionRangeResolutionException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.paper:jar:[2.5.0,2.6)
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolveLatestVersionRange(AetherBasedResolver.java:1068)
... 12 more
23:08:36.553 [ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-habpanel, openhab-ui-paper': Error:
I only need this running so I can make a change of the log4j fix in 2.5.12. But if i can’t even get that running, I’m stuck.
