I guess that the ārandomā field was just not initialized by Volumio and is just not send as long as thereās no value⦠Now thereās a value with false or true.
is anyone faced with the same issue? regularly (but cannot say what regularly is, lets say just often) openhab looses my connection details, meaning the ip adress. i entered my local ip adress from the volumio instance. see attached image.
but after a while, it is set back to the initial setup,
meaning volumio.local
cannot say why, but with the inital connection, my volumio play thing is offline; i have to adapt the config of this thing regularly to my local ip adress to bring it online again.
any idea?
I am using Volumio standalone (not connected to openHAB) and have the same problem every night: when my provider is forcing the connection separation I have to restart Volumio ā¦
Are you using the latest build of 0.0.12 and which openhab version are you using?
Fantastic! Itās working.
But how do I configure my playlist?
I have found, thanks.
Thanks for the answer!
I just updated everything, my Openhab Vesion to the newest version as well as your binding to the newest verions.
My used versions are now:
Volumio Binding: org.openhab.binding.volumio2-2.4.0-SNAPSHOT.jar
OpenHab Version: openhab2 2.3.0-1
I will try again if now everythings work or not, if not i will give an update afterwards!
Hi with
the manual thing configuration does not work anymore. Status gets stuck at:
UNINITIALIZED - HANDLER_CONFIGURATION_PENDING
My item configuration is as follows:
Thing volumio2:player:wz "Livingroom_Volumio" [ hostname="192.168.178.51" ]
Iām going back on a previous release. Maybe someone has a fix.
Thnx for this great plugin!!! Using it with pleasure. I found a small bug. When a webradio stream is playing and i pause it, and start the stream afterwards, iām unable to stop it. The only way is to start something else like spotify or local music and the webstream is forced to stop. I see that when a local file or spotify is playing in volumio, the pause / play button is a pause button when playing. When a webstream is playing, itās a stop button. According to the logfile from openhab the status is the same when playing webstream or local file/spotify, but it seems like under the surface there is a difference. Anyone else notice this behaviour?
Hi Patrickse,
it seems, that updating the plugin as well as updating openhab didnt solve the issue. My logs are full of the following entries:
2018-12-27 07:40:03.452 [ERROR] [ng.volumio2.internal.Volumio2Service] - Timedout while conntecting to Volumio on volumio.local.
2018-12-27 07:51:44.592 [me.event.ThingUpdatedEvent] - Thing 'volumio2:player:cb5ab4a1-2a6d-4173-9fca-f28459cd230e-Volumio' has been updated.
2018-12-27 07:51:44.918 [INFO ] [ng.volumio2.internal.Volumio2Service] - Connected to Volumio2 on 192.168.1.30
2018-12-27 07:51:44.943 [hingStatusInfoChangedEvent] - 'volumio2:player:cb5ab4a1-2a6d-4173-9fca-f28459cd230e-Volumio' changed from OFFLINE to ONLINE
The status change from offline to online happen whenever i update my thing to the local ip adress, meaning volumio.local does not work. but i can reach volumio via webbrowser by using this adress.
Any ideas?
I did some little research and found that the Stop command for Volumio exists and it doesnāt break the webstreaming functionality (pause does this after a couple of pause / play on a webstream) Iām donāt know how to change the binding to use Stop in stead of pause, or add the Stop functionality.
You can test it by opening this URL in the browser: http://volumio.local/api/v1/commands/?cmd=stop, the result is: {ātimeā:1546248106841,āresponseā:āstop Successā}. Unfortunately openhab log / binding sees it as a pause: VolumioPlayer changed from PLAY to PAUSE
So I hope this can be added in the binding!
Hi patrickse,
still there? Problem see above still existsā¦
Many thanks!
Update: i found out that the volumio binding uses regularly after a reboot/ restart ob openhab the standard url
volumio.local
instead of the adapted url/ip.
found new infos to this issue, see attached logā¦
2019-01-06 11:40:45.486 [ERROR] [ng.volumio2.internal.Volumio2Service] - Could not connect to Volumio on 192.168.1.30
2019-01-06 11:41:10.362 [hingStatusInfoChangedEvent] - 'volumio2:player:cb5ab4a1-2a6d-4173-9fca-f28459cd230e-Volumio' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE
2019-01-06 11:41:10.378 [me.event.ThingUpdatedEvent] - Thing 'volumio2:player:cb5ab4a1-2a6d-4173-9fca-f28459cd230e-Volumio' has been updated.
2019-01-06 11:41:10.449 [ERROR] [ng.volumio2.internal.Volumio2Service] - Could not connect to Volumio on volumio.local.
within some minutes, the volumio binding changed the url autonomously, meaning that in the meantime i didnt change anything. seems that the binding acts a bit idenpendentlyā¦
Hi @anon71383850,
sorry been it bit busy over the holidays. I am currently struggling to get my volumio vm up again. I do not have any device to develop at the moment. I will see if I can re-activate one of my old PI“s.
Thanks for the informations I will have a lookā¦
I guess the autonomous change of the hostname is issued by the discovery handler.
At this point I retrieve the server name from the mdns name and return the result to openhab. Because the uuid is unique, I guess openhab relates the discovered hostname to the already defined thing and overwrites the property.
ThatĀ“s just a gues.. as I am still struggling with my test environmentā¦
thanks for this info!
if i can help you in any way, just give me a hint!
any news?
I fixed my dev environment⦠but I canĀ“t fix the problem atm. It works as long as thereās no discovery running for volumio devices. As soon as this discovery kicks in⦠the value for the hostname is changed to the mdns. I guess it depends on the UUID stuff and that my autogenerated UUID is crap.
any news now? the volumio binding is at the moment for me not usableā¦
Sorry to hear that. I still got no clue why the configuration is changed by the automatic discovery process. I am currently out of time to do anything about it. I will try to further investigate next week.
