Is the management of user roles in the karaf framework using jaas useful?
Hi everyone,
I have already post this question in this post, but I ask it again here because it was not enough clear in the previous post.
I actually implement the command to add/remove/change a role of a user in OpenHAB in the class UserConsoleCommandExtension.java at the location
org.openhab.core.io.console/src/main/java/org/openhab/core/io/console/internal/extension/UserConsoleCommandExtension.java
and in the bundle:
as requested in this issue.
However, in the karaf framework for the command jaas (Java Authentication and Authorization Service), there is the command jaas:group-add, jaas:role-add, etc. as shown in the image below:
I wonder if it is necessary that I implement the necessary modules for the jaas: command in the karaf console too?
Can someone confirm if it is necessary or useful to implement the modules to add/remove roles in the karaf framework too? Explain if it is more secure to do it with the jaas ? Explain why if not, and if it is enough to only implement it in the bundle org.openhab.core.io.console.
Thank you,
Nicolas Gennart.
