This is not tested and may contain some errors, but this is basically the easiest way since openHAB2.2
rule "Update User1 Last-Seen Time"
// this will get easier in future when the group trigger is accepted
// and added to the distribution, then only the group has to be listed
Item Presence_Mobile_User1 changed or
Item Presence_Mobile_User2 changed or
Item Presence_Mobile_User3 changed
var time = new DateTimeType()
postUpdate( triggeringItem.name.toString , time.toString)
there are some things which maybe will be of interrest in following threads, for your rules. I tried to add as many explanations as a could.
