Is there a built-in node red in openhab like home assistant
thank you
thank you
Yes it is in openhabian
Check this for an explanation:
I mean, nod-red isn’t in add-on
NodeRed has an openHAB add-on that people use to integrate openHAB with NodeRed. There is no NodeRed add-on for OH because there is no need to have an add-on in both places.
As @lampy mentioned you can add this via openhabian-config tool. If you didn’t install OH via the openhabian image you can add it per the doc’s.
Any idea who has written the openhab nodes for Node-red?
Am curious to see if more could be made.
There are a few more HA nodes (15) available in Node red, and really useful ones like the wait until node.
Only 5 openhab Nodes.
I’m definitely a fan of openhab2.
Probably unfair of me requesting the same facilities of HA, which does have quite a few more contributors?!
As a platform HA isn’t stable or flexible enough. Which is why I’m trying OH2 btw.
At current glance. OH is being a superior platform to HA.
It does seem like a less loved cousin (Development wise),
You can find more info and the maintainer in these to links.
I use nodered as my rule engine since 2017 when I started working with openhab and it worked until now pretty stable.
Big fan of node red too! I’ve found it solid thus far ![]()
