Currently I’m struggeling to configure my Netatmo station properly in OpenHab2 RC 2.10.
So far I’ve configured all things and items as files, only installing the bindings on the PaperUI. However, now I ran into problems with the Netatmo things configuration. At first I would like to explain what I’ve done:
My netatmo.items file in the items folder looks like the following:
Number Netatmo_Innen_CO2 "[%d ppm]" <carbondioxide> { channel = "netatmo:NAMain:raspi:mac-address:Co2" }
Number Netatmo_Aussen_Temperature "[%.1f C]" { channel = "netatmo:NAModule1:raspi:encoded-serial-number:Temperature" }
Now I can see the netatmo binding flagged as “online” in the PaperUI, but none of the things. The items doesn’t work as well.
When I delete the things configuration (only the stations, not the binding itself) and add the inside and outside station in the PaperUI, my items work well. Hence I’m sure that the binding itself is fine and also the item configuration. The error must lay in the things configuration, but I have no clue where.
I hope someone can relate to my issue.
Thanks in advance for your help!
Another thing I am currently fighting with: If I want to set the location of a module, I cannot use the syntax above with then “embedded” thing lines. I have to use:
I can keep everything in one file, e.g. “netatmo.things” on my machine, but the syntax is a bit more verbose and I have to repeat the parentId on each item.
my findings (and problems) may be related to this.
I tried to configure my netatmo.things file as @hakan did, because I wanted to use “custom” names for the things.
However, my modules remain offline. When I take a look into the inbox, the automatic generated things look like this:
netatmo:NAModule1::<serial#-without-dots>
So I thought the thing definition in this case should look like this
Now the things appear in the PaperUI. But my items still didn’t work until I changed my items configuration:
Number Netatmo_Innen_CO2 "[%d ppm]" <carbondioxide> { channel = "netatmo:NAMain:raspi:inside:Co2" }
Number Netatmo_Aussen_Temperature "[%.1f C]" { channel = "netatmo:NAModule1:raspi:outside:Temperature" }
Instead of the mac-address and the encoded serial number, I now used the keywords “inside” and “outside” in the path of the channels. After applying these changes my items work fine.
I have the same Problem…
My Things are ready and online.
But my Items do not show up anywhere. Not even in the console.
(If i use the PaperUI everything works well)
This is my Things config:
