Thanks for the additional suggestions.
Color is not one of the options for Semantic Property in the UI (I assume that is what you mean by a Tag).
I tried removing the “Point” tag, which I had added because one of the other items that works had it. I selected “Light” from the Semantic Property list. No change in behavior.
gExteriorLightsColor has no tags.
I searched the openhab log for errors. None of what I found looks like they would be relevant. Perhaps I need to restart openhab and look in that log.
openhabian@openhabian-spring4:/var/log/openhab $ cat openhab.log | grep -i error
2023-12-13 04:47:59.272 [DEBUG] [ernal.communication.RokuCommunicator] - Error executing player GET command, URL: http://192.168.1.127:8060/query/device-info, java.io.EOFException: HttpConnectionOverHTTP@e5028d::SocketChannelEndPoint@465854{l=/192.168.1.151:37164,r=/192.168.1.127:8060,ISHUT,fill=-,flush=-,to=0/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@e5028d(l:/192.168.1.151:37164 <-> r:/192.168.1.127:8060,closed=false)=>HttpChannelOverHTTP@1bef51b(exchange=HttpExchange@16c258{req=HttpRequest[GET /query/device-info HTTP/1.1]@17443d[TERMINATED/null] res=HttpResponse[null 0 null]@233b13[PENDING/null]})[send=HttpSenderOverHTTP@c515a1(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@9b1863{s=START}],recv=HttpReceiverOverHTTP@b8221(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-12-13 05:34:05.952 [DEBUG] [ernal.communication.RokuCommunicator] - Error executing player GET command, URL: http://192.168.1.91:8060/query/device-info, java.io.EOFException: HttpConnectionOverHTTP@2b5f5b::SocketChannelEndPoint@67c0a6{l=/192.168.1.151:45204,r=/192.168.1.91:8060,ISHUT,fill=-,flush=-,to=0/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@2b5f5b(l:/192.168.1.151:45204 <-> r:/192.168.1.91:8060,closed=false)=>HttpChannelOverHTTP@cd1046(exchange=HttpExchange@2ac9ee{req=HttpRequest[GET /query/device-info HTTP/1.1]@ab8177[TERMINATED/null] res=HttpResponse[null 0 null]@7d0774[PENDING/null]})[send=HttpSenderOverHTTP@46add(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@c5b28a{s=START}],recv=HttpReceiverOverHTTP@9b3b5c(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-12-13 06:10:04.369 [DEBUG] [ernal.communication.RokuCommunicator] - Error executing player GET command, URL: http://192.168.1.127:8060/query/device-info, java.io.EOFException: HttpConnectionOverHTTP@1d5fb86::SocketChannelEndPoint@c6125d{l=/192.168.1.151:47308,r=/192.168.1.127:8060,ISHUT,fill=-,flush=-,to=1/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@1d5fb86(l:/192.168.1.151:47308 <-> r:/192.168.1.127:8060,closed=false)=>HttpChannelOverHTTP@d450fe(exchange=HttpExchange@1af0c85{req=HttpRequest[GET /query/device-info HTTP/1.1]@132c2bd[TERMINATED/null] res=HttpResponse[null 0 null]@11c72fc[PENDING/null]})[send=HttpSenderOverHTTP@19b9001(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@4b7493{s=START}],recv=HttpReceiverOverHTTP@10d714d(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-12-13 06:56:41.059 [WARN ] [ntrol.internal.connection.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE","parameters":{"action":"turnOn"}}]}' resulted in error(s): {"entity":{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-12-13 07:00:01.184 [WARN ] [ntrol.internal.connection.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE","parameters":{"action":"turnOn"}}]}' resulted in error(s): {"entity":{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-12-13 07:07:41.607 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'SetFrontSmartLightTuyaStatus': Failed to execute action: 1(Unexpected error from weaving hook.)
2023-12-13 07:10:09.129 [WARN ] [ntrol.internal.connection.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"dd4ce484-58a3-4421-80d8-9240e2251afc","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"dd4ce484-58a3-4421-80d8-9240e2251afc","entityType":"APPLIANCE"},"code":"NoSuchTargetError","message":"NO_SUCH_ENDPOINT","data":null}
2023-12-13 07:24:06.373 [WARN ] [ntrol.internal.connection.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE","parameters":{"action":"turnOff"}}]}' resulted in error(s): {"entity":{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-12-13 07:58:25.471 [WARN ] [ntrol.internal.connection.Connection] - Smart home device command failed. The request '{"controlRequests":[{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE","parameters":{"action":"turnOn"}}]}' resulted in error(s): {"entity":{"entityId":"f7ef0608-aca2-44df-8aa0-891519436a2e","entityType":"APPLIANCE"},"code":"TargetApplianceUnreachableException","message":"ENDPOINT_UNREACHABLE","data":null}
2023-12-13 08:38:12.498 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'SetFrontSmartLightTuyaStatus': Failed to execute action: 1(Unexpected error from weaving hook.)
2023-12-13 08:41:05.933 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'SetFrontSmartLightTuyaStatus': Failed to execute action: 1(Unexpected error from weaving hook.)
2023-12-13 09:09:31.162 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'AniCloudDeviceLocationChangedCalculateDistanceAndPresence': Failed to execute action: 2(Unexpected error from weaving hook.)
2023-12-13 09:37:02.664 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'SetFrontSmartLightTuyaStatus': Failed to execute action: 1(Unexpected error from weaving hook.)
2023-12-13 10:57:16.819 [DEBUG] [ernal.communication.RokuCommunicator] - Error executing player GET command, URL: http://192.168.1.67:8060/query/device-info, java.io.EOFException: HttpConnectionOverHTTP@24f3a7::SocketChannelEndPoint@1c0a97b{l=/192.168.1.151:46654,r=/192.168.1.67:8060,ISHUT,fill=-,flush=-,to=0/0}{io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@24f3a7(l:/192.168.1.151:46654 <-> r:/192.168.1.67:8060,closed=false)=>HttpChannelOverHTTP@1be7748(exchange=HttpExchange@a6ad3{req=HttpRequest[GET /query/device-info HTTP/1.1]@1001bfe[TERMINATED/null] res=HttpResponse[null 0 null]@1a1f4d4[PENDING/null]})[send=HttpSenderOverHTTP@11bd7df(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@e7e5d{s=START}],recv=HttpReceiverOverHTTP@17844c9(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]
2023-12-13 10:57:29.941 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'SetFrontSmartLightTuyaStatus': Failed to execute action: 1(Unexpected error from weaving hook.)
I think I will look at the items in the API and see if I notice any differences.
