Hi all,
Probably a bit of a basic question here, so I’m posting in beginners (and hoping that it might help others).
I seem to have constant problems with items not working correctly and I’m wondering if it’s due to a fundamental misunderstanding I have with how items, channels and things work?
If I look at @chris 's documentation here, I can see how the various channel types match up to an item type. Getting a mismatch here seems to stop the item getting linked to the channel (i.e. if I try to match a Switch item to a sensor_door then I think this just doesn’t work … at least, I think this was the cause of at least one of my problems).
However if I look up a Thing in @chris 's database, e.g. a fibaro FGK101 then I see that it is a sensor_binary. Whereas when I look in PaperUI for one of mine I see:
i.e. Chris is saying it should be a sensor_binary, but PaperUI thinks it provides the sensor_door channel.
This is my only fibaro FGK101 which is currently functioning, so I know this ‘works’ but I’m not sure how it matches to the database item. My .items file contains:
Contact Garage_Inside_Door "Garage Inside Door" <contact> (gGroundFloor,gInternalSensors) { channel="zwave:device:157b8d41438:node9:sensor_door" } Number Garage_Inside_Door_Bat "Garage Inside Door Battery: [%d %%]" <energy> (gGroundFloor,gInternalDoorSensors) { channel="zwave:device:157b8d41438:node9:battery-level" }
- can this influence what channels PaperUI reports (i.e. am I to blame for the discrepancy between what I see on Chris’ page, or is it something more fundamental)?
The reason I’m wondering about all of this is a) I have several FGK101’s which don’t seem to be working and b) I want to use groups in my rules, but it’s a bit tricky to make something readable if
Group:Contact:OR(OPEN,CLOSED) gInternalDoorSensors "Internal doors open: [(%d)]" <contact>
returns UNDEF, presumably because contains a mixture of Switches and Contacts.
I did read through the documentation here again (and actually it’s been updated since I last looked - it’s very nice now!) before posting this question, but apologies in advance if it’s something which I should have been able to work out myself.
