Jablotron Alarm Binding for OpenHAB
Hi
It’s working now :slight_smile: I can se the status and so on, but how do ARM the alarm?
also how do you set this up in Items so I can use it in the home app on my phone
Please redownload the latest version first from Dropbox - Error - Simplify your life
I do not fully understand the system of sections in JA-100, but this shoud be working:
  • sending ON/OFF to statusPGM_x channels
  • sending a code (arm, disarm, partial arm, …) to status_x channels (sections)
As I already mentioned, I do not have JA-100 and I haven’t got any feedback yet - so try it please.
Thanks.
Ondrej
I am running lastest version, and there is a connection as I can see the status og the diffefrent section, but I am not sure what you mean about sending a ARM or DESARM command, is that a rule you make og do you set it up as an item ?
You can use it as a switch in your sitemap. e.g.
Switch item=JablotronSection1 label="Arm" mappings=[1234=" A ",2345=" B ",3456="ABC"]
Switch item=JablotronSection1 label="Disarm" mappings=[9876="Disarm"]
arm and disarm commands mean the same codes as you are using on your alarm keyboard
Ondrej
Hi Ondrej,
I just installed the binding, and it seems fine “online” etc..
I can’t get any “things” to show values. I just get a list of 15 status channels, and 20 PG Alarm status channels.
I have temperature sensors, and not sure if it fetch the data correctly?
This is from my log.
2018-11-23 18:30:08.822 [INFO ] [lotron.handler.JablotronJa100Handler] - Last event: Ja100Event{date=2018-11-23T17:56:39+0100, section=‘HOVEDDØR TRAP’, event=‘Vypnuto’, eventClass=‘OFF’}
Also I have one long log entry looking like this, all details in “one line” .. Can the Openhab differentiate this or should the “plugin/binding” be adjusted accordingly?.
I can send you the entire log if needed - Can’t find your email :slight_smile: ..
2018-11-23 18:33:15.837 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {“status”:200,“termostaty”:,“elektromery”:,“sekce”:{“2”:{“stav”:0,“nazev”:“Anneks”,“stateName”:“STATE_3”,“time”:“26.02.2018 - 17:28”,“active”:1},“1”:{“stav”:0,“nazev”:“K\u00e6lder”,“stateName”:“STATE_2”,“time”:“22.05.2018 - 23:30”,“active”:1},“0”:{“stav”:0,“nazev”:“Stue”,“stateName”:“STATE_1”,“time”:“26.02.2018 - 17:28”,“active”:1}},“pgm”:{“15”:{“stav”:0,“nazev”:“PG output 16”,“stateName”:“PGM_16”,“ts”:1539270260,“time”:“11.10.2018 - 17:04”,“active”:1},“14”:{“stav”:0,“nazev”:“PG output 15”,“stateName”:“PGM_15”,“ts”:1539270260,“time”:“11.10.2018 - 17:04”,“active”:1},“13”:{“stav”:0,“nazev”:“PG output 14”,“stateName”:“PGM_14”,“ts”:1539270260,“time”:“11.10.2018 - 17:04”,“active”:1},“12”:{“stav”:0,“nazev”:“PG output 13”,“stateName”:“PGM_13”,“ts”:1539270260,“time”:“11.10.2018 - 17:04”,“active”:1},“11”:{“stav”:0,“nazev”:“PG output 12”,“stateName”:“PGM_12”,“ts”:1539270260,"t… Goes on ..
Guten Abend,
ich versuche schon seit längerem die JA100 zu meine Openhab2 hinzuzufügen.
Doch bei mir scheitert es schon an der Einrichtung.
können Sie mir mal eine demo der Installation angeben?
Also wie Konfiguriere ich den jablonet account und wie die JA100.
Danke
sorry but I don’t remember how I bound my JA-80 with my jablonet account (https://www.jablonet.net/).
I did it 9 years ago. And I do not know the JA-100 activation either :frowning:
If no one with JA100 answers, my hint is to follow the manual or ask the support service how to make MyJablotron mobile application working.
Once it is working, you are having the jablonet account.
Thanks.
Ondrej
You first have to configure the jablotron jablonet bridge in openhab and put your Myjablotron login and password in de config of the bridge to activate the jablotron jablonet bridge. When it is online you go to thing jablotron ja100 alarm and select the configured jablonet bridge.And then in should work.
I have a ja-100 alarm and with the binding i can switch on and off and see the pg exit’s but i dont see the following items
            Text item=LastEventCode
            Text item=LastEventClass
            Text item=LastEventTime
            Text item=LastCheckTime
Any idea why i dont see this item’s
This is the log
2019-01-27 16:37:08.898 [hingStatusInfoChangedEvent] - 'jablotron:ja100:ffa3a704:148580' changed from ONLINE to OFFLINE
2019-01-27 16:37:08.902 [me.event.ThingUpdatedEvent] - Thing 'jablotron:ja100:ffa3a704:148580' has been updated.
2019-01-27 16:37:21.259 [hingStatusInfoChangedEvent] - 'jablotron:ja100:ffa3a704:148580' changed from OFFLINE to ONLINE
2019-01-27 16:37:29.351 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603449,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603449,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603449,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603449,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603449,"vypis":[]}
2019-01-27 16:37:29.353 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Water with status: 1
2019-01-27 16:37:29.356 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_2 to value: 1
2019-01-27 16:37:29.358 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Woning with status: 0
2019-01-27 16:37:29.360 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_1 to value: 0
2019-01-27 16:37:29.362 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 16 with status: 0
2019-01-27 16:37:29.364 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_16 to value: 0
2019-01-27 16:37:29.366 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 15 with status: 0
2019-01-27 16:37:29.367 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_15 to value: 0
2019-01-27 16:37:29.369 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 14 with status: 0
2019-01-27 16:37:29.370 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_14 to value: 0
2019-01-27 16:37:29.371 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 13 with status: 0
2019-01-27 16:37:29.372 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_13 to value: 0
2019-01-27 16:37:29.373 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 12 with status: 0
2019-01-27 16:37:29.374 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_12 to value: 0
2019-01-27 16:37:29.375 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 11 with status: 0
2019-01-27 16:37:29.375 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_11 to value: 0
2019-01-27 16:37:29.376 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 10 with status: 0
2019-01-27 16:37:29.377 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_10 to value: 0
2019-01-27 16:37:29.378 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 9 with status: 0
2019-01-27 16:37:29.379 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_9 to value: 0
2019-01-27 16:37:29.380 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 8 with status: 0
2019-01-27 16:37:29.380 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_8 to value: 0
2019-01-27 16:37:29.381 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 7 with status: 0
2019-01-27 16:37:29.382 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_7 to value: 0
2019-01-27 16:37:29.382 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 6 with status: 0
2019-01-27 16:37:29.383 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_6 to value: 0
2019-01-27 16:37:29.384 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Hal verlichting with status: 0
2019-01-27 16:37:29.386 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_5 to value: 0
2019-01-27 16:37:29.387 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: verlichting garage with status: 0
2019-01-27 16:37:29.388 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_4 to value: 0
2019-01-27 16:37:29.388 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Garagepoorten with status: 0
2019-01-27 16:37:29.389 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_3 to value: 0
2019-01-27 16:37:29.390 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Buitensirene with status: 0
2019-01-27 16:37:29.391 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_2 to value: 0
2019-01-27 16:37:29.392 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Flitslamp with status: 0
2019-01-27 16:37:29.393 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_1 to value: 0
2019-01-27 16:37:29.394 [ERROR] [lotron.handler.JablotronJa100Handler] - Error during alarm status update
	at org.openhab.binding.jablotron.internal.model.ja100.Ja100StatusResponse.getTemperatures(Ja100StatusResponse.java:152) ~[?:?]
	at org.openhab.binding.jablotron.handler.JablotronJa100Handler.processTemperatures(JablotronJa100Handler.java:313) ~[?:?]
	at org.openhab.binding.jablotron.handler.JablotronJa100Handler.updateAlarmStatus(JablotronJa100Handler.java:294) ~[?:?]
	at org.openhab.binding.jablotron.handler.JablotronAlarmHandler.lambda$3(JablotronAlarmHandler.java:185) ~[?:?]
2019-01-27 16:37:37.255 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603457,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603457,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603457,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603457,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603457,"vypis":[]}
2019-01-27 16:37:37.257 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Water with status: 1
2019-01-27 16:37:37.257 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_2 to value: 1
2019-01-27 16:37:37.258 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Woning with status: 0
2019-01-27 16:37:37.258 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_1 to value: 0
2019-01-27 16:37:37.259 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 16 with status: 0
2019-01-27 16:37:37.259 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_16 to value: 0
2019-01-27 16:37:37.260 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 15 with status: 0
2019-01-27 16:37:37.261 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_15 to value: 0
2019-01-27 16:37:37.262 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 14 with status: 0
2019-01-27 16:37:37.262 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_14 to value: 0
2019-01-27 16:37:37.262 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 13 with status: 0
2019-01-27 16:37:37.263 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_13 to value: 0
2019-01-27 16:37:37.263 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 12 with status: 0
2019-01-27 16:37:37.263 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_12 to value: 0
2019-01-27 16:37:37.264 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 11 with status: 0
2019-01-27 16:37:37.264 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_11 to value: 0
2019-01-27 16:37:37.264 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 10 with status: 0
2019-01-27 16:37:37.265 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_10 to value: 0
2019-01-27 16:37:37.265 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 9 with status: 0
2019-01-27 16:37:37.266 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_9 to value: 0
2019-01-27 16:37:37.267 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 8 with status: 0
2019-01-27 16:37:37.267 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_8 to value: 0
2019-01-27 16:37:37.268 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 7 with status: 0
2019-01-27 16:37:37.268 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_7 to value: 0
2019-01-27 16:37:37.268 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 6 with status: 0
2019-01-27 16:37:37.269 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_6 to value: 0
2019-01-27 16:37:37.269 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Hal verlichting with status: 0
2019-01-27 16:37:37.269 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_5 to value: 0
2019-01-27 16:37:37.270 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: verlichting garage with status: 0
2019-01-27 16:37:37.270 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_4 to value: 0
2019-01-27 16:37:37.270 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Garagepoorten with status: 0
2019-01-27 16:37:37.270 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_3 to value: 0
2019-01-27 16:37:37.271 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Buitensirene with status: 0
2019-01-27 16:37:37.271 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_2 to value: 0
2019-01-27 16:37:37.271 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Flitslamp with status: 0
2019-01-27 16:37:37.271 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_1 to value: 0
2019-01-27 16:37:37.271 [ERROR] [lotron.handler.JablotronJa100Handler] - Error during alarm status update
2019-01-27 16:37:45.085 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603465,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603465,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603465,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603465,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603465,"vypis":[]}
2019-01-27 16:37:45.088 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Water with status: 1
2019-01-27 16:37:45.089 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_2 to value: 1
2019-01-27 16:37:45.090 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Woning with status: 0
2019-01-27 16:37:45.094 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_1 to value: 0
2019-01-27 16:37:45.096 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 16 with status: 0
2019-01-27 16:37:45.098 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_16 to value: 0
2019-01-27 16:37:45.099 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 15 with status: 0
2019-01-27 16:37:45.104 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_15 to value: 0
2019-01-27 16:37:45.107 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 14 with status: 0
2019-01-27 16:37:45.108 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_14 to value: 0
2019-01-27 16:37:45.111 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 13 with status: 0
2019-01-27 16:37:45.112 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_13 to value: 0
2019-01-27 16:37:45.112 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 12 with status: 0
2019-01-27 16:37:45.112 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_12 to value: 0
2019-01-27 16:37:45.113 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 11 with status: 0
2019-01-27 16:37:45.113 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_11 to value: 0
2019-01-27 16:37:45.113 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 10 with status: 0
2019-01-27 16:37:45.114 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_10 to value: 0
2019-01-27 16:37:45.115 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 9 with status: 0
2019-01-27 16:37:45.116 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_9 to value: 0
2019-01-27 16:37:45.117 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 8 with status: 0
2019-01-27 16:37:45.117 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_8 to value: 0
2019-01-27 16:37:45.119 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 7 with status: 0
2019-01-27 16:37:45.120 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_7 to value: 0
2019-01-27 16:37:45.120 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 6 with status: 0
2019-01-27 16:37:45.121 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_6 to value: 0
2019-01-27 16:37:45.122 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Hal verlichting with status: 0
2019-01-27 16:37:45.123 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_5 to value: 0
2019-01-27 16:37:45.124 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: verlichting garage with status: 0
2019-01-27 16:37:45.124 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_4 to value: 0
2019-01-27 16:37:45.125 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Garagepoorten with status: 0
2019-01-27 16:37:45.125 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_3 to value: 0
2019-01-27 16:37:45.126 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Buitensirene with status: 0
2019-01-27 16:37:45.126 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_2 to value: 0
2019-01-27 16:37:45.127 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Flitslamp with status: 0
2019-01-27 16:37:45.127 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_1 to value: 0
2019-01-27 16:37:45.128 [ERROR] [lotron.handler.JablotronJa100Handler] - Error during alarm status update
2019-01-27 16:37:52.839 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603472,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603472,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603472,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603472,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603472,"vypis":[]}
2019-01-27 16:37:52.841 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Water with status: 1
2019-01-27 16:37:52.842 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_2 to value: 1
2019-01-27 16:37:52.843 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Woning with status: 0
2019-01-27 16:37:52.845 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_1 to value: 0
2019-01-27 16:37:52.846 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 16 with status: 0
2019-01-27 16:37:52.847 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_16 to value: 0
2019-01-27 16:37:52.849 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 15 with status: 0
2019-01-27 16:37:52.850 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_15 to value: 0
2019-01-27 16:37:52.851 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 14 with status: 0
2019-01-27 16:37:52.852 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_14 to value: 0
2019-01-27 16:37:52.853 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 13 with status: 0
2019-01-27 16:37:52.854 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_13 to value: 0
2019-01-27 16:37:52.855 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 12 with status: 0
2019-01-27 16:37:52.856 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_12 to value: 0
2019-01-27 16:37:52.858 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 11 with status: 0
2019-01-27 16:37:52.859 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_11 to value: 0
2019-01-27 16:37:52.860 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 10 with status: 0
2019-01-27 16:37:52.861 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_10 to value: 0
2019-01-27 16:37:52.862 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 9 with status: 0
2019-01-27 16:37:52.863 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_9 to value: 0
2019-01-27 16:37:52.864 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 8 with status: 0
2019-01-27 16:37:52.865 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_8 to value: 0
2019-01-27 16:37:52.867 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 7 with status: 0
2019-01-27 16:37:52.868 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_7 to value: 0
2019-01-27 16:37:52.869 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 6 with status: 0
2019-01-27 16:37:52.870 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_6 to value: 0
2019-01-27 16:37:52.871 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Hal verlichting with status: 0
2019-01-27 16:37:52.872 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_5 to value: 0
2019-01-27 16:37:52.873 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: verlichting garage with status: 0
2019-01-27 16:37:52.874 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_4 to value: 0
2019-01-27 16:37:52.875 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Garagepoorten with status: 0
2019-01-27 16:37:52.876 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_3 to value: 0
2019-01-27 16:37:52.878 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Buitensirene with status: 0
2019-01-27 16:37:52.879 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_2 to value: 0
2019-01-27 16:37:52.880 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Flitslamp with status: 0
2019-01-27 16:37:52.881 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_1 to value: 0
2019-01-27 16:37:52.882 [ERROR] [lotron.handler.JablotronJa100Handler] - Error during alarm status update
2019-01-27 16:38:00.601 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603480,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603480,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603480,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603480,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603480,"vypis":[]}
2019-01-27 16:38:00.602 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Water with status: 1
2019-01-27 16:38:00.604 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_2 to value: 1
2019-01-27 16:38:00.605 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a section: Woning with status: 0
2019-01-27 16:38:00.607 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:STATE_1 to value: 0
2019-01-27 16:38:00.609 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 16 with status: 0
2019-01-27 16:38:00.610 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_16 to value: 0
2019-01-27 16:38:00.611 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 15 with status: 0
2019-01-27 16:38:00.613 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_15 to value: 0
2019-01-27 16:38:00.614 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 14 with status: 0
2019-01-27 16:38:00.615 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_14 to value: 0
2019-01-27 16:38:00.616 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 13 with status: 0
2019-01-27 16:38:00.617 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_13 to value: 0
2019-01-27 16:38:00.618 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 12 with status: 0
2019-01-27 16:38:00.619 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_12 to value: 0
2019-01-27 16:38:00.620 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 11 with status: 0
2019-01-27 16:38:00.621 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_11 to value: 0
2019-01-27 16:38:00.622 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 10 with status: 0
2019-01-27 16:38:00.623 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_10 to value: 0
2019-01-27 16:38:00.625 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 9 with status: 0
2019-01-27 16:38:00.626 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_9 to value: 0
2019-01-27 16:38:00.627 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 8 with status: 0
2019-01-27 16:38:00.628 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_8 to value: 0
2019-01-27 16:38:00.629 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 7 with status: 0
2019-01-27 16:38:00.630 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_7 to value: 0
2019-01-27 16:38:00.631 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: PG-uitgang 6 with status: 0
2019-01-27 16:38:00.632 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_6 to value: 0
2019-01-27 16:38:00.633 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Hal verlichting with status: 0
2019-01-27 16:38:00.634 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_5 to value: 0
2019-01-27 16:38:00.635 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: verlichting garage with status: 0
2019-01-27 16:38:00.636 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_4 to value: 0
2019-01-27 16:38:00.638 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Garagepoorten with status: 0
2019-01-27 16:38:00.639 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_3 to value: 0
2019-01-27 16:38:00.640 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Buitensirene with status: 0
2019-01-27 16:38:00.641 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_2 to value: 0
2019-01-27 16:38:00.642 [INFO ] [lotron.handler.JablotronJa100Handler] - Found a PGM: Flitslamp with status: 0
2019-01-27 16:38:00.643 [INFO ] [lotron.handler.JablotronJa100Handler] - Updating channel: jablotron:ja100:ffa3a704:148580:PGM_1 to value: 0
2019-01-27 16:38:00.644 [ERROR] [lotron.handler.JablotronJa100Handler] - Error during alarm status update
2019-01-27 16:38:08.418 [INFO ] [lotron.handler.JablotronJa100Handler] - getStatus response: {"status":200,"termostaty":[],"elektromery":[],"sekce":{"1":{"stav":1,"nazev":"Water","stateName":"STATE_2","time":"28.09.2018 - 18:17","active":1},"0":{"stav":0,"nazev":"Woning","stateName":"STATE_1","time":"dnes - 07:21","active":1}},"pgm":{"15":{"stav":0,"nazev":"PG-uitgang 16","stateName":"PGM_16","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"14":{"stav":0,"nazev":"PG-uitgang 15","stateName":"PGM_15","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"13":{"stav":0,"nazev":"PG-uitgang 14","stateName":"PGM_14","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"12":{"stav":0,"nazev":"PG-uitgang 13","stateName":"PGM_13","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"11":{"stav":0,"nazev":"PG-uitgang 12","stateName":"PGM_12","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"10":{"stav":0,"nazev":"PG-uitgang 11","stateName":"PGM_11","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"9":{"stav":0,"nazev":"PG-uitgang 10","stateName":"PGM_10","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"8":{"stav":0,"nazev":"PG-uitgang 9","stateName":"PGM_9","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"7":{"stav":0,"nazev":"PG-uitgang 8","stateName":"PGM_8","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"6":{"stav":0,"nazev":"PG-uitgang 7","stateName":"PGM_7","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"5":{"stav":0,"nazev":"PG-uitgang 6","stateName":"PGM_6","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"4":{"stav":0,"nazev":"Hal verlichting","stateName":"PGM_5","ts":1548601414,"time":"dnes - 16:03","active":1},"3":{"stav":0,"nazev":"verlichting garage","stateName":"PGM_4","ts":1538151183,"time":"28.09.2018 - 18:13","active":1},"2":{"stav":0,"nazev":"Garagepoorten","stateName":"PGM_3","ts":1548602668,"time":"dnes - 16:24","active":1},"1":{"stav":0,"nazev":"Buitensirene","stateName":"PGM_2","ts":1548430860,"time":"25.01.2019 - 16:41","active":1},"0":{"stav":0,"nazev":"Flitslamp","stateName":"PGM_1","ts":1548430860,"time":"25.01.2019 - 16:41","active":1}},"moduly":{"16824284":{"1":{"id":16824288,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603488,"controlsComponent":null,"stav":0}},"16824292":{"1":{"id":16824296,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603488,"controlsComponent":null,"stav":0}},"16824300":{"1":{"id":16824304,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603488,"controlsComponent":null,"stav":0}},"16824308":{"1":{"id":16824312,"stateName":"STATE_1","control":0,"value":null,"fce":"PartialArm_Arm","ts":1548603488,"controlsComponent":null,"stav":0}}},"alarm":[],"sdc":[],"common":[],"trouble":[],"service":[],"teplomery":[],"pir":[],"tz":"Europe\/Brussels","prava":0,"permissions":{"STATE_1":1,"STATE_2":1,"PGM_1":1,"PGM_2":1,"PGM_3":1,"PGM_4":1,"PGM_5":1,"PGM_6":1,"PGM_7":1,"PGM_8":1,"PGM_9":1,"PGM_10":1,"PGM_11":1,"PGM_12":1,"PGM_13":1,"PGM_14":1,"PGM_15":1,"PGM_16":1},"timeStamp":1548603488,"vypis":[]}
currently only Last check time channel is available for the JA100 alarm (besides sections and PGMs and temperature sensors). Please test the latest version from:
If there is no exception, the last check channel should be properly updated. Furthermore some debug info about last events should be in your openhab.log.
I’d be glad if you could post it here, so I can add missing channels…
Thanks.
Ondrej
I have installed your latest version i dont see any change.
I have set the logging to TRACE
https://www.dropbox.com/s/ientsgvtquvmuoj/jablotron%20logs?dl=0
I hope you can find the missing channels.
Thanks,
I see the events in the log so I reintroduced the events channels.
Please try this:
since this version adds new channels to ja100 thing, please remove and rediscover the ja100 alarm so it brings into effect.
O.
The binding is working with the added channels and it seems to be working fine i keep testing it.
Is it possibel that you translate Vypnuto Zapnuto to english?
thanks for testing,
please redownload the latest version from the same link, the default language is set to EN.
Thanks.
Ondrej
The binding is in english now?Thanks for that.
I still mis 1 channel te following i am still missing
String JablotronCode { channel="jablotron:oasis:8c93a5ed:50139:command", autoupdate="false" }
With the ja 100 system when i set the alarm on i can press 1 time then the orange light will go on and only the downstairs alarm will be turned on when i press 2 times a red light will go on and the whole house alarm is set on.Can we manage this with the binding?
I am trying to switch my light’s on with the alarm movement sensors but they react to slow i set refresh on 1 sec but it still react’s to slow can you do something about that?
with the JA100 you can control PGM_ channels by sending them ON/OFF command and control STATE_ channels (sections) by sending them user code as a string (e.g. “1234”)
Since the JA80 has only one section, it uses the command channel to send the code…
thanks
Ondrej
Is there a way to speed up the PGM_channels state they act to slow to switch my lights on and off?
Levi
Unfotunately not, Jablonet cloud service is one of the slowest I’ve ever seen.
Login takes at least 3s and every action ads several extra seconds :frowning:
To bad it would be nice if it was possibel.
Then i have to wire the PGM output straight to my modbus digital input.
Are you planning on making this binding officiall?
Yes, I am planinng to, but I still see a lot of work on JA100 alarm.
Unless you confirm it is usable as MVP right now :slight_smile: (Minimum Viable Product)
I think I have found at least 3-5 seconds speedup when sending a command.
Can you download and test the latest version, please?
Thanks.
Ondrej
