I’m using OH 3.1 on a RPI4. every 4 or 5 day’s I get below error. If I get this error, all OH functions are down. It is possible to access the logging but the UI and things are both down. After rebooting (power off/on) the systems restarts and is ok for 4 a 5 day’s.
I am a new-bee OH user, please can you help me to fix this error? Please let me know If I have to gather more info.
2021-10-31 01:26:16.464 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
java.lang.OutOfMemoryError: Java heap space
2021-10-31 01:26:15.380 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
io.netty.channel.ChannelPipelineException: com.hivemq.client.internal.mqtt.handler.MqttChannelInitializer.handlerAdded() has thrown an exception; removed.
at io.netty.channel.DefaultChannelPipeline.callHandlerAdded0(DefaultChannelPipeline.java:624) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline.access$100(DefaultChannelPipeline.java:46) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline$PendingHandlerAddedTask.execute(DefaultChannelPipeline.java:1463) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline.callHandlerAddedForAllHandlers(DefaultChannelPipeline.java:1115) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPipeline.invokeHandlerAddedIfNeeded(DefaultChannelPipeline.java:650) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe.register0(AbstractChannel.java:514) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe.access$200(AbstractChannel.java:429) [bundleFile:4.1.63.Final]
at io.netty.channel.AbstractChannel$AbstractUnsafe$1.run(AbstractChannel.java:486) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:164) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:472) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:500) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) [bundleFile:4.1.63.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.63.Final]
Caused by: java.lang.OutOfMemoryError: Java heap space
2021-10-31 01:26:29.189 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
2021-10-31 01:26:31.322 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '192.168.1.101'. Next attempt in 60000ms
2021-10-31 01:27:01.552 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:27:03.663 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:27:09.002 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:27:24.065 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:27:32.617 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
2021-10-31 01:28:55.840 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
2021-10-31 01:29:38.563 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
2021-10-31 01:32:06.846 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:32:16.481 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:32:19.695 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:04.447 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:06.574 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:14.024 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:20.403 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:49.240 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:33:51.380 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:35:05.201 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
2021-10-31 01:35:05.202 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
2021-10-31 01:34:59.807 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
2021-10-31 01:36:02.626 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:39:53.320 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:38:48.165 [WARN ] [concurrent.SingleThreadEventExecutor] - Unexpected exception from an event executor:
2021-10-31 01:39:53.320 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
2021-10-31 01:40:01.917 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
2021-10-31 01:41:43.209 [ERROR] [org.apache.felix.fileinstall ] - In main loop, we have serious trouble
2021-10-31 01:40:01.917 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
2021-10-31 01:42:14.197 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:40:26.465 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2021-10-31 01:42:15.292 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2021-10-31 01:41:43.209 [WARN ] [netty.channel.DefaultChannelPipeline] - An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
io.netty.channel.ChannelPipelineException: org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$1.handlerAdded() has thrown an exception; removed.
2021-10-31 01:42:15.292 [WARN ] [hannel.AbstractChannelHandlerContext] - An exception 'java.lang.OutOfMemoryError: Java heap space' [enable DEBUG level for full stacktrace] was thrown by a user handler's exceptionCaught() method while handling the following exception:
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:497) [bundleFile:4.1.63.Final]
2021-10-31 01:42:21.011 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
2021-10-31 01:42:21.012 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:43:02.767 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:42:22.096 [WARN ] [netty.util.concurrent.DefaultPromise] - An exception was thrown by org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete()
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete(IpCameraHandler.java:622) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler$2.operationComplete(IpCameraHandler.java:1) ~[?:?]
at io.netty.util.concurrent.DefaultPromise.notifyListener0(DefaultPromise.java:578) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.notifyListeners0(DefaultPromise.java:571) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.notifyListenersNow(DefaultPromise.java:550) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:491) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.setValue0(DefaultPromise.java:616) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.setSuccess0(DefaultPromise.java:605) [bundleFile:4.1.63.Final]
at io.netty.util.concurrent.DefaultPromise.trySuccess(DefaultPromise.java:104) [bundleFile:4.1.63.Final]
at io.netty.channel.DefaultChannelPromise.trySuccess(DefaultChannelPromise.java:84) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.fulfillConnectPromise(AbstractNioChannel.java:300) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.finishConnect(AbstractNioChannel.java:335) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:707) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:655) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:581) [bundleFile:4.1.63.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493) [bundleFile:4.1.63.Final]
2021-10-31 01:43:34.777 [WARN ] [era.internal.handler.IpCameraHandler] - !!!! Camera possibly closed the channel on the binding, cause reported is: Java heap space
2021-10-31 01:47:54.558 [ERROR] [org.apache.felix.fileinstall ] - In main loop, we have serious trouble
2021-10-31 01:48:32.291 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2021-10-31 01:48:32.291 [WARN ] [io.netty.channel.AbstractChannel ] - Force-closing a channel whose registration task was not accepted by an event loop: [FAILED toString()]
java.util.concurrent.RejectedExecutionException: event executor terminated
at io.netty.util.concurrent.SingleThreadEventExecutor.reject(SingleThreadEventExecutor.java:926) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.offerTask(SingleThreadEventExecutor.java:353) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.addTask(SingleThreadEventExecutor.java:346) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.execute(SingleThreadEventExecutor.java:828) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.execute(SingleThreadEventExecutor.java:818) ~[?:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.register(AbstractChannel.java:483) ~[?:?]
at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:87) ~[?:?]
at io.netty.channel.SingleThreadEventLoop.register(SingleThreadEventLoop.java:81) ~[?:?]
at io.netty.channel.MultithreadEventLoopGroup.register(MultithreadEventLoopGroup.java:86) ~[?:?]
at io.netty.bootstrap.AbstractBootstrap.initAndRegister(AbstractBootstrap.java:323) ~[?:?]
at io.netty.bootstrap.Bootstrap.doResolveAndConnect(Bootstrap.java:155) ~[?:?]
at io.netty.bootstrap.Bootstrap.connect(Bootstrap.java:139) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.sendHttpRequest(IpCameraHandler.java:603) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.sendHttpGET(IpCameraHandler.java:503) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.pollCameraRunnable(IpCameraHandler.java:1668) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2021-10-31 01:49:55.938 [ERROR] [ent.DefaultPromise.rejectedExecution] - Failed to submit a listener notification task. Event loop shut down?
at io.netty.util.concurrent.DefaultPromise.safeExecute(DefaultPromise.java:842) ~[?:?]
at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:499) ~[?:?]
at io.netty.util.concurrent.DefaultPromise.addListener(DefaultPromise.java:184) ~[?:?]
at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:95) ~[?:?]
at io.netty.channel.DefaultChannelPromise.addListener(DefaultChannelPromise.java:30) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.sendHttpRequest(IpCameraHandler.java:604) ~[?:?]
