java.io.IOException: Too many open files
My system just because unresponsive. I logged in and found that it has been spamming my logs (all 10 filled with this error in the last few mintues, who knows how long its been going).
2017-05-11 10:26:33.513 [WARN ] [eclipse.jetty.server.ServerConnector] -
at sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method)[:1.8.0_121]
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:422)[:1.8.0_121]
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:250)[:1.8.0_121]
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:377)[81:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:500)[81:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[84:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[84:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
I’m not sure what this is related to. I was noticing yesterday that basicui on my macbook air chrome was not working well. The back error was useless and it was constantly loading.
It suggest a resource leak somewhere, to debug it:
If it comes from openHAB please give as much information as possible :slight_smile:
I’ll see what I can do. I stopped the service (which was consuming 100% of 1 core), did updates (debian box) and rebooted. It had been up for 49 days. I see that it started around 9:30 as that is when my graphs showed the cpu spike.
I have exactly the same problem and it can be easily reproduced:
  • I have three charts in a sitemap
  • I use the basicui
  • As long as I do not refresch the site in a web browser - the performance is OK
  • As soon as I refresh the web view, the system goes down (CPU Usage by openhab > 90%) and does not respond any more
  • After a while I get ‘too many files open’ written to the log file
I have tested this behaiour on a Raspberry 3 and a Raspberry ZeroW
pi@MeteringPiZeroW:/var/lib/openhab2/tmp $ netstat -an | grep CLOSE_WAIT | wc -l
3526
pi@MeteringPiZeroW:/var/lib/openhab2/tmp $ ls -al | wc -l
55
pi@MeteringPi:/var/lib/openhab2/tmp $ netstat -an | grep CLOSE_WAIT | wc -l
1072
pi@MeteringPi:/var/lib/openhab2/tmp $ ls -al | wc -l
46
Please provide us with some output from the stackoverflow answer
Try this URI:
http://kulturnetz-drensteinfurt.de/Medien/Log4HABDebug.zip
Give me a short feedback that you have downloaded the zipped log file.
It contains the openhab2 log files with the exceptions thrown during infinite processing
Just search for ‘viele’ in the file.
grep "Zu viele" openhab.log
BTW:
On my linux development desktop machine - this problem does not occur
I downloaded. Maybe you could also provide the output of
use lsof -p pid to check what cause leak of file references;
use ulimit -n to see the limit of opened file references of a single process;
check any IO resources in your project,are they released in time?,Note that,File,Process,Socket(and Http connections) are all IO resources.
Although in this case the number of connections looks quite extreme, if you could create a Heap dump I might be able to pinpoint it. Please do that at a moment the number CLOSE_WAIT is at least 1000 preferably as high as you have seen it. It makes it easier to find a potential cause. How long does it take to collect this number of open connections?
pi@MeteringPi:/var/log/openhab2 $ sudo lsof -p 20147 | wc -l
2214
pi@MeteringPi:/var/log/openhab2 $ ulimit -n
65536
And lots of these lines
java 20147 openhab 2092u REG 179,2 43 247729 /var/lib/openhab2/tmp/imageio8931737582513179366.tmp
java 20147 openhab 2093u REG 179,2 43 247730 /var/lib/openhab2/tmp/imageio1396124037759319630.tmp
java 20147 openhab 2094u REG 179,2 43 247728 /var/lib/openhab2/tmp/imageio5819838373834152835.tmp
java 20147 openhab 2095u REG 179,2 43 247731 /var/lib/openhab2/tmp/imageio9089374638969299220.tmp
java 20147 openhab 2096u REG 179,2 43 247732 /var/lib/openhab2/tmp/imageio5140302089757248728.tmp
java 20147 openhab 2097u REG 179,2 43 247733 /var/lib/openhab2/tmp/imageio3900864253772793382.tmp
java 20147 openhab 2098u REG 179,2 43 247734 /var/lib/openhab2/tmp/imageio4205840447396376183.tmp
java 20147 openhab 2099u REG 179,2 43 247735 /var/lib/openhab2/tmp/imageio7159244966723304073.tmp
java 20147 openhab 2100u REG 179,2 43 247736 /var/lib/openhab2/tmp/imageio3823977621293419679.tmp
java 20147 openhab 2101u REG 179,2 43 247737 /var/lib/openhab2/tmp/imageio5104763224528198381.tmp
java 20147 openhab 2102u REG 179,2 43 247738 /var/lib/openhab2/tmp/imageio7943117347099773830.tmp
java 20147 openhab 2103u REG 179,2 28280 247594 /var/lib/openhab2/persistence/rrd4j/Consumption.rrd
java 20147 openhab 2104u REG 179,2 43 247677 /var/lib/openhab2/tmp/imageio2028556992348704553.tmp
java 20147 openhab 2105u REG 179,2 28280 247594 /var/lib/openhab2/persistence/rrd4j/Consumption.rrd
java 20147 openhab 2106u REG 179,2 28280 247594 /var/lib/openhab2/persistence/rrd4j/Consumption.rrd
java 20147 openhab 2107u REG 179,2 43 247740 /var/lib/openhab2/tmp/imageio4218212574218079016.tmp
java 20147 openhab 2108u REG 179,2 43 247739 /var/lib/openhab2/tmp/imageio1779322582842757726.tmp
java 20147 openhab 2109u REG 179,2 43 247741 /var/lib/openhab2/tmp/imageio1211665275807915698.tmp
I have to leave office right now
I’ll be back :wink:
Monday
I found a smoking gun for your case, your logging shows this:
2017-10-05 16:32:31.123 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.328 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.430 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.470 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.611 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.690 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.168 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:31.969 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.032 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.315 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.387 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.394 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.578 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.615 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.723 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.692 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.646 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.677 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.895 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.937 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:32.949 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.024 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.040 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.048 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.493 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.503 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.552 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.568 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.896 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.815 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.600 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.599 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.598 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.584 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.583 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:33.570 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.120 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.185 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.192 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.217 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.227 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.238 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.244 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.426 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.619 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.687 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.748 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.810 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.890 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.598 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.588 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.586 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.548 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.533 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.907 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:36.935 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.035 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.307 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.078 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.567 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.564 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.535 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.480 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.348 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.332 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.882 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.935 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.008 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.019 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.040 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.808 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.116 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.138 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.168 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.177 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.671 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.650 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.645 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.644 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:37.643 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.352 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.259 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.243 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.635 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.646 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.663 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.693 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.702 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.713 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.728 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.605 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.743 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.520 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.460 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.435 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.373 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.358 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.867 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.918 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.958 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.964 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:38.998 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.270 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.291 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.254 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.213 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.408 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.451 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.548 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.210 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.141 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.137 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.136 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.114 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.086 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.057 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.040 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.038 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.664 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.678 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.688 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.698 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.718 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.767 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.527 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.488 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.459 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.348 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.293 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:40.187 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:40.268 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:40.299 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:40.309 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:40.138 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.948 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.921 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.919 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.913 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.912 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.882 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
2017-10-05 16:32:39.839 [WARN ] [thome.ui.internal.chart.ChartServlet] - Illegal argument in chart: No Persistence service found.
And if you look at: smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/chart/ChartServlet.java at master · eclipse-archived/smarthome · GitHub
It looks like a plausible place for those image to be left open
Can you say in detail where you see a resource being left open? BufferedImage is not a Closable object, so I do not see where a resource leak can originate from that code…
Then the train stopped, so I had to stop looking, I’m expecting mildly that it could be somewhere inside the provider. I didn’t mean that I found it, just the combination of “imageio5104763224528198381.tmp” files and these log look like an interesting combination to me, I was about look into the builder used inside the provider but could not find the source quickly, so I will be looking at the decompiled one first :slight_smile:
Edit: some typos
From smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/chart/ChartServlet.java at master · eclipse-archived/smarthome · GitHub I end up at the following code fragment in javax.imageio:
 public FileCacheImageOutputStream(OutputStream stream, File cacheDir)
     throws IOException {
	if (stream == null) {
		throw new IllegalArgumentException("stream == null!");
	if ((cacheDir != null) && !(cacheDir.isDirectory())) {
		throw new IllegalArgumentException("Not a directory!");
	this.stream = stream;
	if (cacheDir == null)
		this.cacheFile = Files.createTempFile("imageio", ".tmp").toFile();
	else
		this.cacheFile = Files.createTempFile(cacheDir.toPath(), "imageio", ".tmp")
							  .toFile();
	this.cache = new RandomAccessFile(cacheFile, "rw");
	this.closeAction = StreamCloser.createCloseAction(this);
	StreamCloser.addToQueue(closeAction);
Looking at it, I would say that it could maybe also be a consequence of an almost out-of-memory or other system problems. The code which I copied is part of the JDK so it should be rather unique if it gives problems, although I do not really like the part where the implementation states that it closes the images when the vm closes, so I prepared a PR: [ui/Charts] Explicitly close the image output-stream, using a try-with-resources by martinvw · Pull Request #4380 · eclipse-archived/smarthome · GitHub
I think this is not the only problem which you are facing so maybe a heap-dump will give more insights.
Please also not limit yourself to a lot of these lines, but give me/us a text file with all of them, because to me they do not look the same :slight_smile:
I can provide now a clean ‘bug shot’, which can be downloaded here:
http://kulturnetz-drensteinfurt.de/Medien/Log4HABDebug_02.zip
It includes a readme describing how the error has been reproduced.
If you need additional information please give me some instructions what has to be dumped from the raspberry.
That is interesting so its all about the non closed connections, because the number of graphs being left behind is really limited.
And you are running openHABian with the Zulu jdk?
Can others reproduce this easily?
I would really be interested in a heap dump but can’t find what tools are supported by zulu for that, can you validate whether this works: https://stackoverflow.com/questions/407612/how-to-get-a-thread-and-heap-dump-of-a-java-process-on-windows-thats-not-runnin
Can you also run:
lsof -P
lsof -n
Whatever gets the real values of the ports instead http-alt I assume its just 8080 but its good to know for sure :slight_smile:
I’m Running a Zulu for PIZeroW
pi@MeteringPiZeroW:~ $ java -version
openjdk version "1.8.0_121"
OpenJDK Runtime Environment (Zulu Embedded 8.20.0.42-linux-aarch32hf) (build 1.8.0_121-b42)
OpenJDK Client VM (Zulu Embedded 8.20.0.42-linux-aarch32hf) (build 25.121-b42, mixed mode, Evaluation)
and a HotSpot for PI3
pi@MeteringPiRed:~ $ java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
On both PIs the same behaviour. As soon as the Chrome Refresh is pressed the problem occurs.
Here are the Download Links for the PI3 Heaps:
http://kulturnetz-drensteinfurt.de/Medien/heap_01.bin
http://kulturnetz-drensteinfurt.de/Medien/heap_02.bin
