- Platform information:
- Hardware: KVM VM on AMD
- OS: Ubuntu 24.10
- Java Runtime Environment: openjdk version “17.0.14” 2025-01-21
- openHAB version: 4.3.3
- Issue of the topic: Installation of Jython for automation does not work
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
Hi there - I’ve installed Jython automation based on this topic: Ivan’s Helper Libraries - OH3, Python, JavaScript
Starting openhab after going thru these steps the following errors could be seen in the log:
| 14:38:42.779 | DEBUG | org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl | Added ScriptEngine for language ‘py’ with identifier: /etc/openhab/automation/jsr223/python/core/components/100_StartupTrigger.py |
| 14:38:42.780 | INFO | org.openhab.binding.velux.internal.bridge.slip.SlipVeluxBridge | sending command GW_GET_SCENE_LIST_REQ |
| 14:38:42.800 | ERROR | org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl | Error during evaluation of script ‘/etc/openhab/automation/jsr223/python/core/components/100_StartupTrigger.py’: ImportError: No module named core in /etc/openhab/automation/jsr223/python/core/components/100_StartupTrigger.py at line number 9 |
Running my own script ends with similar error: 14:41:44.221 DEBUG org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler Executing pre-compiled script of rule with UID ‘ed1249e5db’
14:41:44.247 ERROR org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler Script execution of rule with UID ‘ed1249e5db’ failed: ImportError: No module named core in
14:41:44.248 DEBUG org.openhab.core.automation.internal.RuleEngineImpl The rule ‘ed1249e5db’ is executed.
Is there any other way to install Jython automation and especially the helper libraries? The topic regarding Ivans helper libraries is from 2021 and describes openhab2 and openhab version 3.
Thanks for any help and best regarda, Falk
