OK, this approach breaks it down quite nicely.
What do you mean with “more complex” functions? I would have thought that the 3 buttons triggering an ON
/OFF
signal are quite straight forward?
On first read, I misinterpreted the description of the buttons needing multiple different pushes some of which trigger rules.
I see it now, and you’re right. The function should be fairly easy to add in if the buttons are just sending simple ON/OFF commands.
OK. Then I will come back once the first card is set up and working as desired.
Thank you for the support!
OK, this is where I got so far.
All content is hard coded so far as I want to get the styling right.
I am not 100% sure whether my approach behaves nicely on different screens (smartphone, tablet, 4k monitor).
What I can see on my phone as an example is that the “Wachstumsphase” (Growth phase) label is moving on top of the toggle button as soon as there is not enough space. The card looks “denser” on my phone. The screenshot here is from a 4k monitor.
How can I influence the background image? I.e. make it opaque or darker? With oh-location-card it is straight forward as you can set a brightness
property. But how does it work with f7-cards?
uid: plantCard
tags: []
props:
parameters: []
timestamp: Oct 10, 2023, 3:02:35 PM
component: f7-card
style:
border-radius: 20px
background: url(/static/baddg.jpg)
background-size: cover
height: 200px
width: 344px
--font-size-title: 24px
--font-weight-title: 740
--font-size-location: 20px
--font-color-addInfo: rgb(200,200,200)
--font-size-addInfo: 13px
--font-weight-addInfo: 400
slots:
default:
- component: f7-row
style:
height: 100%
slots:
default:
- component: f7-col
style:
width: 50%
height: 100%
padding-top: 15px
padding-left: 35px
slots:
default:
- component: f7-row
style:
align-content: flex-start
height: 50%
slots:
default:
- component: Label
style:
width: 100%
font-size: var(--font-size-title)
font-weight: var(--font-weight-title)
text: Drachenpalme
- component: Label
style:
font-size: var(--font-size-location)
text: Erdgeschoss
- component: f7-row
style:
height: 45%
display: flex
align-content: flex-end
slots:
default:
- component: Label
style:
width: 100%
color: var(--font-color-addInfo)
font-size: var(--font-size-addInfo)
font-weight: var(--font-weight-addInfo)
text: Gießen in 5 Tagen
- component: Label
style:
text: Düngen in 17 Tagen
- component: f7-col
style:
width: 50%
height: 100%
padding-top: 20px
padding-right: 5px
slots:
default:
- component: f7-row
style:
justify-content: flex-end
height: 50%
slots:
default:
- component: oh-icon
style:
padding-right: 10px
icon: iconify:mdi:watering-can
color: blue
height: 45px
style:
padding-right: 20px
icon: iconify:game-icons:fertilizer-bag
color: green
height: 40px
- component: f7-row
style:
height: 45%
display: flex
align-items: center
slots:
default:
- component: Label
style:
padding-right: 15px
text: Wachstumsphase
- component: oh-toggle
item: Debug_Knopf
color: '=(items[Debug_Knopf].state == "ON") ? "" : "green"'
Looks like a great start.
This is, in my opinion, the hardest part of styling. In particular font size. There are a couple of ways you might want to try and handle this.
- You’re forcing the font sizes with your css variables. But there are already built in f7 font size variables that you could use instead if you prefer: CSS Variables Reference | Framework7 Documentation many of these will be auto-calculated by the f7 library to be responsive to both mobile and desktop views.
- You can use the
device
object in your widget to respond to a desktop vs mobile display.device.desktop
will be true on desktop browsers and false on mobile so you could define your font size css variables like this
--font-size-title: =(device.desktop)?('24px'):('16px')
Other than that I find that relying more of flex spacing than absolute width and height of containers helps with responsive design. That will probably help you with the problem of the text over-running the switch component.
You can always take a look at how the oh version of a component is defined to get an idea. In this case the location cards come from the base model card here, and the background is not actually a background setting, it is an image in the f7 header:
You can use html tags as components too, so you can put your own img
in the card and apply a style directly to that image. You’ll just have to adjust the positioning of the first f7-row
after that to be absolutely positioned over the image.
- component: f7-card
slots:
default:
- component: img
src: /static/baddg.jpg
style:
filter: brightness(25%)
If you want to keep the image as a background style of the card, then it gets a little trickier. Applying a filter to a background image directly is not something that’s supported in css to my knowledge, so you’ll have to find some clever work-around. My first instinct would be to stack backgrounds. You can define more than one background with css, so you can probably define the image as the lower background and then a solid black background above that with an alpha value that would serve to turn down the brightness of the image.
Wonderful! Thank you for the kind feedback. It really motivates me going further.
So you mean the width: 50%
or height: xyz%
directives for the rows/columns should be avoided and in the best case one only uses the align-items
, justify-content
and align-content
properties to get a smooth experience?
That’s what I do for most of my widgets. Here’s a really helpful resource to give you an idea of everything you can do with flexbox alignment:
So, regarding the background image I decided to use the “overlay” approach. Inside the development environment it looks as expected:
But when looking at it on an overview page the black layer is above all other layers:
What we can also see is that the flex-spacing is somehow ignored. The same happens on my phone.
Any idea why?
uid: plantCard
tags: []
props:
parameters: []
timestamp: Oct 11, 2023, 11:14:06 AM
component: f7-card
style:
border-radius: 20px
height: 200px
width: calc(340px - 2*var(--f7-card-header-padding-horizontal))
--font-size-title: 22px
--font-size-location: 18px
--font-size-addInfo: =(device.desktop)?('12px'):('10px')
display: flex
flex-wrap: wrap
slots:
default:
- component: f7-block
style:
position: absolute
top: -16px
width: 100%
height: 100%
background: rgba(0, 0, 0, 0.4)
border-radius: 20px
- component: f7-row
style:
position: absolute
top: 0
left: 0
slots:
default:
- component: f7-col
style:
width: 48%
height: 100%
padding-top: 15px
padding-left: 35px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
- component: Label
style:
width: 100%
text: Drachenpalme
- component: Label
style:
text: Erdgeschoss
- component: f7-row
style:
height: 45%
display: flex
slots:
default:
- component: Label
style:
width: 100%
- component: Label
style:
- component: f7-col
style:
width: 52%
height: 100%
padding-top: 20px
padding-right: 5px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
style:
padding-right: 10px
color: blue
height: 45px
style:
padding-right: 5px
color: green
height: 40px
- component: f7-row
style:
height: 45%
display: flex
align-items: center
slots:
default:
- component: Label
style:
padding-right: 15px
style:
transform: =(device.desktop)?'':'scale(0.8)'
item: Debug_Knopf
Edit: I realized I have to add a top: -16px
property to the f7-block
otherwise the black image won’t cover the whole picture. This seems a litte bit odd to me. I’d also like to know why I need to do this. Any suggestions?
This one perfectly good solution. In fact, if you do this, then you don’t need the extra f7-block
, just set the background on your first f7-row
(you’ll also need to set border-radius on the row to match the card, 20px, if I recall, and give it 100% height and width).
My guess is that this will fix both of the problems you are seeing.
It shouldn’t happen that the editor view and the display view are any different, but I’ve seen a couple of examples of it over time. It just means that there’s some upstream css setting in the main window that is for some reason overriding one on your card. The flex styling is still working, but instead of you f7-row
being the full height of the card, it’s height is reduced. That’s why I suspect that the fix above will fix the issue: it explicitly sets the height of that first f7-row
explicitly.
So… I’d say the widget is ready for now and it behaves as I want it to behave.
This is the code containing still some hard-coded parts as I don’t have access to item labels when not using oh-repeater
uid: plantCard
tags: []
props:
parameters:
- context: item
description: Die zu pflegende Pflanze
label: Pflanze
required: true
type: TEXT
timestamp: Oct 12, 2023, 3:11:14 PM
component: f7-card
style:
border-radius: 20px
height: 200px
display: flex
flex-wrap: wrap
slots:
default:
- component: f7-row
style:
position: absolute
height: 100%
width: 100%
border-radius: 20px
slots:
default:
- component: f7-col
style:
width: 48%
height: 100%
padding-top: 15px
padding-left: 35px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
- component: Label
style:
width: 100%
color: white
text: Testpflanze
- component: Label
style:
color: white
text: Erdgeschoss
- component: f7-row
style:
height: 45%
display: flex
slots:
default:
- component: Label
style:
width: 100%
text: "= (@(props.plant + '_TageBisGiessen') > 1) ? 'Gießen in ' + @(props.plant + '_TageBisGiessen') + ' Tagen' : (@(props.plant + '_TageBisGiessen') == 1) ? 'Morgen gießen' : ''"
- component: Label
style:
text: "= (@(props.plant + '_TageBisDuengen') > 1) ? 'Düngen in ' + @(props.plant + '_TageBisDuengen') + ' Tagen' : (@(props.plant + '_TageBisDuengen') == 1) ? 'Morgen düngen' : ''"
- component: f7-col
style:
width: 52%
height: 100%
padding-top: 20px
padding-right: 5px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
- component: oh-button
style:
height: auto
icon-f7: drop_fill
iconSize: 40
iconColor: "=(items[props.plant + '_Giessen'].state == 'ON') ? 'blue' : 'gray'"
action: toggle
actionCommand: ON
actionCommandAlt: OFF
actionItem: = props.plant + '_Giessen'
tooltip: Pflanze gegossen
style:
height: auto
icon-f7: eyedropper_full
iconSize: 40
iconColor: "=(items[props.plant + '_Duengen'].state == 'ON') ? 'green' : 'gray'"
action: toggle
actionCommand: ON
actionItem: = props.plant + '_Duengen'
tooltip: Pflanze gedüngt
- component: f7-row
style:
height: 45%
display: flex
align-items: center
slots:
default:
- component: Label
style:
padding-right: 15px
style:
transform: =(device.desktop)?'':'scale(0.75)'
item: = props.plant + '_Ruhephase'
color: green
Now comes the tricky part. I’d like to use oh-repeater
in order to iterate through all plants. A plant can be detected by the non-semantic tag ["Plant"]
What’s the logic on the styling side to get as many plant cards drawn as plants do exist?
My current thoughts are from a hierarchical perspective in pseudo-code:
f7-block # Main container carries all cards and makes sure that the cards are aligned correctly depending on the screen width
style:
flex-wrap: wrap # Wrap cards for smaller screens
slots:
default:
- component: oh-repeater
sourceType: itemsWithTags
itemTags: Plant # To only get plants
slots:
default:
# and from here on simply pasting the code from above starting at the f7-card??????
style:
border-radius: 20px
background: url(...) # url from item's metadata
Would this work?
That’s pretty much the approach I would take. You just have to make sure you understand the loop object that results from the repeater call.
If you want to see it, you can use the API explorer and use the items end point with the plant tag and correct metadata namespace. That should return the same JSON object that the repeater will use.
Hooray! We are getting there!
Two questions I have:
- To get the location I’m currently doing quite an ugly hack. In my model the location is the 2nd group a plant is member of and each location has the following naming schema: “Location_Somelocation”. In German it is “Ort_Wohnzimmer” as an example. Due to this I can create a correct label with:
loop.item.groupNames[1].replace("Ort_", "")
However, is there a more generic solution which is using the semantic model like
loop.item.location.label
(which does not work unfortunately)?
- The positioning of the cards is not correct at the moment. They are all stacked inside a column and I can only move the column. The
flex-direction: row
property seems to be ignored. Any idea why?
I would expect the cards to be next to each other.
uid: plantCards
tags: []
props:
parameters:
- context: item
description: Die zu pflegenden Pflanzen
label: Pflanze
required: true
type: TEXT
timestamp: Oct 13, 2023, 11:20:49 AM
component: f7-block
style:
display: flex
flex-direction: row
flex-wrap: wrap
justify-content: space-around
slots:
default:
for: item
itemTags: Plant
slots:
default:
style:
border-radius: 20px
height: 200px
display: flex
flex-wrap: wrap
slots:
default:
- component: f7-row
style:
position: absolute
height: 100%
width: 100%
border-radius: 20px
slots:
default:
- component: f7-col
style:
width: 48%
height: 100%
padding-top: 15px
padding-left: 35px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
- component: Label
style:
width: 100%
color: white
text: =loop.item.label
- component: Label
style:
color: white
text: =loop.item.groupNames[1].replace("Ort_", "")
- component: f7-row
style:
height: 45%
display: flex
slots:
default:
- component: Label
style:
width: 100%
text: "= (@(loop.item.name + '_TageBisGiessen') > 1) ? 'Gießen in ' + @(loop.item.name + '_TageBisGiessen') + ' Tagen' : (@(loop.item.name + '_TageBisGiessen') == 1) ? 'Morgen gießen' : ''"
- component: Label
style:
text: "= (@(loop.item.name + '_TageBisDuengen') > 1) ? 'Düngen in ' + @(loop.item.name + '_TageBisDuengen') + ' Tagen' : (@(loop.item.name + '_TageBisDuengen') == 1) ? 'Morgen düngen' : ''"
- component: f7-col
style:
width: 52%
height: 100%
padding-top: 20px
padding-right: 5px
slots:
default:
- component: f7-row
style:
height: 50%
slots:
default:
style:
height: auto
icon-f7: drop_fill
iconSize: 40
iconColor: "=(items[loop.item.name + '_Giessen'].state == 'ON') ? 'blue' : 'gray'"
action: toggle
actionCommand: ON
actionItem: = loop.item.name + '_Giessen'
style:
height: auto
iconSize: 40
iconColor: "=(items[loop.item.name + '_Duengen'].state == 'ON') ? 'green' : 'gray'"
action: toggle
actionCommand: ON
actionItem: = loop.item.name + '_Duengen'
- component: f7-row
style:
height: 45%
display: flex
align-items: center
slots:
default:
- component: Label
style:
padding-right: 15px
style:
item: = loop.item.name + '_Ruhephase'
color: green
Nope, no matter which way you get the parent semantic group (you could also use the semantic metadata) you will only get the name of the location group, not the label. So, you would still be required to create the label from the item name.
This is a little tricky. The default configuration for a repeater has all the repeated elements inside an additional div
container. So your flex settings are not being ignored, but that root f7-block
has only one child which is that container div
and that container doesn’t have any flex settings. The solution to this is to add fragment: true
to your repeater config
this will remove that extra container and all your cards will be direct children of the root block and be subject to it’s flex directives.
Ok. So many fine details to take care of.
Nevertheless, I think I‘m done so far. I‘ll give it a test and finalize some smaller details. After that I shall provide the widget to the marketplace.
Highly appreciate your support @JustinG
Hey, I could still need some help regarding the background images of the card. I fail to retrieve the image dynamically.
The data structure for the items to be looped through in the oh-repeater looks as follows:
Group thePlant
"The plant"
(AllPlants)
["Plant", "The location"]
image=" " [link="/static/plants/aNeatPicture.jpg"]
When using this widget config:
for: item
fragment: true
itemTags: Plant
fetchMetadata: image
slots:
default:
style:
background: url(loop.item.metadata.image.config.link)
The cards do not show any background.
When using a hard link to an image like this:
background: url(/static/plants/aNeatPicture.jpg)
a picture is shown.
When debugging with a label
text: =loop.item.metadata.image.config.link
it shows for the test item:
So the link is correctly retrieved.
Where is the error? :-/
The trick here is that you need an expression that that will evaluate to the string "url(/static/plants/aNeatPicture.jpg)"
. So first, the yaml value has to start with an =
, and then you need to use that expression to build the string. There are a few ways to do this, I would recommend using a string template:
background: =`url(${loop.item.metadata.image.config.link})`
Inside the ``
everything is treated as a string except for the expressions inside ${ }
which are evaluated.
Thank you again. That was it. Now the widget looks finalized (for now). I will make a post on the marketplace soon.
Errm… it’s me again. I did some more tweaks to the widget inspired and a lot copycatted by OH3 - Expandable F7-card - Add-ons / UIs - openHAB Community
Again I tried to come up with the logic that I only assign all my plants in one group to the widget and it draws all the cards.
This works and looks nicely in the widget development area but does not really work on the main page. Clicking on a card on the main page only shows the card content in a blurred way. Clicking anywhere will close the card and everything looks as initially. I tried to play with the z-index
but that did not really work out.
Any idea?
Here the card looks nicely inside the dev tools:
Clicking on a card when the widget is on the main page looks like this:
The code:
uid: plant_cards
tags: []
props:
parameters:
- context: item
label: Pflanze
required: true
type: TEXT
parameterGroups: []
timestamp: Oct 17, 2023, 2:35:21 PM
component: f7-block
style:
display: flex
flex-direction: row
flex-wrap: wrap
z-index: 100
slots:
default:
for: item
fragment: true
itemTags: Plant
slots:
default:
expandable: true
swipeToClose: true
backdrop: true
class:
- card-expandable-animate-width
style:
height: 200px
width: 320px
--font-size-addInfo: 12px
--font-size-location: 22px
--mobileVerticalOffset: =(device.desktop)?('10px'):('40px')
slots:
default:
icon-f7: ellipsis
iconSize: 30px
color: black
style:
position: absolute
bottom: 5px
right: 0
padding-top: 10px
padding-bottom: 35px
z-index: 90
class:
- cell-open-button
- card-opened-fade-out
class:
- card-closed-fade-in
- card-prevent-open
action: toggle
actionCommand: ON
icon-f7: drop_fill
iconSize: 40
style:
height: auto
position: absolute
top: 10px
right: 65px
z-index: 90
class:
- card-prevent-open
action: toggle
actionCommand: ON
iconSize: 40
style:
height: auto
position: absolute
top: 10px
right: 15px
z-index: 90
- component: f7-card-content
style:
width: 100%
slots:
default:
class:
- card-opened-fade-in
- card-closed-fade-out
action: toggle
actionCommand: ON
icon-f7: drop_fill
iconSize: 40
style:
height: auto
position: absolute
top: var(--mobileVerticalOffset)
right: 105px
z-index: 90
class:
action: toggle
actionCommand: ON
actionItem: loop.item.name + '_Duengen'
iconSize: 40
style:
height: auto
position: absolute
right: 45px
z-index: 90
iconF7: xmark_circle_fill
iconSize: 30px
color: black
style:
position: absolute
right: 0
padding-top: 10px
z-index: 90
class:
- cell-close-button
- card-close
class:
- no-padding
style:
height: 200px
style:
position: absolute
height: 216px
width: 100%
top: 0
class:
- no-padding
style:
height: 200px
position: absolute
top: 15px
left: 30px
slots:
default:
- component: f7-row
style:
height: 75px
display: flex
flex-direction: row
flex-wrap: wrap
slots:
default:
- component: f7-col
style:
width: 50%
slots:
default:
- component: Label
style:
padding-top: 15px
- component: Label
text: "=loop.item.tags[1] == 'Plant' ? loop.item.tags[0] : loop.item.tags[1]"
style:
- component: f7-row
style:
height: 110px
white-space: nowrap
flex-wrap: nowrap
align-items: flex-end
slots:
default:
- component: f7-col
slots:
default:
- component: Label
text: "= (items[loop.item.name + '_TageBisGiessen'].state > 1) ? 'Gießen in ' + items[loop.item.name + '_TageBisGiessen'].state + ' Tagen' : (items[loop.item.name + '_TageBisGiessen'].state == 1) ? 'Morgen gießen' : 'Heute gießen'"
style:
- component: Label
text: "= (items[loop.item.name + '_TageBisDuengen'].state > 1) ? 'Düngen in ' + items[loop.item.name + '_TageBisDuengen'].state + ' Tagen' : (items[loop.item.name + '_TageBisDuengen'].state == 1) ? 'Morgen düngen' : 'Heute düngen'"
visible: = items[loop.item.name + '_TageBisDuengen'].state != 999
style:
class:
- card-prevent-open
- card-content-padding
style:
height: 300px
z-index: 110
slots:
default:
- component: oh-list
class:
- padding
slots:
default:
- component: oh-list-item
title: Gießen notwendig
item: Testpflanze_Giessen
icon: f7:drop
iconColor: "=(items[loop.item.name + '_Giessen'].state == 'ON') ? 'blue' : 'white'"
after: "=(items[loop.item.name + '_Giessen'].state == 'ON') ? 'Ja' : 'Nein'"
title: Düngen notwendig
item: Testpflanze_Duengen
icon: f7:eyedropper
iconColor: "=(items[loop.item.name + '_Duengen'].state == 'ON') ? 'green' : 'white'"
after: "=(items[loop.item.name + '_Duengen'].state == 'ON') ? 'Ja' : 'Nein'"
- component: Label
text: Gießplanung
style:
padding: 7px
border-bottom: 1px solid grey
font-weight: 600
color: gray
margin-top: 10px
- component: oh-stepper-item
item: = loop.item.name + '_TageBisGiessen'
title: Tage bis Gießen
icon: f7:calendar
color: blue
raised: true
round: true
autorepeat: true
autorepeatDynamic: false
enableInput: true
fill: true
item: = loop.item.name + '_TageBisDuengen'
title: Tage bis Düngen
icon: f7:calendar
color: blue
raised: true
round: true
autorepeat: true
enableInput: true
fill: true
- component: oh-toggle-item
title: Wachstumsphase
icon: f7:sun_max
color: green
iconColor: yellow
item: = loop.item.name + '_Wachstumsphase'
- component: Label
text: Gieß- und Düngeparameter
style:
padding: 7px
font-weight: 600
color: gray
margin-top: 10px
item: = loop.item.name + '_Giessintervall_Wachstumsphase'
title: Gießintervall Wachstumsphase
icon: f7:drop_fill
iconColor: blue
color: blue
raised: true
round: true
autorepeat: true
enableInput: true
fill: true
item: = loop.item.name + '_Giessintervall_Ruhephase'
title: Gießintervall Ruhephase
icon: f7:drop
iconColor: blue
color: blue
raised: true
round: true
autorepeat: true
enableInput: true
fill: true
item: = loop.item.name + '_Duengeintervall_Wachstumsphase'
title: Düngeintervall Wachstumsphase
icon: f7:eyedropper_full
iconColor: green
color: blue
raised: true
round: true
autorepeat: true
enableInput: true
fill: true
item: = loop.item.name + '_Duengeintervall_Ruhephase'
title: Düngeintervall Ruhephase
icon: f7:eyedropper_halffull
iconColor: green
color: blue
raised: true
round: true
fill: true
I’ve seen reports of this sort of thing before. I’ve never really looked into it so I don’t know the exact source of the issue. I think that the reason there’s a difference between what you see in the two views is that the overview page is only sort of a real page, it’s a tab within the home page, and this means that there are some style settings and that have different directives and some different page architecture as well.
For the time being you should just be able to set backdrop: false
on your cards instead and that should disable the blurring so that you don’t see the issue.
If I have a chance I’ll look into more sometime soon.
Yeah, I can live with this workaround.
