I built my first expandable f7-card, which works almost as expected.
However I need your help to sort out some points:
I’m not sure the approach I use to expand the card is correct. I suppose the design can be simplified and improved. I guess the css classes are not used properly.
The items aligned on the right site of the card (Gauge and Grass Icon) are not at the right position when the card is collapsed again
Correct - before the card was expanded:
Wrong: after the card was closed: The Icon and Gauge moved out the visible area.
- The icon to close the expanded card does not work and is stretched
Thanks for any hint ![]()
Below is the code I use - still with dummy item entries for testing.
uid: widget_Bewaesserung_v1-3
tags: []
props:
parameters:
- description: A text prop
label: Prop 1
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Mar 13, 2021, 6:56:54 PM
component: f7-card
expandable: true
swipeToClose: true
backdrop: true
class:
- no-padding
style:
height: 200px
margin: 10px
box-shadow: var(--f7-card-expandable-box-shadow)
slots:
default:
- component: oh-button
iconF7: gear
iconSize: 30px
color: black
style:
position: absolute
top: 0
right: 0
padding-top: 10px
padding-bottom: 35px
z-index: 999
class:
- cell-open-button
- card-opened-fade-out
- float-right
iconF7: xmark_circle_fill
iconSize: 30px
color: black
style:
position: absolute
top: 0
right: 0
padding-top: 10px
z-index: 999
class:
- card-opened-fade-in
- cell-close-button
- float-right
- component: oh-link
action: toggle
actionItem: Bewaesserung_Rasen_Schalter
actionCommand: ON
actionCommandAlt: OFF
class:
- card-prevent-open
style:
width: 100%
height: 200px
position: absolute
top: 0
left: 0
z-index: 0
- component: f7-card-content
style:
width: 100%
slots:
default:
- component: f7-icon
material: grass
color: green
style:
position: absolute
right: 3%
top: 120px
opacity: 40%
- component: f7-block
style:
margin: 0px
height: 200px
slots:
default:
- component: f7-row
class:
- display-flex
- align-items-center
- justify-content-space-between
style:
white-space: nowrap
flex-wrap: nowrap
height: 75px
weight: 100%
slots:
default:
- component: f7-col
style:
height: 75px
width: auto
class:
- display-flex
- flex-direction-column
- align-items-flex-start
slots:
default:
- component: Label
text: Büsche hinten
style:
font-size: 25px
font-weight: 600
- component: f7-chip
text: "=items.Bewaesserung_Rasen_Schalter.state === 'ON' ? 'Bewässerung aktiv' : 'AUS'"
color: "=items.Bewaesserung_Rasen_Schalter.state === 'ON' ? 'green' : 'gray'"
- component: f7-col
style:
margin-top: 15px
width: auto
class:
- display-flex
slots:
default:
- component: oh-gauge
min: 0
max: 90
type: semicircle
value: 40
labelText: 20 min
borderWidth: 20
borderBgColor: "#d2d2d2"
borderColor: "#4287f5"
visible: "=items.Bewaesserung_Rasen_Schalter.state === 'ON' ? true : false"
style:
width: 100%
- component: f7-row
style:
white-space: nowrap
flex-wrap: nowrap
height: 30px
width: 16%
class:
- display-flex
- flex-direction-row
- justify-content-flex-start
slots:
default:
f7: cloud_rain
color: gray
visible: "=items.Bewaesserung_Rasen_Regenautomatik.state === 'ON' ? true : false"
style:
padding-right: 5px
f7: umbrella
color: gray
visible: "=Number.parseInt(items.item_Netatmo_Regen_Niederschlag.displayState) >= 1 ? true : false"
style:
padding-right: 5px
- component: f7-row
style:
flex-wrap: nowrap
height: 10px
width: 180px
class:
- display-flex
slots:
default:
- component: f7-col
style:
width: 40%
class:
- display-flex
slots: {}
- component: f7-row
style:
margin-top: 10px
align-content: flex-end
height: 50px
slots:
default:
- component: f7-col
style:
flex-wrap: nowrap
width: 100%
align-content: flex-start
class:
- display-flex
slots:
default:
- component: f7-row
style:
flex-wrap: nowrap
slots:
default:
f7: alarm
color: blue
visible: "=items.Bewaesserung_Rasen_Timer.state === 'ON' ? true : false"
style:
margin-top: 0px
- component: Label
text: 19. April, 18:30
style:
margin-left: 5px
font-size: 14px
font-weight: 600
f7: timer
color: blue
style:
margin-top: 0px
margin-left: 10px
- component: Label
text: 35min
style:
margin-left: 5px
font-size: 14px
font-weight: 600
- component: f7-row
style:
margin-top: 5px
flex-wrap: nowrap
slots:
default:
material: restore
color: gray
style:
margin-top: 0px
margin-left: 0px
- component: Label
text: 14. April, 18:30
style:
margin-left: 8px
font-size: 12px
color: gray
f7: timer
color: gray
style:
margin-top: 2px
margin-left: 10px
- component: Label
text: 20min
style:
margin-left: 3px
font-size: 12px
color: gray
class:
- card-prevent-open
- card-content-padding
style:
height: 300px
slots:
default:
- component: oh-list
class:
- padding
slots:
default:
- component: oh-stepper-item
title: Ausschalt Timer (min)
item: Bewaesserung_Rasen_Ausschalt_Timer
icon: f7:timer
color: blue
raised: true
round: true
autorepeat: true
autorepeatDynamic: false
min: 0
max: 90
- component: Label
text: =props.Title?props.Title:"Timer Settings"
style:
padding: 7px
border-bottom: 1px solid grey
font-weight: 600
color: gray
margin-top: 10px
- component: oh-toggle-item
title: Timer
icon: f7:alarm
color: green
item: Bewaesserung_Rasen_Timer
- component: oh-input-item
title: Startzeit
type: datepicker
sendButton: true
item: Bewaesserung_Rasen_Timer_Startzeit
outline: false
calendarParams:
timePicker: true
dateFormat:
month: short
day: numeric
hour: numeric
minute: numeric
style:
--f7-input-bg-color: "#ededed"
item: Bewaesserung_Rasen_Timer_Laufzeit
title: Laufzeit (min)
icon: f7:timer
color: blue
raised: true
round: true
autorepeat: true
min: 0
max: 90
item: Bewaesserung_Rasen_Interval
title: Interval (Tage)
icon: f7:arrow_2_circlepath
color: blue
raised: true
round: true
autorepeat: true
min: 0
max: 90
- component: Label
text: =props.Title?props.Title:"Wettersteuerung"
style:
padding: 7px
font-weight: 600
color: gray
margin-top: 10px
title: Regenautomatik
icon: f7:cloud_rain
color: green
item: Bewaesserung_Rasen_Regenautomatik
item: Bewaesserung_Rasen_Regenautomatik_Grenzwert
title: Grenzwert Regen (mm)
icon: f7:chart_bar
color: blue
raised: true
round: true
autorepeat: true
min: 0
max: 90
