Hi together,
since the beginning with openHAB, I connected OH to my knx network in TUNNEL mode through my KNX Weinzierl IP Router 750. The interface supports up to 5 TUNNEL connections, so I’m fine with some other parallel test installations. But at the end of course I’m very interested in working with ROUTER mode.
My network hardware includes:
- FritzBox 7490
- FritzBox 4020
- Netgear GS110 TP
- Netgear GS724Tv4
So at the end my entire network should be prepared for multicast.
I enabled ROUTER mode in openhab.cfg with following entries:
knx:type=ROUTER knx:localIp=192.168.178.167 knx:ignorelocalevents=true
The localIp represents the IPv4 address of my openHAB server. This address I use also if I connect through TUNNEL mode.
Ok, when I start OH with ROUTER mode the connection will be established:
[INFO ] [b.k.i.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
But directly after I get flooded with following log entries:
WARN ] [.b.knx.internal.bus.KNXBinding] - Ignoring local Event, received from my local Source address 0.0.0 for Group address X/X/X
Now my question: Is this only a configuration problem of my switches? I know I can configure it with tons of IGMP settings and I tried already so enable IGMP, but it doesn’t work properly. To be honest - I don’t know which settings I have to enable in my Switches.
Is there someone out there, who is firm with this settings? Here are the two manuals of my switches:
http://www.downloads.netgear.com/files/GS108T_GS110TP_SWA_5Nov10.pdf
http://www.downloads.netgear.com/files/GDC/GS716TV3/GS716Tv3_GS724Tv4_GS748Tv5_SWA_25Sept2013.pdf
thx!
