Hi all,
i have a knx thing with a channel for setting the humidity value for a controller. This was working fine with older versions of openhab. Now with 4.0.3 i got out that the value of the dimmer item can be changed in openhab, but is not send to knx any more. I can listen by ETS on the bus but there are no messages if change happens in openhab.
channels:
- id: FeuchteSollwert
channelTypeUID: knx:dimmer
label: FeuchteSollwert
description: ""
configuration:
increaseDecrease: 9.007:<3/0/4
position: 9.007:<3/0/4
Do i have to change something or is there a problem in knx binding?
The manual tells " Data type for DPT 9.007 (Humidity) has changed from PercentType
to QuantityType
." but i cannot get out if i have to change something.
Could someone help me with this?
