KNX Problem reading property
I get a lot of there errors when changing values in Basic UI (I am openhab beginner):
THINGS:
Bridge knx:ip:bridge [
    ipAddress="192.168.249.103",
    portNumber=3671,
    localIp="192.168.249.114",
    type="TUNNEL",
    readingPause=50,
    responseTimeout=10,
    readRetriesLimit=3,
    autoReconnectPeriod=1,
    localSourceAddr="0.0.0"
    Thing device generic [
        address="1.0.5",
        fetch=true,
        pingInterval=300,
        readInterval=3600
        Type switch        : UG_Gang_Licht        "Light"       [ ga="1/0/200+<1/0/201" ]
Group gWohnzimmer "Wohnzimmer"
Group gKueche "Küche"
Group gSchlafzimmer "Schlafzimmer"
Group gBad "Bad"
Group gGang "Gang"
Group gGarderobe "Garderobe"
Group gTerasse "Terasse"
Group gGarten "Garten"
Switch        UG_Gang_Licht         "Licht [%s]" <light>     (gGang)     { channel="knx:device:bridge:generic:UG_Gang_Licht" }
sitemap knx label="Wohnung" {
    Frame label="Räume" {
    Group item=gWohnzimmer icon="screen"
    Group item=gKueche icon="kitchen"
    Group item=gSchlafzimmer icon="bedroom"
    Group item=gBad icon="bath"
    Group item=gGang icon="corridor"
    Group item=gGarderobe icon="frontdoor"
    Group item=gTerasse icon="terrace"
    Group item=gGarten icon="garden"
2018-08-07 13:25:53.887 [WARN ] [alimero.mgmt.MC 192.168.249.103:3671] - problem reading property (response 43 d6 00 4e 00 01)
tuwien.auto.calimero.KNXRemoteException: property access OI 0 PID 78 failed/forbidden
at tuwien.auto.calimero.mgmt.ManagementClientImpl.extractPropertyElements(ManagementClientImpl.java:986) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.lambda$readProperty$0(ManagementClientImpl.java:570) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.waitForResponses(ManagementClientImpl.java:905) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readProperty(ManagementClientImpl.java:568) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readProperty(ManagementClientImpl.java:535) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.lambda$2(DeviceInfoClientImpl.java:107) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.readFromManagementClient(DeviceInfoClientImpl.java:56) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.readDeviceProperties(DeviceInfoClientImpl.java:105) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInspector.readDeviceProperties(DeviceInspector.java:108) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInspector.readDeviceInfo(DeviceInspector.java:88) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.describeDevice(AbstractKNXThingHandler.java:89) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.lambda$0(AbstractKNXThingHandler.java:153) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-08-07 13:25:54.083 [WARN ] [alimero.mgmt.MC 192.168.249.103:3671] - problem reading property (response 43 d6 00 4e 00 01)
2018-08-07 13:25:54.271 [WARN ] [alimero.mgmt.MC 192.168.249.103:3671] - problem reading property (response 43 d6 00 4e 00 01)
2018-08-07 13:25:54.472 [WARN ] [alimero.mgmt.MC 192.168.249.103:3671] - problem reading property (response 43 d6 00 4e 00 01)
2018-08-07 13:25:54.660 [WARN ] [alimero.mgmt.MC 192.168.249.103:3671] - problem reading property (response 43 d6 00 4e 00 01)
Can you help me, please? Many thanks!
I do not have kxn but you may find this post helpful
https://community.openhab.org/t/knx-binding-2-3/46417
Please set the DPT for the channel:
    portNumber=3671,
    type="TUNNEL",
    readingPause=50,
    responseTimeout=10,
    readRetriesLimit=3,
        address="1.0.5",
        fetch=true,
        pingInterval=300,
        readInterval=3600
        Type switch : UG_Gang_Licht "Light" [ ga="1.001:1/0/200+<1/0/201" ]
as there is a problem that DPT is not optional when using more than one GA per parameter.
