Kostal Inverter (Plenticore plus 10 FW 01.42) no connection
I´ve tried it before with my openhab 2.4;
The configuratio in paper UI looks a little bit different there.
I also was not able to establish a connection as I always got an error regarding a wrong index.
BR Stefan
Hi guys,
as I pointed out in my github issue (see [kostal-inverter] Cannot connect to PLENTICORE PLUS 10.0 · Issue #7492 · openhab/openhab-addons · GitHub), there is a known issue for Java with cryptographic settings for Java versions older than 1.8_u162. I found out that this actually makes the authentication code crash. The code itself is correct, only the Java runtime settings are broken.
You are welcomed to join the issue discussion on GitHub.
Best wishes
Marco
Hi!
Problem is solved!
Just updated the java on my PI via the openhab-config tool. (1.8.0_152 → 1.8.0_252)
THX for the help and the hint!
Hi guys,
I’m on OH 3.0 an get the same issue here.
Java 11 installed.
Binding goes to “UNKNOWN” and that’s it :frowning:
In the log, I found an error message:
021-01-22 18:20:32.872 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Expected closing bracket for IPv6 address at index 13: http://[http://192.168.6.3//api/v1/processdata]
at java.net.URI.create(URI.java:883) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:442) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:431) ~[?:?]
at org.openhab.binding.internal.kostal.inverter.thirdgeneration.ThirdGenerationHttpHelper.executeHttpPost(ThirdGenerationHttpHelper.java:84) ~[?:?]
at org.openhab.binding.internal.kostal.inverter.thirdgeneration.ThirdGenerationHandler.updateChannelValues(ThirdGenerationHandler.java:155) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
Caused by: java.net.URISyntaxException: Expected closing bracket for IPv6 address at index 13: http://[http://192.168.6.3//api/v1/processdata]
at java.net.URI$Parser.fail(URI.java:2913) ~[?:?]
at java.net.URI$Parser.failExpecting(URI.java:2919) ~[?:?]
at java.net.URI$Parser.parseServer(URI.java:3292) ~[?:?]
at java.net.URI$Parser.parseAuthority(URI.java:3216) ~[?:?]
at java.net.URI$Parser.parseHierarchical(URI.java:3158) ~[?:?]
at java.net.URI$Parser.parse(URI.java:3114) ~[?:?]
at java.net.URI.<init>(URI.java:600) ~[?:?]
at java.net.URI.create(URI.java:881) ~[?:?]
... 10 more
I seems, as if there’s an error with IPv6 based on this message:
can now answer the issue by myself.
you have to ommit the “http://” in the IP-adress field.
Now it works, bur I think, at least a note/comment beside the field would be fine, or automatically strip the “http://” before processing.
Hi Jörg,
Thank you for the information!
Out of your message I conclude that the binding is nk working well with OH 3?
BR Stefan
Hi Stefan,
yes, the binding is now working in my my OH 3.0 test environment.
But I still don’t get it working in my 2.5. production environment.
There’s another issue.
I cannot setup the thing, as I get an “Error 500” as soon as I select the Plenticore Plus 8.5 and there are no fields to enter IP, username, etc.
Just name, ID, location.
I allready uninstalled an reinstalled without any success.
Will try to get more infos by enabeling DEBUG level
Thanks for your efforts in developing an maintaining this binding.
Joerg
Hi @pfoerti10,
I still cannot install things (in this case Plenticore PLUS 8.5 with battery) in OH 2.5.
Even after deleting cache and tmp and reboot, I get the same Errorr 500 with lack of the fields IP, password, …
I enabled DEBUG, but I don’t see any debug message from binding.
What is the latest version for 2.5.x? IS there a jar for download?
Thanks Joerg
Am I running in the same issue as here:
https://github.com/openhab/openhab-addons/issues/7090
Is this bug still not resolved?
Can’t you install things on general, or only in the kostal binding?
Unfortunately the bug with simultaneous use of Zwave and Kostal binding isn’t resolved until now. The bug also exists in OH3. I uninstalled the Kostal binding and integrated the inverter via modbus binding. It’s a lot of work instead of using the Kostal binding, but it works.
@pfoerti10 : It only regards adding things from Kostal binding while Zwave binding is installed simultaneously.
Hi @pfoerti10,
can confirm. Only Kostal things. Error 500 and fields mentioned above are missing.
@torsten,
while waiting for feedback from @pfoerti10, can you share some information on your modbus implementation?
Thanks Joerg
Hi Jörg,
so you have installed the Zwave binding also which means you´re having the issue linked and also described by torsten, right?
I´m afraid I don´t know how to help currently, I´m not using Zwave so far;
But I saw this is also discussed here
BR
Ah,
sry just recognized the linked discussion had a dead end and is from April,
my apologies…
Hi @pfoerti10,
maybe @chris as Zwave binding maintainer has an idea, why and how the Kostal and the Zwave binding can interfere.
Joerg
I found a workaround to get both bindings running.
Uninstall the Z-Wave binding. Just the binding, already configured things are kept and will work again after reinstalling.
Now, you can install/configure the Kostal binding/things/channels/items.
Afterwards reinstall the Z-Wave binding.
All configured Kostal and Z-Wave items will still work afterwards.
For changing anything of Kostal binding, you have to uninstall the Z-Wave binding again temporarily.
Not nice but at least both binding are running together until the bug is fixed.
Joerg
Hi all,
just want to let you know, that -thanks to basse04 the issue is solved at least for OH 3.1. and up.
See github issue #7090
Joerg
I am having the issue (OH 3.2) also:
I set the url to the IP (not including http:/).
Thing ‘kostalinverter:PLENTICOREPLUS70WITHOUTBATTERY:PlenticoreUI’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Error during the initialisation of the authentication
Thing ‘kostalinverter:PLENTICOREPLUS70WITHOUTBATTERY:PlenticoreUI’ changed from OFFLINE (COMMUNICATION_ERROR): Error during the initialisation of the authentication to OFFLINE (COMMUNICATION_ERROR): HTTP communication error: No response from device
Also did a Restart with the last configuration.
I get “Wrong password”, if I enter the wrong password - so the IP is fine. Software: MC-Version: 01.57
I would be grateful for some help!
Florian
same problem here after updating to Openhab 3.3:
Thing ‘kostalinverter:PLENTICOREPLUS55WITHBATTERY:74718620f9’ changed from OFFLINE (COMMUNICATION_ERROR): Error during the initialisation of the authentication to OFFLINE (COMMUNICATION_ERROR): HTTP communication error: No response from device
After another downgrade to 3.2 it works again.
Any idea how to solve this problem?
Greetings
