I usually use lambda functions of the following form in my calculations to make the code cleaner if items must be handled with a default value like 0 if they carry NULL:
val Functions$Function1 < GenericItem, Float > nvlFloat = [ theItem |
var Float theValue = 0.0f
if (theItem.state != NULL) theValue = theItem.getStateAs(DecimalType).floatValue
theValue
val Functions$Function1 < GenericItem, Integer > nvlInt = [ theItem |
var int theValue = 0
if (theItem.state != NULL) theValue = theItem.getStateAs(DecimalType).intValue
theValue
The usage of those functions look like this:
if (
( (nvlInt.apply(I_Wetter_AktuellID) >= 800 && nvlInt.apply(I_Wetter_AktuellID) <= 802)
|| (nvlInt.apply(I_Wetter_3Stunden_VorhersageID) >= 800 && nvlInt.apply(I_Wetter_3Stunden_VorhersageID) <= 802)
|| (nvlInt.apply(I_Wetter_6Stunden_VorhersageID) >= 800 && nvlInt.apply(I_Wetter_6Stunden_VorhersageID) <= 802)
sunForecasted = true
if (nvlFloat.apply(I_EG_WZ_Ofenthermometer_Ofen) > 40.0 && nvlFloat.apply(I_EG_WZ_Ofenthermometer_Ofen) < 70.0
&& nvlFloat.apply(I_KG_Heizraum_Solar_Speichertemperatur) < 50.0
&& nvlFloat.apply(G_Aussentemperatur) <= 10.0
&& nvlInt.apply(I_Wetter_3Stunden_VorhersageID) != 800 && nvlInt.apply(I_Wetter_3Stunden_VorhersageID) != 801
&& nvlInt.apply(I_Wetter_6Stunden_VorhersageID) != 800
&& nvlFloat.apply(I_KG_Heizraum_Solar_Kollektortemperatur) <= nvlFloat.apply(I_KG_Heizraum_Solar_Speichertemperatur)
I_EG_WZ_Ofen_Nachlegeempfehlung.sendCommand(ON)
} else {
I_EG_WZ_Ofen_Nachlegeempfehlung.sendCommand(OFF)
In the discussion Operator_multiply(float,float) on instance null Rich proposed a more generic lambda function that drops the need of differentiating the value type:
val nvl = [ GenericItem theItem |
if(theItem.state == NULL || theItem.state == UNDEF) 0 else theItem.state as Number
However, I found that this gives me headaches if the item is of a QuantityType, and most often I only need the actual numeric value in my rules to calculate with.
My question would be: Is there a way to write this funtion such that it delivers only the number portion whether the item is a QuantityType or not?
rossko57 explained a lot on handling QuantityTypes in other threads (e.g. Working with Number:Temperature Items in rules), from which I took the following could work:
if(theItem.state == NULL || theItem.state == UNDEF) 0 else (theItem.state as QuantityType<Number>).toBigDecimal
However, this variant fails if the item is a pure Number item.
Is there a way to find out if the GenericItem is a Number item or a QuantityItem?
Thanks,
stedon81
