Does anyone here have any experience with LampUX bulbs?
I picked one up off of Amazon a couple of weeks back hoping to make it work with OH, the price was decent so I figured why not? Amazon Link
I have installed the Wifi LED binding and it did not detect it, I tried adding it manually but thats doesn’t seem to be working either sadly. The odd thing about it is that the device doesn’t have a normal IP on my network, 192.168.x.x. It has its own IP of 69.168.151.19 and I can ping it from other devices in my network, such as my OH box but for some reason can not connect to it.
Admittedly I am a noob on working with these bulbs, so I am not sure what exactly to be on the lookout for but with some guidance I can most likely figure it out, just need to be pointed in the right direction.
Any guidance or help on this would be great. Thanks for reading.
So I’ve got the same bulb and a similar problem. I’d like to be able to use Node Red and OpenHAB with it, but am struggling.
I think “62.168.151.19” is a red herring, as this is most likely your ISP provisioned IP address for your home WhoIs
IFTTT works with it like a dream btw (and may be a good shortcut for the moment. You could set up a webhook using the SmartLife app that OpenHAB or NodeRed trigger to turn the lamp on and off…), but what I want to do it have it turn OFF n seconds after it’s been turned on. The native automation app looks like it supports this functionality, but I’ve not successfully manage to get this working yet.
That is really interesting @Belial I never even considered the IP as being my public IP address of my ISP but it looks like you are right.
That is really odd that it would work like that but makes sense. I am still curious to sniff the traffic of the app to see what it’s doing, just need the time I look at it.
I haven’t tried to make the bulb do anything else yet other than just turn it off/on. I did link it to my Google Home so it can be controlled by that but my main goal is to have everything integrated into OH.
I will let you know if I figure anything out, nice to know others are looking at this as well
Did anyone ever get these working? I’m having the same issue. The wifiled binding doesn’t work.
I did find the ip addresses of the individual bulbs, however, using a combination of the LampUX app and my wifi router. In the app, tap the device and then in the top-right tap the edit icon. Down toward the bottom of the edit screen you’ll see Check Device Network — tap that. (Make sure you’re on the same wifi network as the lights.) The result will be a list of Signal Strength, IP address (which is wrong) and Mac Address. Make note of the Mac Address.
Go to your router’s admin page, to DHCP list, and browse the list of devices connected to your network. They should all have a Mac Address and IP Address listed. Just match the Mac Address from the app to the list and voila, IP Address.
