I installed the latest snapshot according to the instructions on Download openHAB | openHAB (package installation). No issues there, but now I can’t access openhab anymore when I browse to :8080, I’m getting a connection refused error. Same thing if I try to use karaf, also results in a connection refused error.
this is my /etc/default/openhab2 file, none of the variables is commented out
when I scan the ports on the raspberry using sudo netstat -lptu I can see that none of the ports above is used. using ps -ef I can see that there is a openhab process running, but the log files don’t hold any information other than the shutdown before the upgrade
Does anyone have an idea what might be goign wrong?
Give it a few minutes and try again.
I did the same, and fro some reason it took at coupple of minute getting connection refused, and then it suddenly worked.
Thanks. no, not yet. Just did that and now the log gets at least updated. Apparently somethign is not working wth regard to the spotify binding, I’m getting a
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.spotify [20]
Unresolved requirement: Import-Package: com.google.gson
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
