The coloring is not yet finished but based on the color table of: gtjlcars.de
Additionally I would like to add a “status dashboard” which gives a generic overview of the Object.
And a possibility to show the floor plan(s).
The current work is optimized for a 1024px width.
I’m not too familiar with Eclipse development and I just messed up my environment yesterday :-(.
So anybody who is willing to support my freaky idea is welcome to join it.
Gents:
I’ve recently restarted my activities on this idea. But for the time beeing I was working with PHP.
I need to find out how to build it with Java, if one of you could help me here, it would be much appresiated.
There is a skeleton for binding development using Eclipse but not for UI development.
I have replaced the screenshot as I changed the design.
Ha, I was just thinking about this the other day, I hope your work progresses faster than mine!
My intention was to do something similar to the ‘ship blueprints’ that you see in different scenes (but for my house, obviously) with status and control interfaces off to the side.
I Just finished the first runable package, actually the dashboard tile is not yet in which means you need to enter the url manually. I didn’t find out what I made wrong here.
As it is still in very early stage I didn’t yet publish it on GITHUB. But you can download it from my site for tests. Just rename it to jar and copy it to the addons folder.
The problem following my initial approach is that my own way of thinking to do it interferes the way how the Angular framework runs. Whenever I thougt I made it nice I realized that it’s not. because there is some other behaving of angular that made my codeing look stupid.
I’m frustrated.
So I need to start from begin and firstly read about how angular works. But I think even then It will be difficult to align it together due to the fact that the used elements in LCARS style follow a different goal.
If there is anyone familiar with the angualar framework I would appreciate and welcome you.
UPDATE:
Link removed, as there is no working version currently.
I’m very sorry, this was effort to achieve something fancy. But unfortunately I had no time anymore to continue with it. Another story was to continues changes that have been applied to openHAB 2 in that time.
I still would love to have such UI. but with two small kids, its really difficult to find spare time.
Der Screenshot ist auf deutsch. Deswegen hoffe ich, du verstehst mich, wie kann ich das lcars design in openhab einbinden? ist es dann auf dem Habpanel zu sehen?
[English below]
Schön daß es Dir gefällt. Leider ist das Teil noch immer nicht so weit wie ich es gern hätte.
Nein Habpanel wird es nicht darstellen können. Die Idee war ein eigenes UI im LCARS Design.
Leider ist die Entwicklung von UIs für openHAB alles andere als trivial . Da ich auch nur beschränkt Entwicklererfahrung habe. Da ich nur in den späten Abendstunden dran arbeite ist das enorm Zeitraubend.
Derzeit arbeite ich daran den Slider vernünftig darstellen zu können. Das nächste werden die Charts sein. Ich verwende PHP und REST zur Aufbereitung, später soll es aber als native Java daherkommen. Aber eben… Java ist nicht meine Stärke, oder noch nicht…
good to read that you like it. Unfortunately it is by far not finished yet. And no it isn’t mean to be seen within Habpanel. The idea was/is a separate UI addon in the LCARS Design.
But developing a UI for openHAB isn’t that easy and as my developer skills are not that high, it doesn’t make it easier too. As I only work on it in the late evening hours, it needs a lot of time to finish parts of.
Currently I work on the Slider elements to make them looking good, a next one will be charts. At the moment I use a PHP / rest environment but the plan is to have a native java one. But as I wrote before Java is not one of my strengths … at least not by now.
Stefan
MDAR
#12
If it helps anyone.,…
I have been playing around with the SVG approach to a HabPanel UI and used LCARS as a starting point.
This is what I have so far.
(If anyone has a suggestion on how to get a slider working, I’d love to hear it)
technically feasible for habpanel. But frankly spoken some of the colors would, in my opinion, need to be adjusted and the elbows are partially looking strange, at least on these pictures.
Cheers
Stefan
MDAR
#14
Hey Stefan,
I take all that onboard.
I’m certainly not known for my graphics skills, or programming skills for that matter.
If you can get your UI to run in OH2.5, I would be very keen to give it a try.
(I dropped your jar file into OH and Karaf saw it as a bundle, but nothing appeared in the Start/Index page. Was I doing something wrong?)
The jar you downloaded is so outdated, that it doesn’t make sense to talk about it. I should remove that link. That version was a fork of PaperUI which didn’t work well on one hand and on the other PaperUI was never meant to be as a “normal user” interface but for admin reasons.
If you would like I could provide you my current “work in progress” framework. But it is not a OH2 addon. It is outside of it and requires you to have PHP 7.2 installed at least. Please send me a PM in case of.
MDAR
#17
Thanks.
PHP is a step too far for me.
I found this article that references openHAB, which I’ll have a dig around in.
@MDAR Funny to keep seeing you on the same threads, I’m guessing we have some similar interests!
I’m actually also working on an LCARS interface, built with SVGs on HABpanel.
It’s designed for simultaneous display on three screens: one is a home monitor with a map, one is a frame for displaying logs or node-RED (among others), and a small touchscreen is for controlling it all.
Just for fun, all design elements respond to a red alert virtual switch.
It’s very much still a work in progress but I am willing to share code once it’s more stable, if there’s interest.
Note: that’s a low quality video. I’ll probably put a better one up soon and will update this link.
