First Community Beta Test Candidate released: lgwebos-2.5.0-snapshot-201908262331
there will be a warning about weak ciphers used in the log.
It seems the device does not support any non-weak ones, so I enabled all. I need to find how this can be improved and limited to a minimum of weak ones.
Have tested my deviceâs SSL capability, and it is not performing well at all:
SSL Server Test_ WebOS.pdf (228.2 KB)
OS Release Version 2.2.1, Device OS 4.1, Software Version 4.5.85
Of course, the certificate is self signed and we simply have to trust it, so it will not prevent any man in the middle attack.
It does not support TLS 1.3 and only uses weak cipher suites. This is something which could change in the future with an update, but I doubt that this going to happen.
I could enable some of the weak ciphers, but it will result in a warning in the log. I doubt that in our home environment and for the un-sensitive data we are passing encryption is really required.
NOTE: The only security relevant data could be the client-key. If somebody on the network steals it, he could also connect to the TVâs API.
Thus, I will rework this now to not use encryption (https) and use plain unencrypted communication (http).
Does anyone have any doubts, recommendations, thoughts?
Hi i have a problem, when i turn off the tv the status on openhab change to off and then immediatly goes back on, i tried to figure out whatâs going on looking at the logs but i havenât found anything.
I assume you use lgwebos-2.5.0-snapshot-201908262331
does the TV turn off and will it eventually show off in OH? So, just a temporary inconsistency?
I am seeing something similar. If I simply power on or off the âbouncingâ of the switch doesnât cause any negative effects. However, I have a âgood nightâ routine that I run that does various things including turning off the TV via my Harmony Hub âPower Offâ rule. If I manually turn off the TV (using the Harmony Remote) and then press the good night button, the TV will turn back on. I believe the switch will toggle even though the TV is off already which sends another WOL command turning the TV back on.
Here are my rules:
rule "Harmony Hub LR - Power Off"
Item HarmonyHubLR received update
if (HarmonyHubLR.state == "PowerOff" ) {
sendCommand(LG_TV0_Power, OFF)
sendCommand(zone1Power, OFF)
sendCommand(LG_TV1_Power, OFF)
sendCommand(Audio_Zones_Amp_14PR, OFF)
rule "Good Night Button Extension"
Item GdNght_Flag received update
sendCommand(Lights_FamilyRoom_Angie_LampZWave, OFF)
sendCommand(Lights_FamilyRoom_Steve_LampZWave, OFF)
sendCommand(MiscZwaveSwitch, OFF)
postUpdate(HarmonyHubLR, "PowerOff")
sendCommand(ZnAllState, OFF)
sendPushoverMessage(pushoverBuilder("Good Night!"))
iâm using the 2.4.0 version and i checked this morning and now itâs working fineâŠhowever it was a temporary inconsistency, thank you for your reply and sorry for the inconvenience.
any feedback regarding this beta version. I would like to start the pull request to go through code review.
Hi Sebastian,
thank you, good work !!!
I have been installing the snapshot for a week. So far, I have not encountered any problems.
Before that I had the ON OFF problem. This does not occur now.
All features works with my WebOS 5.10.10 TV.
The only thing I have seen are OFFLINE messages in the event.log every 10 seconds when the TV is not on.
âchanged from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Connect Timeoutâ
âchanged from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Connect Timeout to OFFLINE: TV is offâ
Kind Regards
Jens
I cannot wait to see this in the milestone builds
@sprehn: Iâm using milestone 2.5M3 and the toast messages are working again since you removed the default icon on toast messages -> thanks a lot
Regarding beta version:
I have not yet tested your beta version. Will try this as soon I have a little spare time.
thx for your observation - it is now addressed in code
Pull Request Raised #6060
Hi @sprehn
Sorry for long delay âŠ
Today I uninstalled lgwebos binding (I am using Openhab 2.4) then
a) copied org.openhab.binding.lgwebos-2.5.0-SNAPSHOT.jar to /usr/share/openhab2/addons/
b) added in file addons.cfg line: binding = lgwebos,âŠ
and received this in Karaf console:
[WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.lgwebos-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.lgwebos [229]
Unresolved requirement: Import-Package: org.openhab.core.automation.annotation; resolution:=âoptionalâ
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.discovery.upnp
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
Can I test your binding in Openhab 2.4? I cannot switch to OH 2.5 since many other errors
Is the pull request in the last snapshot?
it will only work with 2.5, correct
@sprehn
I installed the test version and I am having issues getting one of my two LG TVâs to connect (stay connected). One was detected, connected, and paired with no issue. The other TV is found normally but as soon as I confirm the pairing on the TV the binding begins to quickly connect and disconnect. Iâve tried removing the thing and restarting but I canât seem to make a stable connection.
TV: [LG] webOS TV OLED65E7P, webOS v5.80.35
openHAB: 2.5M3
Log example (repeats endlessly):
2019-09-21 14:23:28.058 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from ON to OFF
2019-09-21 14:23:28.238 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.240 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-21 14:23:28.254 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.255 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-21 14:23:28.260 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from OFF to ON
2019-09-21 14:23:28.306 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-21 14:23:28.308 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-21 14:23:28.311 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-21 14:23:28.312 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-21 14:23:28.313 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from ON to OFF
2019-09-21 14:23:28.587 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.589 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-21 14:23:28.603 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.604 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-21 14:23:28.609 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from OFF to ON
2019-09-21 14:23:28.635 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-21 14:23:28.636 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-21 14:23:28.638 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-21 14:23:28.639 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-21 14:23:28.640 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from ON to OFF
2019-09-21 14:23:28.886 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.889 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-21 14:23:28.902 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-21 14:23:28.904 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-21 14:23:28.908 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from OFF to ON
2019-09-21 14:23:28.928 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-21 14:23:28.929 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-21 14:23:28.934 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from ON to OFF
Any ideas or anything else I can provide to help troubleshoot?
EDIT: I reverted back to the 2.5M3 version of the binding and the TV now will stay connected. However, I noticed the following error in the log. Iâm not sure if itâs related or not but there was a similar error statement about a value being between 0 and 100 that seemed common to both versions.
2019-09-22 11:22:18.707 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:d33eeacc-b1a7-44b4-972d-fc71a26a851e' changed from OFFLINE: TV is off to ONLINE: Device Ready
2019-09-22 11:22:18.878 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:d33eeacc-b1a7-44b4-972d-fc71a26a851e' changed from ONLINE: Device Ready to ONLINE: Connected
2019-09-22 11:22:18.886 [vent.ItemStateChangedEvent] - LG_TV0_Power changed from OFF to ON
2019-09-22 11:22:18.909 [vent.ItemStateChangedEvent] - LG_TV0_Application changed from to com.webos.app.hdmi1
2019-09-22 11:22:18.890 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:58) ~[?:?]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:43) ~[?:?]
at org.openhab.binding.lgwebos.internal.VolumeControlVolume$1.onSuccess(VolumeControlVolume.java:98) ~[?:?]
at org.openhab.binding.lgwebos.internal.VolumeControlVolume$1.onSuccess(VolumeControlVolume.java:1) ~[?:?]
at com.connectsdk.core.Util$1.run(Util.java:78) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
2019-09-22 11:22:19.082 [WARN ] [ng.lgwebos.internal.TVControlChannel] - error requesting channel list: tuner channel map does not exist.
Thank you!
could you enable debug log level and run the new version one more time.
in Karaf:
log:set debug org.openhab.binding.lgwebos
ok, log file excerpt with debug filtered for webos:
2019-09-22 19:55:14.711 [DEBUG] [org.openhab.binding.lgwebos ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingActions}={service.id=530, service.bundleid=205, service.scope=singleton} - org.openhab.binding.lgwebos
2019-09-22 19:55:14.722 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from UNINITIALIZED to INITIALIZING
2019-09-22 19:55:14.820 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:55:15.047 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:55:15.497 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:55:15.515 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from INITIALIZING to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:55:17.451 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:55:17.456 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:55:17.670 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livetv - Live TV
2019-09-22 19:55:17.672 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo netflix - Netflix
2019-09-22 19:55:17.673 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo amazon - Amazon Prime Video
2019-09-22 19:55:17.674 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo hulu - Hulu
2019-09-22 19:55:17.675 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.movenetworks.app.sling-tv-sling-production - Sling TV
2019-09-22 19:55:17.676 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo channelplus.us - Channel Plus
2019-09-22 19:55:17.686 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo vudu - VUDU
2019-09-22 19:55:17.688 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo googleplaymovieswebos - Google Play Movies & TV
2019-09-22 19:55:17.689 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.dolby.lgapp - Dolby Access
2019-09-22 19:55:17.690 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.discovery - LG Content Store
2019-09-22 19:55:17.692 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.voice - Search
2019-09-22 19:55:17.693 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.browser - Web Browser
2019-09-22 19:55:17.694 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tvuserguide - User Guide
2019-09-22 19:55:17.695 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.connectionwizard - Device Connector
2019-09-22 19:55:17.696 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tvguide - Guide
2019-09-22 19:55:17.697 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.music - Music
2019-09-22 19:55:17.707 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.photovideo - Photo & Video
2019-09-22 19:55:17.708 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.igallery - OLED Gallery
2019-09-22 19:55:17.709 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.scheduler - TV Scheduler
2019-09-22 19:55:17.710 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.miracast - Screen Share
2019-09-22 19:55:17.711 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.multiview - Multi-view
2019-09-22 19:55:17.712 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.accessibility - Accessibility
2019-09-22 19:55:17.714 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.notificationcenter - Notifications
2019-09-22 19:55:17.716 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.remoteservice - LG Remote Service
2019-09-22 19:55:17.717 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.adapp - Advertisement
2019-09-22 19:55:17.718 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.brandshop - Brand Shop
2019-09-22 19:55:17.720 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.facebooklogin - Thirdparty Login
2019-09-22 19:55:17.721 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.membership - LG Membership
2019-09-22 19:55:17.722 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.inputcommon - InputCommon
2019-09-22 19:55:17.723 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.palm.app.firstuse - First Use
2019-09-22 19:55:17.724 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.palm.app.settings - Settings
2019-09-22 19:55:17.725 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrcard - LivePlus
2019-09-22 19:55:17.726 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrcomponent - LivePlus
2019-09-22 19:55:17.727 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrhdmi1 - LivePlus
2019-09-22 19:55:17.729 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrhdmi2 - LivePlus
2019-09-22 19:55:17.730 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrhdmi3 - LivePlus
2019-09-22 19:55:17.731 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acrhdmi4 - LivePlus
2019-09-22 19:55:17.732 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.acroverlay - LivePlus
2019-09-22 19:55:17.733 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.channeledit - CHANNEL MANAGER
2019-09-22 19:55:17.734 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.channelsetting - Channel Tuning
2019-09-22 19:55:17.735 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.cheeringtv - Cheering Mode
2019-09-22 19:55:17.736 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.container - Enyo (2.6) App Container
2019-09-22 19:55:17.737 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.customersupport - Customer Support
2019-09-22 19:55:17.738 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.dvrpopup - DvrPopup
2019-09-22 19:55:17.739 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.eula - User Agreement
2019-09-22 19:55:17.741 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.externalinput.av1 - AV
2019-09-22 19:55:17.742 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.externalinput.av2 - AV2
2019-09-22 19:55:17.744 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.externalinput.component - Component
2019-09-22 19:55:17.745 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.externalinput.scart - AV1
2019-09-22 19:55:17.746 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.factorywin - QML Factorywin
2019-09-22 19:55:17.748 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.favshows - My Content
2019-09-22 19:55:17.749 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.hdmi1 - HDMI1
2019-09-22 19:55:17.750 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.hdmi2 - HDMI2
2019-09-22 19:55:17.751 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.hdmi3 - HDMI3
2019-09-22 19:55:17.753 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.hdmi4 - HDMI4
2019-09-22 19:55:17.755 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.inputmgr - Input Hub
2019-09-22 19:55:17.756 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.installation - Installation Settings
2019-09-22 19:55:17.757 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livedmost - Live Dmost
2019-09-22 19:55:17.758 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.liveibb - Live IBB
2019-09-22 19:55:17.759 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inhdmi1 - Live Zoom App
2019-09-22 19:55:17.760 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inhdmi2 - Live Zoom App
2019-09-22 19:55:17.762 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inhdmi3 - Live Zoom App
2019-09-22 19:55:17.763 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inhdmi4 - Live Zoom App
2019-09-22 19:55:17.764 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inphotovideo - Live Zoom App
2019-09-22 19:55:17.765 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-inrecordings - Live Zoom App
2019-09-22 19:55:17.766 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-insmhl - Live Zoom App
2019-09-22 19:55:17.767 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.livezoom-intv - Live Zoom App
2019-09-22 19:55:17.768 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.magicnum - Magic Number
2019-09-22 19:55:17.770 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.mystarter - My Starter
2019-09-22 19:55:17.771 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.remotesetting - Remote Setting
2019-09-22 19:55:17.772 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.screensaver - Screen Saver
2019-09-22 19:55:17.773 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.softwareupdate - Software Update
2019-09-22 19:55:17.774 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.store-demo - Store Demo
2019-09-22 19:55:17.776 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.systemmusic - Music Overlay
2019-09-22 19:55:17.777 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tips - Tips App
2019-09-22 19:55:17.778 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tvhotkey - Local Control Panel
2019-09-22 19:55:17.780 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tvsimpleviewer - Viewer
2019-09-22 19:55:17.781 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.tvtutorial - Adjust camera angle
2019-09-22 19:55:17.782 [DEBUG] [lgwebos.internal.LauncherApplication] - AppInfo com.webos.app.webapphost - Web App
2019-09-22 19:55:17.785 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Error: {"type":"error","id":3,"error":"1010 tuner channel map does not exist","payload":{}}
2019-09-22 19:55:17.788 [WARN ] [ng.lgwebos.internal.TVControlChannel] - error requesting channel list: 1010 tuner channel map does not exist.
2019-09-22 19:56:06.335 [vent.ItemStateChangedEvent] - LG_TV0_Application changed from NULL to com.webos.app.hdmi1
2019-09-22 19:56:06.792 [vent.ItemStateChangedEvent] - LG_TV1_Application changed from NULL to com.webos.app.hdmi1
2019-09-22 19:56:06.873 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Power-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:power' has been added.
2019-09-22 19:56:06.875 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Mute-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mute' has been added.
2019-09-22 19:56:06.879 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Volume-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:volume' has been added.
2019-09-22 19:56:06.882 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_VolumeDown-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:volumeDown' has been added.
2019-09-22 19:56:06.884 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_VolumeUp-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:volumeUp' has been added.
2019-09-22 19:56:06.886 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_ChannelNo-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:channel' has been added.
2019-09-22 19:56:06.889 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_ChannelDown-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:channelDown' has been added.
2019-09-22 19:56:06.893 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_ChannelUp-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:channelUp' has been added.
2019-09-22 19:56:06.903 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Channel-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:channelName' has been added.
2019-09-22 19:56:06.915 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:06.919 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:06.924 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_MediaState-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaState' has been added.
2019-09-22 19:56:06.928 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Toast-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:toast' has been added.
2019-09-22 19:56:06.929 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Play-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaPlayer' has been added.
2019-09-22 19:56:06.929 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Stop-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaStop' has been added.
2019-09-22 19:56:06.929 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Pause-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaPause' has been added.
2019-09-22 19:56:06.929 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Forward-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaForward' has been added.
2019-09-22 19:56:06.930 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Rewind-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:mediaRewind' has been added.
2019-09-22 19:56:06.934 [.ItemChannelLinkAddedEvent] - Link 'LG_TV0_Application-lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b:appLauncher' has been added.
2019-09-22 19:56:06.975 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:06.958 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
at org.openhab.binding.lgwebos.internal.handler.WebOSTVSocket.sendMessage(WebOSTVSocket.java:342) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.WebOSTVSocket.sendCommand(WebOSTVSocket.java:304) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.WebOSTVSocket.subscribeCurrentChannel(WebOSTVSocket.java:501) ~[?:?]
at org.openhab.binding.lgwebos.internal.TVControlChannel.getSubscription(TVControlChannel.java:95) ~[?:?]
at org.openhab.binding.lgwebos.internal.BaseChannelHandler.refreshSubscription(BaseChannelHandler.java:70) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.WebOSHandler.refreshChannelSubscription(WebOSHandler.java:254) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.WebOSHandler.channelLinked(WebOSHandler.java:235) ~[?:?]
2019-09-22 19:56:07.017 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:07.061 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.010 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:07.063 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:07.065 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.066 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
at org.openhab.binding.lgwebos.internal.TVControlChannelName.getSubscription(TVControlChannelName.java:46) ~[?:?]
2019-09-22 19:56:07.103 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:07.122 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:07.123 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:07.138 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:07.297 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:07.322 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:07.326 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:07.372 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:07.374 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.375 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:07.378 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.384 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.388 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.394 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.405 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:07.429 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:07.429 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:07.449 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:07.449 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.456 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.457 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.459 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.461 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:07.468 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:07.473 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:07.502 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:07.511 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:07.755 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:08.067 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:08.071 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:08.165 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:08.171 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:08.173 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.187 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.205 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.208 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.214 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.231 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:08.243 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:08.246 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:08.258 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:08.259 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.267 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.284 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.286 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.288 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:08.295 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:08.299 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:08.313 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:08.317 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:08.571 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:08.991 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:09.003 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:09.067 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:09.073 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.073 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:09.079 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.092 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.104 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.116 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.149 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:09.154 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:09.156 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:09.163 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:09.165 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.167 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.179 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.184 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.186 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:09.192 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:09.200 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:09.313 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:09.314 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:09.825 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:10.112 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:10.114 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:10.647 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:10.664 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:10.665 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.666 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.668 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.678 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.680 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.699 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:10.700 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:10.701 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.701 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.703 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:10.711 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:10.702 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.712 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.713 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:10.714 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:10.714 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:10.728 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:10.728 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:11.068 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:11.094 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:11.096 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:11.142 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:11.149 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:11.151 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.156 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.162 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.172 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.174 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.182 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:11.186 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:11.187 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:11.227 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.230 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.232 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.234 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:11.239 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.242 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:11.248 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:11.253 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:11.296 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:11.297 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
2019-09-22 19:56:11.456 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Connected to: /192.168.1.44
2019-09-22 19:56:12.221 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:12.223 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2019-09-22 19:56:12.240 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.241 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.243 [me.event.ThingUpdatedEvent] - Thing 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' has been updated.
2019-09-22 19:56:12.244 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
2019-09-22 19:56:12.260 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.261 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.275 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Subscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.278 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Value must be between 0 and 100
2019-09-22 19:56:12.295 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100
2019-09-22 19:56:12.279 [DEBUG] [webos.internal.handler.WebOSTVSocket] - WebSocket Closed - Code: 1006, Reason: Value must be between 0 and 100
2019-09-22 19:56:12.296 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlVolume on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.297 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.LauncherApplication on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.297 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannel on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.298 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.VolumeControlMute on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.299 [DEBUG] [.lgwebos.internal.BaseChannelHandler] - Unsubscribed org.openhab.binding.lgwebos.internal.TVControlChannelName on IP: lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b
2019-09-22 19:56:12.302 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Value must be between 0 and 100 to OFFLINE: TV is off
2019-09-22 19:56:12.307 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Connecting to: wss://192.168.1.44:3001
2019-09-22 19:56:12.308 [DEBUG] [gwebos.internal.handler.WebOSHandler] - Connection failed - error: Disconnected
2019-09-22 19:56:12.310 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE: TV is off to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected
2019-09-22 19:56:12.310 [hingStatusInfoChangedEvent] - 'lgwebos:WebOSTV:f9ec57aa-a319-d3ea-5f23-fc59673fde3b' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Disconnected to OFFLINE: TV is off
There seem to be two issues:
A)
2019-09-22 19:55:17.785 [DEBUG] [webos.internal.handler.WebOSTVSocket] - Error: {âtypeâ:âerrorâ,âidâ:3,âerrorâ:â1010 tuner channel map does not existâ,âpayloadâ:{}}
This error message comes from the TV itself in response to the query for all Channels. I have no idea what to do about it, to be honest. Without this, you wonât be able to switch channels via the binding.
B)
This acutally sounded to me like a familiar OH error when parsing a PercentType. And this seems to be the case, as you confirmed in the previous version. Could it be that the type of the item you have bound to this channel is not String? The type of this channel changed to string a while ago. Please confirm if it works if you connect this channel to a String type item.
Nevertheless, an exception at this point should not disconnect the binding. Have to come up with a solution to that.
Kind Regards
Sebastian
