Thank you. @HaKuNa
@sprehn do you know of a way to tell that the TV is in its āscreensaverā mode? The idea is to automatically turn off the TV once the screensaver has been showing for a period of time. AFAIK the TV itself doesnāt have such a feature.
The application stays the same (e.g. Youtube) when the screensaver is on.
I have had issues sometimes with the WoL since probably at least 6-8 months back in time.
Changing input etc works, volume up/down works so the binding is authenticated.
But for some reason it almost never works to power on the TV. Power on works without issues. Anyone noticed something similar or know why this could be? Model is 65C9.
Edit: OpenHAB 3 by the way.
Hi, if i send command ā1ā to ārcButtonā channel, my tv show toast message āplease use magic tv remote to controlā.
I need working samle, may be someone has one?
Number devTvRoomChannelToSet
rule "devTvRoomChannelToSet CHANGED"
Item devTvRoomChannelToSet changed
var String ch = devTvRoomChannelToSet.state.toString
var int cnt = 0
ch.toCharArray.forEach[
Thread::sleep(200)
val String chStr = (ch.toCharArray.get(cnt)).toString
devTvRoomButton.sendCommand(chStr)
cnt += 1
I see that commands to ārcButtonā channel works only when Magic Remote is active, when Magic Remote in sleep mode, i see message about āuse magic remoteā.
Hi I have some troubles with the Binding.
I get the Text message size exceeds error.
I have installed OH3.
Can someone help me with my issue?
2021-03-26 19:31:22.082 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'lgwebos:WebOSTV:a9161f51eb' changed from ONLINE: Connected to OFFLINE (COMMUNICATION_ERROR): Connection Failed: Text message size [3415920] exceeds maximum size [3145728]
2021-03-26 19:31:22.086 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'lgwebos:WebOSTV:a9161f51eb' changed from OFFLINE (COMMUNICATION_ERROR): Connection Failed: Text message size [3415920] exceeds maximum size [3145728] to OFFLINE: TV is off
2021-03-26 19:31:22.148 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'lgwebos:WebOSTV:a9161f51eb' changed from OFFLINE: TV is off to ONLINE: Registering - You may need to confirm pairing on TV.
2021-03-26 19:31:22.208 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'lgwebos:WebOSTV:a9161f51eb' changed from ONLINE: Registering - You may need to confirm pairing on TV. to ONLINE: Connected
Cheers Joko
Hi Joko
this means the payload returned by your tv is too large for the binding. it is a bug. will have to look into this.
kind regards
Sebastian
Please feel free to add details to this issue:
Fix has been merged
Hi!
I am trying to set up Toasts on my OpenHAB 2.5.13 instance.
My rule looks like that:
rule "Notifier: Light"
Item Notifier_Light received command
logInfo("Notifier", "Light: " + receivedCommand)
val LGTVWZ = getActions("lgwebos", "lgwebos:WebOSTV:abcd1234")
LGTVWZ.showToast("http://192.168.***.***:7080/icon/light?format=png", receivedCommand)
Log output:
21:22:16.806 [INFO ] [ipse.smarthome.model.script.Notifier] - Light: Kino-Modus aktiviert
21:22:16.807 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Notifier: Light': An error occurred during the script execution: Could not invoke method: org.openhab.binding.lgwebos.action.LGWebOSActions.showToast(org.eclipse.smarthome.core.thing.binding.ThingActions,java.lang.String,java.lang.String) on instance: null
Any idea why LGTVWZ is ānullā in this case? I double-checked the thing ID. I even tried to setup the thing using a file based defintion - without success.
The Thing is working (all items work and sending a string command to the Toast channel also works)
Thanks in advance!
Hi
maybe the error is misleadingā¦
can you try without icon url? some users have reported that icons in toasts do not work in newer lg models
Sebastian
how can i use a rule to open a simple website
if this happens open this url
http://user:pass@192.168.86.60/cgi-bin/snapshot.cgi?loginuse=user&loginpas=pass
ule āTv Stream kameraā
Item kameratv received update ON
LG_TV0_Application.sendCommand(āwww.sol.noā)
Brain do not work today
Hello, Iām totally newbie user and starting to love openHAB.
Today Iāve tried to add my LG webos OLED to the bindings, and sadly no success. Keep getting errors shown below.
TV and openHAB in same network, TV accept LG Apps connection, tried with firewall off.
OpenHab v. 4.3.2 running on Win SRV 2019 - just for now.
On binging page I got
Status:
UNINITIALIZED
HANDLER_INITIALIZING_ERROR
Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@7a71f46a[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@3b4cfe51[Wrapped task = org.openhab.binding.lgwebos.internal.handler.LGWebOSHandler$$Lambda$1371/0x0000000100f79c40@3f736de0]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@7a8358b2[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 2]
Iāve tried log:set debug org.openhab.binding.lgwebos
but log seems to be clear
log:tail org.openhab.binding.lgwebos
14:02:08.963 [DEBUG] [webos.internal.handler.LGWebOSHandler] - Disposing handler for thing lgwebos:WebOSTV:XXX
14:02:08.964 [DEBUG] [ebos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current DISCONNECTED
14:02:19.921 [DEBUG] [webos.internal.handler.LGWebOSHandler] - Initializing handler for thing lgwebos:WebOSTV:XXX
Only error Iāve managed to catch as fresh user is from log:tail org.openhab.core.thing
14:06:19.645 [ERROR] [.core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ālgwebos:WebOSTV:0e45eafa-9149-905d-56db-221ba8e4af21ā: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@7a71f46a[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@3b4cfe51[Wrapped task = org.openhab.binding.lgwebos.internal.handler.LGWebOSHandler$$Lambda$1371/0x0000000100f79c40@3f736de0]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@7a8358b2[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 2]
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@7a71f46a[Not completed, task = java.util.concurrent.Executors$RunnableAdapter@3b4cfe51[Wrapped task = org.openhab.binding.lgwebos.internal.handler.LGWebOSHandler$$Lambda$1371/0x0000000100f79c40@3f736de0]] rejected from org.openhab.core.internal.common.WrappedScheduledExecutorService@7a8358b2[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 2]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2055) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:825) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:340) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor.scheduleWithFixedDelay(ScheduledThreadPoolExecutor.java:680) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.LGWebOSHandler.startReconnectJob(LGWebOSHandler.java:171) ~[?:?]
at org.openhab.binding.lgwebos.internal.handler.LGWebOSHandler.initialize(LGWebOSHandler.java:148) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Please help
hi all, I have some trouble to configure my lg G9 to work with alexa.
I can use all items with the gui and they work nice but with alexa I only can poweron and poweroff.
On the alexa app I only see the on/off button.
Following how I configured the whole group:
Group TVSala āTVā Endpoint.tv
Switch TVSala āpowerā PowerController.powerState
Dimmer TVSala_Volume āvolumeā (TVSala) Speaker.volume
Switch TVSala_mute āmuteā (TVSala) Speaker.muted
Player TVSala_mediaPlayer āmedia controlā (TVSala) PlaybackController.playback
Thanks for your time.
Hi all
First of all, great binding
Iām using this binding successfully for quite a while now.
Recently I replaced my LG WebOS TV with a new one (LG OLED65C27LA) which runs on WebOS 22.
As far as I know, most is still working, exept of the āApplicationā Channel.
The possible āApp-Optionsā (App-List) are not listed and there is also no item-ādisplayStateā anymore. Only āStateā returns a value, which is a little bit cryptic.
Any other users experience this behaviour?
Anyone experiencing strange behaviour with binding after WebOS 03.30.16 update ?
The TV looks always offline with message āTV is Offā and nothing seems to work apart from WoL function.
Any idea ?
Same to me. Unable to bring it online in openhab after 03.30.16 Updateā¦
Discovery is also not working. Seems LG broke something
Firmware 05.30.25 and no problem.
It could be something specific to a model?
What models are concerned?
My Model ist āOLED65C27LA.AVSā released in 2022. LG WebOS Version is 7.0.3-16. Maybe its WebOS related and not āfirmwareā 03.30.16. But maybe this Versions are not independentā¦
The release notes of firmware are not very detailed, but a lot of models will get this update.
[03.30.16]
LG Channels expanded its availability to more countries. (Argentina, Chile, Colombia, Peru
A new feature, Learn Remote Control, has been added for people with disabilities
Known kernel vulnerabilities patche
- CVE-2021-4154, CVE-2022-2588
See the following link, click on the āreferenceā drop down for release notes and related models:
LG Software & Firmware | LG Schweiz
Same here.
2023-01-27 21:39:25.376 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current DISCONNECTED
2023-01-27 21:39:25.376 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - Connecting to: ws://192.168.1.x:3000
2023-01-27 21:39:25.378 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Connection failed - error: HttpConnectionOverHTTP@bdeac39::SocketChannelEndPoint@661cce3f{l=/192.168.1.y:55874,r=/192.168.1.x:3000,ISHUT,fill=-,flush=-,to=0/0}{i
o=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@bdeac39(l:/192.168.1.y:55874 <-> r:/192.168.1.x:3000,closed=false)=>HttpChannelOverHTTP@49efd3be(exchange=HttpExchange@11dd762e{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@6f1caf48[TERMINATED
/null] res=HttpResponse[null 0 null]@6ff1f9a2[PENDING/null]})[send=HttpSenderOverHTTP@5834b5c1(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@22a2d4ef{s=START}],recv=HttpReceiverOverHTTP@284e491c(rsp=IDLE,failure=null)[HttpParser{s
=CLOSED,0 of -1}]]
2023-01-27 21:39:35.377 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - setState new DISCONNECTED - current DISCONNECTED
2023-01-27 21:39:35.377 [DEBUG] [bos.internal.handler.LGWebOSTVSocket] - Connecting to: ws://192.168.1.x:3000
2023-01-27 21:39:35.379 [DEBUG] [ebos.internal.handler.LGWebOSHandler] - Connection failed - error: HttpConnectionOverHTTP@46d2470f::SocketChannelEndPoint@28809e7a{l=/192.168.1.y:56002,r=/192.168.1.x:3000,ISHUT,fill=-,flush=-,to=0/0}{
io=0/0,kio=0,kro=1}->HttpConnectionOverHTTP@46d2470f(l:/192.168.1.y:56002 <-> r:/192.168.1.x:3000,closed=false)=>HttpChannelOverHTTP@38a874be(exchange=HttpExchange@27c6af09{req=WebSocketUpgradeRequest[GET / HTTP/1.1]@73786ec1[TERMINAT
ED/null] res=HttpResponse[null 0 null]@5fa74d9a[PENDING/null]})[send=HttpSenderOverHTTP@2451cf54(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@367d8230{s=START}],recv=HttpReceiverOverHTTP@643ec58(rsp=IDLE,failure=null)[HttpParser{
s=CLOSED,0 of -1}]]
- openHBA:
3.4.1
- TV Model:
OLED77C29LD
- webOS TV-Version:
7.3.0-16 (mullet-mebbin)
- Softwareversion:
03.30.16
Installed the update yesterday.
