Lidl TS0505A Colour Bulb with Zigbee binding can't set color
I have read the available threads similar to my problem with this Zigbee bulb and tried the solutions, but the problem is a little different.
THREAD: brightness control
THREAD: color control.
Set up
Raspi 4 openHAB 3.3.0 Release via openhabian install.
Zigbee binding installed via addons.cfg
zigbee Things defined via home.cfg
Bridge zigbee:coordinator_ember:stick "Zigbee USB Stick" [zigbee_port="/dev/ttyACM1", zigbee_baud=115200, zigbee_flowcontrol=1, zigbee_childtimeout=864000, zigbee_concentrator=1, zigbee_meshupdateperiod=86400, zigbee_panid=47447, zigbee_extendedpanid="EB6242A6B1AFB3BE", zigbee_networkkey="5A 69 67 42 65 65 41 6C 6C 69 61 6E 63 65 30 39", zigbee_powermode=1, zigbee_txpower=8]
   Thing device 4c5bb3fffe73ba51 "Innr SP 222 1" [ zigbee_macaddress= "4C5BB3FFFE73BA51"]
   Thing device f4b3b1fffe42365d "Innr SP 222 2" [ zigbee_macaddress= "f4b3b1fffe42365d"]
   Thing device 00158d0001d0c5bd "Innr BY 256 1" [ zigbee_macaddress= "00158d0001d0c5bd"]
   Thing device 00158d0001d0f07d "Innr BY 256 2" [ zigbee_macaddress= "00158d0001d0f07d"]
   Thing device 842E14FFFE02C3F8 "Lidl TS0505A 1" [ zigbee_macaddress= "842E14FFFE02C3F8"]
   Thing device 588e81fffed402f7 "Lidl TS0505A 2" [ zigbee_macaddress= "588e81fffed402f7"]
The problem I have is with the two Lidl TS050A bulbs. Their things look to define fine:
Their items are defined in .items file and this all links correctly.
Dimmer    LidlTS0505A_2Colortemperature              "Lidl 2 Color temperature"                      (gPrototype)                          {channel="zigbee:device:stick:588e81fffed402f7:588E81FFFED402F7_1_colortemperature"}
Color     LidlTS0505A_2Color                         "Lidl 2 Color"                                  (gPrototype)                          {channel="zigbee:device:stick:588e81fffed402f7:588E81FFFED402F7_1_color"}
Switch    LidlTS0505A_2Toggle                        "Lidl 2 Switch"                                 (gPrototype)                          {channel="zigbee:device:stick:588e81fffed402f7:588E81FFFED402F7_1_color"}
Dimmer    LidlTS0505A_2ColorBrightness               "Lidl 2 Color Brightness"                       (gPrototype)                          {channel="zigbee:device:stick:588e81fffed402f7:588E81FFFED402F7_1_color"}
I get the color temperature channel and am able to link an item that works !
I get the color channel and am able to link it to three item types: Color, Dimmer and Switch
I have set the Color Channel Details to XY Commands
The Switch and Dimmer item works just fine, but the color picker doesn’t
The Brightness control works fine but neither the Hue or Saturation control effects the bulb.
Any help apricated.
I have even tried this with a similar setup that doesn’t use file configuration .items or .things files, but I get the same results.
To dig in a bit deeper I have used the openhab console with the zigbee commands.
openhab> zigbee nodes
Total known nodes in network: 8
Network  Addr  IEEE Address      Logical Type  State      EP   Profile                    Device Type                Manufacturer     Model
      0  0000  E0798DFFFEA831F1  COORDINATOR   ONLINE
  15482  3C7A  00158D0001D0F07D  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     DIMMABLE_LIGHT             innr             BY 265
                                                         242  ZIGBEE_GREEN_POWER         0061
  26030  65AE  588E81FFFED402F7  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_dbou1ap4  TS0505A
  26288  66B0  842E14FFFE02C3F8  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_dbou1ap4  TS0505A
  54908  D67C  F4B3B1FFFE42365D  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_PLUG_IN_UNIT        innr             SP 222
  59508  E874  001C550000084201  UNKNOWN       UNKNOWN
  60104  EAC8  4C5BB3FFFE73BA51  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_PLUG_IN_UNIT        innr             SP 222
  62158  F2CE  00158D0001D0C5BD  ROUTER        UNKNOWN     1  ZIGBEE_HOME_AUTOMATION     DIMMABLE_LIGHT             innr             BY 265
openhab> zigbee fingerprint 0x65AE
output appears to agree to one included in the first thread referenced
|>| Node Descriptor
| |> Logical Type               ROUTER
| |> MAC Capabilities           [FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE]
| |> Stack Compliance           22
| |> Server Capabilities        []
| |> Buffer Size                82
| |> Incoming Transfer Size     82
| |> Outgoing Transfer Size     82
|>| Power Descriptor
| |> Available Power Sources    [MAINS]
| |> Current Power Source       MAINS
| |> Current Power Mode         RECEIVER_ON_IDLE
| |> Power Level                FULL
|>| ZDO
| |> ManagementBindRequest      SUCCESS
| |> IeeeAddressRequest         SUCCESS
| |> ManagementLqiRequest       SUCCESS
| |> ManagementRoutingRequest   SUCCESS
|>| Basic Information
| |> Generic Device Class
| |> Generic Device Type
| |> Manufacturer Name          _TZ3000_dbou1ap4
| |> Model Indentifier          TS0505A
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version        80
| |> Software Build ID
| |> Hardware Version           1
| |> Zcl Version                3
| |> Stack Version              0
| |>| Endpoint 1
| | |> Profile                  0104  ZIGBEE_HOME_AUTOMATION
| | |> Device Type              010D  EXTENDED_COLOR_LIGHT
| | |> Device Version           1
| | |>| Input Clusters
| | | | |> Type                 Server [Input]
| | | | |> Manufacturer Spec.   No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> 0000  ZCL Version                               >> UNSIGNED_8_BIT_INTEGER          3
| | | | | |> 0001  Application Version                       >> UNSIGNED_8_BIT_INTEGER          80
| | | | | |> 0002  Stack Version                             >> UNSIGNED_8_BIT_INTEGER          0
| | | | | |> 0003  HW Version                                >> UNSIGNED_8_BIT_INTEGER          1
| | | | | |> 0004  Manufacturer Name                         >> CHARACTER_STRING                _TZ3000_dbou1ap4
| | | | | |> 0005  Model Identifier                          >> CHARACTER_STRING                TS0505A
| | | | | |> 0006  Date Code                                 >> CHARACTER_STRING
| | | | | |> 0007  Power Source                              >> ENUMERATION_8_BIT               1
| | | | | |> FFDE                                            >> UNSIGNED_8_BIT_INTEGER          11
| | | | | |> FFFD  Cluster Revision                          >> UNSIGNED_16_BIT_INTEGER         2
| | | | | |> FFFE  Attribute Reporting Status                >> ENUMERATION_16_BIT              0
| | | |>| Cluster 0003 Identify
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000  Scene Count                               >> UNSIGNED_8_BIT_INTEGER          0
| | | | | |> 0001  Current Scene                             >> UNSIGNED_8_BIT_INTEGER          0
| | | | | |> 0002  Current Group                             >> UNSIGNED_16_BIT_INTEGER         0
| | | | | |> 0003  Scene Valid                               >> BOOLEAN                         false
| | | | | |> 0004  Name Support                              >> BITMAP_8_BIT                    0
| | | |>| Cluster 0006 On/Off
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000  On Off                                    >> BOOLEAN                         true
| | | |>| Cluster 0008 Level Control
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000  Current Level                             >> UNSIGNED_8_BIT_INTEGER          254
| | | | | |> 000F  Options                                   >> BITMAP_8_BIT                    0
| | | | | |> FFFD  Cluster Revision                          >> UNSIGNED_16_BIT_INTEGER         1
| | | |>| Cluster 0300 Color Control
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 1000
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 000A Time
| | | | |> Type                 Client [Output]
| | | | |> Unsupported locally
| | | |>| Cluster 0019 Ota Upgrade
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000  Upgrade Server ID                         >> IEEE_ADDRESS                    FFFFFFFFFFFFFFFF
| | | | | |> 0001  File Offset                               >> UNSIGNED_32_BIT_INTEGER         -1
| | | | | |> 0006  Image Upgrade Status                      >> ENUMERATION_8_BIT               0
| | | | | |> FFFD  Cluster Revision                          >> UNSIGNED_16_BIT_INTEGER         3
| |>| Endpoint 242
| | |> Profile                  A1E0  ZIGBEE_GREEN_POWER
| | |> Device Type              0061
| | |> Device Version           0
openhab> zigbee node 0x65AE
appears to list the COLOR_CONTROL
IEEE Address     : 588E81FFFED402F7
Network Address  : 26030
Node Descriptor  : NodeDescriptor [apsFlags=0, bufferSize=82, complexDescriptorAvailable=false, manufacturerCode=1002, logicalType=ROUTER, serverCapabilities=[], incomingTransferSize=82, outgoingTransferSize=82, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false, stackCompliance=22]
Power Descriptor : PowerDescriptor [currentPowerMode=RECEIVER_ON_IDLE, availablePowerSources=[MAINS], currentPowerSource=MAINS, powerLevel=FULL]
Associations     : []
Endpoints        :
            1    : Profile     ZIGBEE_HOME_AUTOMATION
                 : Device Type EXTENDED_COLOR_LIGHT
                   -> BASIC
                   -> IDENTIFY
                   -> GROUPS
                   -> SCENES
                   -> ON_OFF
                   -> LEVEL_CONTROL
                   -> COLOR_CONTROL
                   -> 0x1000
                   <- TIME
                   <- OTA_UPGRADE
            242  : Profile     ZIGBEE_GREEN_POWER
                 : Device Type 0061
                   <- GREEN_POWER
Neighbors        :
Routes           :
openhab> zigbee read 26030/1 0x0300
These values change with values set by the color picker however it didn’t appear to be very deterministic.
I was unable to figure out the console syntax to send Zigbee commands, if anyone knows, that could perhaps help with debugging.
Reading endpoint 65AE/1, cluster server cluster Color Control (0300), attributes Current Hue, Current Saturation, Remaining Time, Current X, Current Y, Color Temperature, Color Mode, Cluster Revision
Response for cluster 0x0300
Attribute    0  Current Hue                                         UNSIGNED_8_BIT_INTEGER          152
Attribute    1  Current Saturation                                  UNSIGNED_8_BIT_INTEGER          254
Attribute    2  Remaining Time                                      UNSIGNED_16_BIT_INTEGER         0
Attribute    3  Current X                                           UNSIGNED_16_BIT_INTEGER         45874
Attribute    4  Current Y                                           UNSIGNED_16_BIT_INTEGER         19660
Attribute    7  Color Temperature                                   UNSIGNED_16_BIT_INTEGER         153
Attribute    8  Color Mode                                          ENUMERATION_8_BIT               2
Attribute 65533  Cluster Revision                                    UNSIGNED_16_BIT_INTEGER         2
I turned on debug
log:set debug org.openhab.binding.zigbee
log:set debug com.zsmartsystems.zigbee
log:set info com.zsmartsystems.zigbee.dongle.ember.internal.ash
debug log in the file below
debug log.txt (146.7 KB)
Thanks for the support
Looking at the log, the binding is using the HSB commands - not the XY commands. So it seems that this is possibly not set?
You cna use the zigbee write command to write to an attribute.
Thanks Chris.
Okay, so this was the hint to help further debugging: What I have found is that if I define the Lidl TS0505A Thing by configuration file it is not possible to change the color control Method to XY in the OH3 GUI. Don’t know why I didn’t think of that before.
The GUI doesn’t complain it just doesn’t give the ā€œThing updatedā€ message.
The logs I collected above are from a file configured Thing and although I said ā€˜I have set the Color Channel Details to XY Commands’ apparently it silently fails.
so I tried again without configuration files and was able to use the GUI to set the Color Channel Details to XY Commands. (though I had done this before but couldn’t have). It worked; thanks for the pointer.
Is it possible to define the Thing or modify the color channel to the XY control method via a config file?
Something like:
Thing device 588e81fffed402f7 "Lidl TS0505A 2" [ zigbee_macaddress = "588e81fffed402f7", ColorMode = "XY"]
Yep tried that (see below) but bulb remained stubbornly unchanged. Maybe I’m missing something.
openhab> zigbee read 57672/1 0x0300
Reading endpoint E148/1, cluster server cluster Color Control (0300), attributes Current Hue, Current Saturation, Remaining Time, Current X, Current Y, Color Temperature, Color Mode, Cluster Revision
Attribute    0  Current Hue                                         UNSIGNED_8_BIT_INTEGER          0
Attribute    3  Current X                                           UNSIGNED_16_BIT_INTEGER         13934
Attribute    4  Current Y                                           UNSIGNED_16_BIT_INTEGER         18703
Attribute    7  Color Temperature                                   UNSIGNED_16_BIT_INTEGER         500
Attribute    8  Color Mode                                          ENUMERATION_8_BIT               1
openhab> zigbee write 57672/1 0x0300 3 13934
Attribute value write success.
openhab> zigbee write 57672/1 0x0300 4 18703
Thanks for your help.
What were you expecting to change? You wrote the same value as was already set, and then read it back and it was the same - that looks correct to me. The writes were successful though.
eg -:
Attribute    3  Current X                                           UNSIGNED_16_BIT_INTEGER         **13934**
zigbee write 57672/1 0x0300 3 **13934**
Sorry Chris, I forgot to say, I moved the light colour via the OH3 GUI colour picker to a red colour right before sending the write commands. The values I sent should have turned the light blue.
Ok, but the write was still successful, so it is working ok…
Hi there,
I’ve got a similar problem I don’t get my Livarno Home Smart LED Light Bar to change Colors - it only changes color temp.
My items are correct from my point of view:
Color Kueche_Stimmungslicht_links_Color               "Stimmungslicht Farbwahl"      <colorpicker>                       {channel="zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color" }
Color Kueche_Stimmungslicht_rechts_Color               "Stimmungslicht Farbwahl"      <colorpicker>                       {channel="zigbee:device:87b026a31c:b4e3f9fffee7771d:B4E3F9FFFEE7771D_1_color" }
I’ve got the following nodes online:
Total known nodes in network: 54
      0  0000  DC8E95FFFE0B603A  COORDINATOR   ONLINE
   2012  07DC  9035EAFFFE124078  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH       EcoDim           ED-10014
                                                           2  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH
                                                           3  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH
                                                           4  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH
   2354  0932  385B44FFFE1B267C  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
   2555  09FB  84BA20FFFEC4B7C3  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH       EcoDim           ED-10014
   3367  0D27  0C4314FFFE64C56E  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
   3480  0D98  B4E3F9FFFE09197A  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
   4689  1251  00124B0025147F4B  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE
   6722  1A42  00124B002911986E  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
   8142  1FCE  B4E3F9FFFEA76D5F  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
   8757  2235  00124B0029299581  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
   9833  2669  00124B0029112D46  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  10742  29F6  9035EAFFFE02DAD6  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3210_r0xgkft5  TS0505B
  11213  2BCD  50325FFFFEACB2FA  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  11504  2CF0  00124B002513D5AC  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  12705  31A1  0000000000000000  UNKNOWN       ONLINE
  13063  3307  00124B0029118FA8  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  13074  3312  B4E3F9FFFE358C52  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  13460  3494  B4E3F9FFFE08F783  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  13756  35BC  00124B002513DC81  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  14443  386B  0C4314FFFE64C580  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  15806  3DBE  385B44FFFE143D5B  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  16206  3F4E  00124B0025497EA5  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  17837  45AD  00124B0029119478  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  17977  4639  DC8E95FFFE1E313E  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  22063  562F  00124B002911228B  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  22668  588C  00124B002513DCA4  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  22826  592A  B4E3F9FFFEE7771D  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3210_iystcadi  TS0505B
  22830  592E  0C4314FFFE57C066  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  22973  59BD  DC8E95FFFE1E3154  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  26143  661F  B4E3F9FFFEA764C7  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  28220  6E3C  385B44FFFE1B2982  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  28708  7024  0C4314FFFE600162  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  28990  713E  B4E3F9FFFEA76932  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  31576  7B58  00124B002513D58C  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  32501  7EF5  00124B002513CE6B  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  33868  844C  00124B0025120B61  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE
  34548  86F4  84BA20FFFEC4D37C  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     LEVEL_CONTROL_SWITCH       EcoDim           ED-10014
  36639  8F1F  0C4314FFFE5B5EBA  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  37176  9138  B4E3F9FFFECA363C  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3210_iystcadi  TS0505B
  39132  98DC  DC8E95FFFE1E314C  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  40063  9C7F  0C4314FFFE64B04A  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  43217  A8D1  60A423FFFEB02B7B  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     COLOR_TEMPERATURE_LIGHT    _TZ3000_el5kt5im  TS0502A
  49082  BFBA  00158D00024FC323  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     DIMMABLE_LIGHT             Immax            IM-Z3.0-DIM
                                                         242  ZIGBEE_GREEN_POWER         0066
  50000  C350  385B44FFFE1F5F26  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  50746  C63A  B4E3F9FFFEE16DC8  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  52360  CC88  00124B00292818BF  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  52604  CD7C  B4E3F9FFFEC0AB18  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     EXTENDED_COLOR_LIGHT       _TZ3000_qd7hej8u  TS0505B
  57084  DEFC  385B44FFFE1B24CC  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     ON_OFF_LIGHT               SONOFF           01MINIZB
  58799  E5AF  00124B0029111638  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  61357  EFAD  847127FFFE90EC19  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     COLOR_TEMPERATURE_LIGHT    _TZ3000_el5kt5im  TS0502A
  62502  F426  847127FFFE8F7F94  ROUTER        ONLINE      1  ZIGBEE_HOME_AUTOMATION     COLOR_TEMPERATURE_LIGHT    _TZ3000_el5kt5im  TS0502A
  63328  F760  00124B002513DA56  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  63951  F9CF  00124B0029119846  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
  64531  FC13  00124B0029119984  END_DEVICE    ONLINE      1  ZIGBEE_HOME_AUTOMATION     IAS_ZONE                   eWeLink          MS01
The relevant are:
openhab> zigbee fingerprint 0x592A
|>| Node Descriptor
| |> Logical Type               ROUTER
| |> Stack Compliance           22
| |> Buffer Size                82
|>| Power Descriptor
| |> Power Level                FULL
|>| ZDO
|>| Basic Information
| |> Generic Device Type
| |> Manufacturer Name          _TZ3210_iystcadi
| |> Model Indentifier          TS0505B
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version        66
| |> Software Build ID
| |> Hardware Version           1
| |> Zcl Version                3
| |> Stack Version              0
| |>| Endpoint 1
| | |> Device Version           1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0001  Application Version                       >> UNSIGNED_8_BIT_INTEGER          66
| | | | | |> 0004  Manufacturer Name                         >> CHARACTER_STRING                _TZ3210_iystcadi
| | | | | |> 0005  Model Identifier                          >> CHARACTER_STRING                TS0505B
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | |>| Cluster 0006 On/Off
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000  On Off                                    >> BOOLEAN                         false
| | | | | |> F000                                            >> UNSIGNED_32_BIT_INTEGER         0
| | | | |> Type                 Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> F000                                            >> UNSIGNED_16_BIT_INTEGER         1000
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 1000
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster EF00
| | | | |> Type                 Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 000A Time
| | | | |> Unsupported locally
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| |>| Endpoint 242
| | |> Device Type              0061
| | |> Device Version           0
the logs are saying:
2023-03-14 18:14:36.372 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'Kueche_Stimmungslicht_links_Color' received command 290,90,79
2023-03-14 18:14:36.374 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Kueche_Stimmungslicht_links_Color' predicted to become 290,90,79
2023-03-14 18:14:37.265 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteErrorHandler [networkId=0, status=EMBER_MAC_INDIRECT_TIMEOUT, target=2669]
2023-03-14 18:14:38.859 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingRouteErrorHandler [networkId=0, status=EMBER_MAC_INDIRECT_TIMEOUT, target=2669]
2023-03-14 18:14:39.803 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 84BA20FFFEC4B7C3: Polling 16 channels
2023-03-14 18:14:39.804 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 84BA20FFFEC4B7C3: Polling zigbee:device:87b026a31c:84ba20fffec4b7c3:84BA20FFFEC4B7C3_1_batteryvoltage
2023-03-14 18:14:39.806 [DEBUG] [.zsmartsystems.zigbee.zcl.ZclCluster] - readSync request: ZclAttribute [cluster=Power Configuration, id=32, name=Battery Voltage, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=33, lastReportTime=Tue Mar 14 17:54:12 CET 2023, implemented=true]
2023-03-14 18:14:39.808 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - 84BA20FFFEC4B7C3: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=84BA20FFFEC4B7C3 queueTime=0, state=WAITING, sendCnt=0, command=ReadAttributesCommand [Power Configuration: 0000/0 -> 09FB/1, cluster=0001, TID=--, identifiers=[32]]]
2023-03-14 18:14:39.809 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=3, sleepy=0/3
2023-03-14 18:14:39.810 [DEBUG] [transaction.ZigBeeTransactionManager] - 09FB/1: Sending ZigBeeTransaction [ieeeAddress=84BA20FFFEC4B7C3 queueTime=3, state=WAITING, sendCnt=0, command=ReadAttributesCommand [Power Configuration: 0000/0 -> 09FB/1, cluster=0001, TID=A9, identifiers=[32]]]
2023-03-14 18:14:39.812 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2023-03-14 18:14:39.813 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ReadAttributesCommand [Power Configuration: 0000/0 -> 09FB/1, cluster=0001, TID=A9, identifiers=[32]]
2023-03-14 18:14:39.815 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=A9, commandId=0]
2023-03-14 18:14:39.816 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=09FB/1, profile=0104, cluster=0001, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=31, rssi=--, lqi=--, payload=00 A9 00 20 00]
2023-03-14 18:14:39.818 [DEBUG] [transaction.ZigBeeTransactionManager] - 9138/1: Sending ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=3430, state=WAITING, sendCnt=0, command=MoveToHueAndSaturationCommand [Color Control: 0000/0 -> 9138/1, cluster=0300, TID=AA, hue=205, saturation=229, transitionTime=10]]
2023-03-14 18:14:39.819 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2023-03-14 18:14:39.821 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: MoveToHueAndSaturationCommand [Color Control: 0000/0 -> 9138/1, cluster=0300, TID=AA, hue=205, saturation=229, transitionTime=10]
2023-03-14 18:14:39.822 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=AA, commandId=6]
2023-03-14 18:14:39.824 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=9138/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=32, rssi=--, lqi=--, payload=01 AA 06 CD E5 0A 00]
2023-03-14 18:14:39.827 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=2E]
2023-03-14 18:14:39.847 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=2F]
2023-03-14 18:14:39.922 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=01], lastHopLqi=140, lastHopRssi=-65, sender=9138, bindingIndex=255, addressIndex=255, messageContents=08 AA 0B 06 00]
2023-03-14 18:14:39.925 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=9138/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=01, rssi=-65, lqi=8C, payload=08 AA 0B 06 00]
2023-03-14 18:14:39.928 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node update. NWK Address=NULL
2023-03-14 18:14:39.930 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node 9138 is not updated from ZigBeeNode [state=ONLINE, IEEE=B4E3F9FFFECA363C, NWK=----, endpoints=[]]
2023-03-14 18:14:39.933 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=AA, commandId=11]
2023-03-14 18:14:39.935 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [Color Control: 9138/1 -> 0000/1, cluster=0300, TID=AA, commandIdentifier=6, statusCode=SUCCESS]
2023-03-14 18:14:39.937 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Color Control: 9138/1 -> 0000/1, cluster=0300, TID=AA, commandIdentifier=6, statusCode=SUCCESS]
2023-03-14 18:14:39.940 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B4E3F9FFFECA363C: Channel zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color received SUCCESS in response to 290,90,79
2023-03-14 18:14:39.940 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=3552, state=COMPLETE, sendCnt=1, command=MoveToHueAndSaturationCommand [Color Control: 0000/0 -> 9138/1, cluster=0300, TID=AA, hue=205, saturation=229, transitionTime=10]]
2023-03-14 18:14:39.942 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2023-03-14 18:14:39.943 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B4E3F9FFFECA363C: Channel zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color updated to 290,90,79
2023-03-14 18:14:39.944 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFECA363C: Updating ZigBee channel state zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color to 290,90,79
2023-03-14 18:14:39.945 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFECA363C: transactionComplete, state=COMPLETE, outstanding=0
2023-03-14 18:14:39.945 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=9138, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=2F], messageTag=AA, status=EMBER_SUCCESS, messageContents=]
2023-03-14 18:14:39.946 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c
2023-03-14 18:14:39.948 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=AA state=RX_ACK
2023-03-14 18:14:39.948 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=02], lastHopLqi=144, lastHopRssi=-64, sender=9138, bindingIndex=255, addressIndex=255, messageContents=18 00 0A 01 00 20 E5]
2023-03-14 18:14:39.948 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=1/3
2023-03-14 18:14:39.949 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c
2023-03-14 18:14:39.949 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=AA, state=RX_ACK, outstanding=1
2023-03-14 18:14:39.950 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c in 14430 seconds
2023-03-14 18:14:39.950 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=9138/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=02, rssi=-64, lqi=90, payload=18 00 0A 01 00 20 E5]
2023-03-14 18:14:39.953 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node update. NWK Address=NULL
2023-03-14 18:14:39.955 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node 9138 is not updated from ZigBeeNode [state=ONLINE, IEEE=B4E3F9FFFECA363C, NWK=----, endpoints=[]]
2023-03-14 18:14:39.956 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=00, commandId=10]
2023-03-14 18:14:39.957 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ReportAttributesCommand [Color Control: 9138/1 -> 0000/1, cluster=0300, TID=00, reports=[AttributeReport [attributeDataType=UNSIGNED_8_BIT_INTEGER, attributeIdentifier=1, attributeValue=229]]]
2023-03-14 18:14:39.958 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Color Control: 9138/1 -> 0000/1, cluster=0300, TID=00, reports=[AttributeReport [attributeDataType=UNSIGNED_8_BIT_INTEGER, attributeIdentifier=1, attributeValue=229]]]
2023-03-14 18:14:39.960 [DEBUG] [rter.ZigBeeConverterColorTemperature] - B4E3F9FFFECA363C: ZigBee attribute reports ZclAttribute [cluster=Color Control, id=1, name=Current Saturation, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=229, lastReportTime=Tue Mar 14 18:14:39 CET 2023, implemented=true]  on endpoint 1
2023-03-14 18:14:39.960 [DEBUG] [.converter.ZigBeeConverterColorColor] - B4E3F9FFFECA363C: ZigBee attribute reports ZclAttribute [cluster=Color Control, id=1, name=Current Saturation, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=229, lastReportTime=Tue Mar 14 18:14:39 CET 2023, implemented=true]
2023-03-14 18:14:39.962 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0300, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=03], lastHopLqi=140, lastHopRssi=-65, sender=9138, bindingIndex=255, addressIndex=255, messageContents=18 7F 0A 02 F1 48 0C 01 01 23 01 86 03 17 03 17 03 5C 00]
2023-03-14 18:14:39.964 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=9138/1, destinationAddress=0000/1, profile=0104, cluster=0300, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=03, rssi=-65, lqi=8C, payload=18 7F 0A 02 F1 48 0C 01 01 23 01 86 03 17 03 17 03 5C 00]
2023-03-14 18:14:39.965 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node update. NWK Address=NULL
2023-03-14 18:14:39.966 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node 9138 is not updated from ZigBeeNode [state=ONLINE, IEEE=B4E3F9FFFECA363C, NWK=----, endpoints=[]]
2023-03-14 18:14:39.967 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=true, manufacturerCode=0, sequenceNumber=7F, commandId=10]
2023-03-14 18:14:39.968 [ERROR] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler Exception processing EZSP frame:
java.lang.IllegalArgumentException: No reader defined in ZigBeeDeserializer for DATA_40_BIT (0x0C)
	at com.zsmartsystems.zigbee.serialization.DefaultDeserializer.readZigBeeType(DefaultDeserializer.java:345) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.serialization.DefaultDeserializer.readZigBeeType(DefaultDeserializer.java:328) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.zcl.field.AttributeReport.deserialize(AttributeReport.java:101) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.zcl.ZclFieldDeserializer.deserialize(ZclFieldDeserializer.java:73) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.zcl.clusters.general.ReportAttributesCommand.deserialize(ReportAttributesCommand.java:111) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.ZigBeeNetworkManager.receiveZclCommand(ZigBeeNetworkManager.java:1158) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.ZigBeeNetworkManager.receiveCommand(ZigBeeNetworkManager.java:986) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.dongle.ember.ZigBeeDongleEzsp.handlePacket(ZigBeeDongleEzsp.java:937) ~[bundleFile:?]
	at com.zsmartsystems.zigbee.dongle.ember.internal.ash.AshFrameHandler$AshReceiveProcessorThread.run(AshFrameHandler.java:399) [bundleFile:?]
2023-03-14 18:14:40.462 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B4E3F9FFFECA363C: Channel zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color updated to 290.55118,90.15748,79
2023-03-14 18:14:40.464 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFECA363C: Updating ZigBee channel state zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color to 290.55118,90.15748,79
2023-03-14 18:14:40.466 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker reset for handler with thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c
2023-03-14 18:14:40.468 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker cancelled task for thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c
2023-03-14 18:14:40.469 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - IsAlive Tracker scheduled task for thingUID=zigbee:device:87b026a31c:b4e3f9fffeca363c in 14430 seconds
2023-03-14 18:14:41.011 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B4E3F9FFFECA363C: Command for channel zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color --> 290,90,79 [HSBType]
2023-03-14 18:14:41.012 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFECA363C: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=0, state=WAITING, sendCnt=0, command=MoveToLevelWithOnOffCommand [Level Control: 0000/0 -> 9138/1, cluster=0008, TID=--, level=201, transitionTime=10]]
2023-03-14 18:14:41.013 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=2, sleepy=1/3
2023-03-14 18:14:41.014 [DEBUG] [transaction.ZigBeeTransactionManager] - 9138/1: Sending ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=2, state=WAITING, sendCnt=0, command=MoveToLevelWithOnOffCommand [Level Control: 0000/0 -> 9138/1, cluster=0008, TID=AB, level=201, transitionTime=10]]
2023-03-14 18:14:41.015 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2023-03-14 18:14:41.016 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: MoveToLevelWithOnOffCommand [Level Control: 0000/0 -> 9138/1, cluster=0008, TID=AB, level=201, transitionTime=10]
2023-03-14 18:14:41.017 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX ZCL: ZclHeader [frameType=CLUSTER_SPECIFIC_COMMAND, manufacturerSpecific=false, direction=CLIENT_TO_SERVER, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=AB, commandId=4]
2023-03-14 18:14:41.018 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/1, destinationAddress=9138/1, profile=0104, cluster=0008, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=33, rssi=--, lqi=--, payload=01 AB 04 C9 0A 00]
2023-03-14 18:14:41.019 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - B4E3F9FFFECA363C: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=0, state=WAITING, sendCnt=0, command=MoveToHueAndSaturationCommand [Color Control: 0000/0 -> 9138/1, cluster=0300, TID=--, hue=205, saturation=229, transitionTime=10]]
2023-03-14 18:14:41.020 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=2, outstandingQueues=2, sleepy=1/3
2023-03-14 18:14:41.021 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B4E3F9FFFECA363C: Channel zigbee:device:87b026a31c:b4e3f9fffeca363c:B4E3F9FFFECA363C_1_color waiting for response to 290,90,79
2023-03-14 18:14:41.028 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=30]
2023-03-14 18:14:41.057 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0104, clusterId=0008, sourceEndpoint=1, destinationEndpoint=1, options=[EMBER_APS_OPTION_RETRY, EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=04], lastHopLqi=140, lastHopRssi=-65, sender=9138, bindingIndex=255, addressIndex=255, messageContents=08 AB 0B 04 00]
2023-03-14 18:14:41.059 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=9138/1, destinationAddress=0000/1, profile=0104, cluster=0008, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=04, rssi=-65, lqi=8C, payload=08 AB 0B 04 00]
2023-03-14 18:14:41.060 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node update. NWK Address=NULL
2023-03-14 18:14:41.061 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - B4E3F9FFFECA363C: Node 9138 is not updated from ZigBeeNode [state=ONLINE, IEEE=B4E3F9FFFECA363C, NWK=----, endpoints=[]]
2023-03-14 18:14:41.062 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX ZCL: ZclHeader [frameType=ENTIRE_PROFILE_COMMAND, manufacturerSpecific=false, direction=SERVER_TO_CLIENT, disableDefaultResponse=false, manufacturerCode=0, sequenceNumber=AB, commandId=11]
2023-03-14 18:14:41.064 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DefaultResponse [Level Control: 9138/1 -> 0000/1, cluster=0008, TID=AB, commandIdentifier=4, statusCode=SUCCESS]
2023-03-14 18:14:41.065 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [Level Control: 9138/1 -> 0000/1, cluster=0008, TID=AB, commandIdentifier=4, statusCode=SUCCESS]
2023-03-14 18:14:41.066 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=B4E3F9FFFECA363C queueTime=54, state=COMPLETE, sendCnt=1, command=MoveToLevelWithOnOffCommand [Level Control: 0000/0 -> 9138/1, cluster=0008, TID=AB, level=201, transitionTime=10]]
So what are the next steps to find out what to do?
Thanks in advance - sorry I need some support cause I don’t quite understand where to look for the error.
Hi Andreas
Did you fix this?
See you received no response, if you still need support maybe try opening a new thread on your issue.
But …
Not sure if you read through the detail in the thread, but the solution I found was to set the Thing Color Channel Details to XY Commands.
This appears to be only possible to do if the thing is not defined by a configuration file, but through the OH3 GUI
Please excuse me for not replying for so long. Not my style.
Yeah I found out you could switch the Color Channel Details latter on. But in the meantime I switched to Z2M.
