When I toggle the light it sends first 100, then a second later a lower value like 15 is reported…and the light stays at the lower 15% brightness…so it is not increasing to the initial value of 100.
When I use the brightness slider in the locations tab and set it to 100% and then 0% the toggling works again for full brightness…
I assume the lower value comes back from the Hue light…so maybe some parameter available in ZigBee for setting the ramping for switching on?
MDAR
#4
Oh, I see.
Sorry, I didn’t realise that you meant your lamp wasn’t continuing to change.
To understand what you see in the logs, understand ‘autoupdate’.
You can change the behaviour by disabling autoupdate.
You haven’t described the physical response at your device, but guessing that it resumes a previously-set brightness when you command it ON - many people would see that as desirable behaviour.
(This is very device dependent, not all bindings do it that way)
Is this a problem for ypou, or just a puzzle over the logging?
