Continuing the discussion from LightwaveRF - New LightwaveRF Binding:
Using Dave’s LightwaveRF binding for 2 years, just now moving from OH2.5 to OH3.1.
Activated the latest binding from org.openhab.binding.lightwaverf-3.2.0-SNAPSHOT_3.11.jar and having trouble swithing on/off GEN1 switch devices.
Testing this binding for a GEN1 LightwaveRF gateway (KaKU ICS1000), not using a cloud account.
Manually added with UI a brigde called ics1000 (GEN1 device) by IP
UID: lightwaverf:1bridge:ics1000
label: ics1000
thingTypeUID: lightwaverf:1bridge
configuration:
ipaddress: 192.168.0.11
Manually added in UI a 1-way switch thing (GEN1) with parameters: room1, device 4.
UID: lightwaverf:1switch:ics1000:RoomLight
label: RoomLight
thingTypeUID: lightwaverf:1switch
configuration:
deviceid: "4"
roomid: "1"
bridgeUID: lightwaverf:1bridge:ics1000
Both bridge and thing show ONLINE. Manual netcat sending !R1D4F1 triggers the switch successfully.
Triggering the switch via OH thing: nothing happens. Log shows Queuing of the command: No OK message received.
2022-01-09 17:49:26.492 [INFO ] [dler.LightwaverfConnectSwitchHandler] - Sending Command:,!RDF1 from device:
2022-01-09 17:49:26.495 [INFO ] [tions.LightwaverfConnectSenderThread] - added command to queue: 210,!RDF1
2022-01-09 17:49:29.600 [INFO ] [dler.LightwaverfConnectSwitchHandler] - Sending Command:,!RDF0 from device:
2022-01-09 17:49:29.605 [INFO ] [tions.LightwaverfConnectSenderThread] - added command to queue: 211,!RDF0
I suspect the binding for GEN1 is not sending the roomID (1) and deviceID (4) parameters: Sending !RDF1 where the gateway would expect !R1D4F1. This behaviour seems identical to issue mentioned at #488 by [Lukasz_Szafraniec].
Did I miss to configure anything for communication with the Gateway?
Let me know if I need to run more tests or logging.
