LightwaveRF - New LightwaveRF Binding
New binding is available below. jar will be kept up to date on git.
Ill do my best to keep on top of any issues reported.
Excuse my coding skills,I don’t have any I.T qualifications but wasnt going to let this beat me. :slight_smile:
Pre compiled:
Change Log
https://github.com/delid4ve/lightwaverf/blob/3.x/changeLog.txt
Readme
@xela @Fixer @s73ven @Greigc @pentiumdb
29days from loading up an IDE to start this project I feel it’s now in a great position. Report any bugs here now.
If anyone has loaded in the newest version be good to get some feedback. @Fixer let me know how this affects your cpu as I’ve removed the additional thread it was using for the polling and it seems a lot more stable.
Oh and if someone can check what bulb and dim setup items should actually be..
I’ll load it up tomorrow. Anything else I can report on besides cpu? Any log entries or stats that would be helpful?
If you switch to debug you can make sure that when you send a command it applies the lock, then removes it (you will also be able to see your polling time like this by calculating the difference between them).
Any other errors that get thrown, haven’t seen any in my logs since I loaded it up but maybe on a different system..
I’ll load it up on my dev OpenHAB tonight and have a play, I’ll check the locking too.
Everything is running nice on my main instance though :slight_smile:
:+1: Can you run both versions (1.0.6 without lock but extra thread, and 1.0.7 and check cpu usage for each while your there.
Tried 1.0.7 but some of my devices stopped polling so reverted to 1.0.1. However they’re still not polling and the LWRF app is really slow, barely responsive, so it looks like LWRF are messing about with the API again. Can’t really test until they stop
really?? not even 1.0.6?
have you added as text items now or still through the ui?
I went back to 1.0.1 as that’s what I was running yesterday when everything was polling.
What’s stopped is the ‘master’ side of my double socket. Not reporting anything.But the secondary side is working. Don’t want to reset the socket as it’s powering my internet router and Openhab server…
But as I said, I suspect LWRF are messing about as my app is terrible right now
Pushes to the device are working, just not reporting any power, voltage, outlet in use etc
UPDATE
Now moved the whole house onto the binding. 113 items. Version 1.0.7
Things all done through Paper UI but items defined in text file.
Control of everything tested and works great.
Updates however aren’t really working but I don’t know if that’s the binding yet or LWRF.
Spotted a bug with the 3-gang Gen2 dimmer but will post that on Git.
Pi Stats:
############### openHABianPi
Ip = x.x.x.x
Release = Raspbian GNU/Linux 9 (stretch)
Kernel = Linux 4.19.66-v7+
Platform = Raspberry Pi 3 Model B Plus Rev 1.3
Uptime = 0 day(s). 1:40:10
CPU Usage = 18.23% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 0.56, 5m: 0.61, 15m: 0.82
Memory = Free: 0.13GB (14%), Used: 0.82GB (86%), Total: 0.95GB
Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
Root = Free: 204.47GB (98%), Used: 3.38GB (2%), Total: 219.06GB
Updates = 0 apt updates available.
Sessions = 1 session(s)
Processes = 111 running processes of 32768 maximum processes
Your going to have to clean the cache where you’ve gone from 1.0.1 to 1.0.7.. (required for that older version change)
I have just uploaded v1.0.8 though to git
Version 1.0.8
Fixed 3/4 gang dimmer incorrect channel name
added token refresh
fixed link plus date format
with thanks to @rossko57 for the date format here:
Cleared the cache and gone to 1.0.8 but still hardly any updates. Pretty much the only thing that’s polling on a regular basis is the energy monitor - the firts thing I added.
UPDATE
Changed the polling interval from 5 to 10, things start polling again. Hmm…
Got to go out now, will play later
enable debug and see whats going on as you’ll get the json response message come up
@pentiumdb enable debug logging and see what you get come back.
are you sure your credentials are correct for lightwave as i believe the api throws the same message for incorrect username and password
I feel really dumb now! I updated java, pull docker, uploaded certificates, lost 5 hours of my life trying to troubleshoot this and yes it was wrong password :rofl: :rofl: :rofl:
There was definitely a cert error in the first instance.
The simple things though :joy:
Working ok now though??
@xela unfortunately it’s a 404 not found for incorrect username/password aswell as if it’s down on the login server.
The api server does give an unauthorised message if the token is wrong, but you won’t even get to this point if your credentials are wrong in the first instance.
I’ll change the message when I make any other changes to down or incorrect credentials
What have you got the group size set to? (Default is 20)..
Yes, working great now, i’m currently adding devices
Been messing about a lot.
Currently have the polling interval set to 10 and number of devices to 25.
Put the binding into debug and it seems to be polling just for the same two blocks of items over and over
2020-02-13 21:51:38.005 [DEBUG] [.lightwaverf.internal.UpdateListener] - response:{“5a6a3fbfc211836b17f98f26-264-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-265-3157328472+0”:100,“5a6a3fbfc211836b17f98f26-268-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-269-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-270-3157328472+0”:5062,“5a6a3fbfc211836b17f98f26-258-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-263-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-2-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-10-3157328472+0”:62041,“5a6a3fbfc211836b17f98f26-11-3157328472+0”:27153,“5a6a3fbfc211836b17f98f26-7-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-12-3157328472+0”:768,“5a6a3fbfc211836b17f98f26-132-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-58-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-59-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-61-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-62-3157328472+0”:4,“5a6a3fbfc211836b17f98f26-63-3157328472+0”:5121,“5a6a3fbfc211836b17f98f26-52-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-57-3157328472+0”:1}
2020-02-13 21:51:41.411 [DEBUG] [.lightwaverf.internal.UpdateListener] - response:{“5a6a3fbfc211836b17f98f26-64-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-65-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-67-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-68-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-69-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-76-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-32-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-77-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-33-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-34-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-79-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-35-3157328472+0”:88397378,“5a6a3fbfc211836b17f98f26-80-3157328472+0”:3,“5a6a3fbfc211836b17f98f26-36-3157328472+0”:4294967295,“5a6a3fbfc211836b17f98f26-25-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-70-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-30-3157328472+0”:16711680,“5a6a3fbfc211836b17f98f26-75-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-31-3157328472+0”:-2865,“5a6a3fbfc211836b17f98f26-82-3157328472+0”:0}
2020-02-13 21:51:53.262 [DEBUG] [.lightwaverf.internal.UpdateListener] - response:{“5a6a3fbfc211836b17f98f26-264-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-265-3157328472+0”:100,“5a6a3fbfc211836b17f98f26-268-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-269-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-270-3157328472+0”:5062,“5a6a3fbfc211836b17f98f26-258-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-263-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-2-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-10-3157328472+0”:62041,“5a6a3fbfc211836b17f98f26-11-3157328472+0”:27153,“5a6a3fbfc211836b17f98f26-7-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-12-3157328472+0”:768,“5a6a3fbfc211836b17f98f26-132-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-58-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-59-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-61-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-62-3157328472+0”:4,“5a6a3fbfc211836b17f98f26-63-3157328472+0”:5121,“5a6a3fbfc211836b17f98f26-52-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-57-3157328472+0”:1}
2020-02-13 21:51:55.153 [DEBUG] [.lightwaverf.internal.UpdateListener] - response:{“5a6a3fbfc211836b17f98f26-64-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-65-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-67-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-68-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-69-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-76-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-32-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-77-3157328472+0”:80,“5a6a3fbfc211836b17f98f26-33-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-34-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-79-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-35-3157328472+0”:88397378,“5a6a3fbfc211836b17f98f26-80-3157328472+0”:3,“5a6a3fbfc211836b17f98f26-36-3157328472+0”:4294967295,“5a6a3fbfc211836b17f98f26-25-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-70-3157328472+0”:0,“5a6a3fbfc211836b17f98f26-30-3157328472+0”:16711680,“5a6a3fbfc211836b17f98f26-75-3157328472+0”:1,“5a6a3fbfc211836b17f98f26-31-3157328472+0”:-2865,“5a6a3fbfc211836b17f98f26-82-3157328472+0”:0}
Very few item updates being shown in the normal log.
When I chnage the polling interval and/or the number of devices that seems to give it a poke and I get some updates coming through in the log for around 20 seconds or so then it stops again.
I can pull more logs at debug level if it helps
UPDATE
When I look under the properties of the Lightwave Account thing I seem to be seeing my devices listed multiple times which seems odd. I did clear the cache before moving to 1.0.8 so it can’t be that:
Access Token
Connected Device: 0 Simple DeviceId (sdId): 1, Product: Central Hub, Gen: 2, Channels: 1
Connected Device: 1 Simple DeviceId (sdId): 4, Product: Smart Socket, Gen: 2, Channels: 2
Connected Device: 10 Simple DeviceId (sdId): 29, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 100 Simple DeviceId (sdId): 35, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 101 Simple DeviceId (sdId): 36, Product: Energy Monitor, Gen: 1, Channels: 1
Connected Device: 102 Simple DeviceId (sdId): 37, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 103 Simple DeviceId (sdId): 38, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 104 Simple DeviceId (sdId): 39, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 105 Simple DeviceId (sdId): 41, Product: Smart Dimmer, Gen: 2, Channels: 3
Connected Device: 106 Simple DeviceId (sdId): 42, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 107 Simple DeviceId (sdId): 47, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 108 Simple DeviceId (sdId): 44, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 109 Simple DeviceId (sdId): 45, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 11 Simple DeviceId (sdId): 30, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 110 Simple DeviceId (sdId): 46, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 111 Simple DeviceId (sdId): 43, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 12 Simple DeviceId (sdId): 31, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 13 Simple DeviceId (sdId): 32, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 14 Simple DeviceId (sdId): 33, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 15 Simple DeviceId (sdId): 34, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 16 Simple DeviceId (sdId): 35, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 17 Simple DeviceId (sdId): 36, Product: Energy Monitor, Gen: 1, Channels: 1
Connected Device: 18 Simple DeviceId (sdId): 37, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 19 Simple DeviceId (sdId): 38, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 2 Simple DeviceId (sdId): 11, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 20 Simple DeviceId (sdId): 39, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 21 Simple DeviceId (sdId): 41, Product: Smart Dimmer, Gen: 2, Channels: 3
Connected Device: 22 Simple DeviceId (sdId): 42, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 23 Simple DeviceId (sdId): 47, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 24 Simple DeviceId (sdId): 44, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 25 Simple DeviceId (sdId): 45, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 26 Simple DeviceId (sdId): 46, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 27 Simple DeviceId (sdId): 43, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 28 Simple DeviceId (sdId): 1, Product: Central Hub, Gen: 2, Channels: 1
Connected Device: 29 Simple DeviceId (sdId): 4, Product: Smart Socket, Gen: 2, Channels: 2
Connected Device: 3 Simple DeviceId (sdId): 14, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 30 Simple DeviceId (sdId): 11, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 31 Simple DeviceId (sdId): 14, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 32 Simple DeviceId (sdId): 23, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 33 Simple DeviceId (sdId): 24, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 34 Simple DeviceId (sdId): 25, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 35 Simple DeviceId (sdId): 26, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 36 Simple DeviceId (sdId): 27, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 37 Simple DeviceId (sdId): 28, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 38 Simple DeviceId (sdId): 29, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 39 Simple DeviceId (sdId): 30, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 4 Simple DeviceId (sdId): 23, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 40 Simple DeviceId (sdId): 31, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 41 Simple DeviceId (sdId): 32, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 42 Simple DeviceId (sdId): 33, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 43 Simple DeviceId (sdId): 34, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 44 Simple DeviceId (sdId): 35, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 45 Simple DeviceId (sdId): 36, Product: Energy Monitor, Gen: 1, Channels: 1
Connected Device: 46 Simple DeviceId (sdId): 37, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 47 Simple DeviceId (sdId): 38, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 48 Simple DeviceId (sdId): 39, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 49 Simple DeviceId (sdId): 41, Product: Smart Dimmer, Gen: 2, Channels: 3
Connected Device: 5 Simple DeviceId (sdId): 24, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 50 Simple DeviceId (sdId): 42, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 51 Simple DeviceId (sdId): 47, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 52 Simple DeviceId (sdId): 44, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 53 Simple DeviceId (sdId): 45, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 54 Simple DeviceId (sdId): 46, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 55 Simple DeviceId (sdId): 43, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 56 Simple DeviceId (sdId): 1, Product: Central Hub, Gen: 2, Channels: 1
Connected Device: 57 Simple DeviceId (sdId): 4, Product: Smart Socket, Gen: 2, Channels: 2
Connected Device: 58 Simple DeviceId (sdId): 11, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 59 Simple DeviceId (sdId): 14, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 6 Simple DeviceId (sdId): 25, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 60 Simple DeviceId (sdId): 23, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 61 Simple DeviceId (sdId): 24, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 62 Simple DeviceId (sdId): 25, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 63 Simple DeviceId (sdId): 26, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 64 Simple DeviceId (sdId): 27, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 65 Simple DeviceId (sdId): 28, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 66 Simple DeviceId (sdId): 29, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 67 Simple DeviceId (sdId): 30, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 68 Simple DeviceId (sdId): 31, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 69 Simple DeviceId (sdId): 32, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 7 Simple DeviceId (sdId): 26, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 70 Simple DeviceId (sdId): 33, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 71 Simple DeviceId (sdId): 34, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 72 Simple DeviceId (sdId): 35, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 73 Simple DeviceId (sdId): 36, Product: Energy Monitor, Gen: 1, Channels: 1
Connected Device: 74 Simple DeviceId (sdId): 37, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 75 Simple DeviceId (sdId): 38, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 76 Simple DeviceId (sdId): 39, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 77 Simple DeviceId (sdId): 41, Product: Smart Dimmer, Gen: 2, Channels: 3
Connected Device: 78 Simple DeviceId (sdId): 42, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 79 Simple DeviceId (sdId): 47, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 8 Simple DeviceId (sdId): 27, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 80 Simple DeviceId (sdId): 44, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 81 Simple DeviceId (sdId): 45, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 82 Simple DeviceId (sdId): 46, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 83 Simple DeviceId (sdId): 43, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 84 Simple DeviceId (sdId): 1, Product: Central Hub, Gen: 2, Channels: 1
Connected Device: 85 Simple DeviceId (sdId): 4, Product: Smart Socket, Gen: 2, Channels: 2
Connected Device: 86 Simple DeviceId (sdId): 11, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 87 Simple DeviceId (sdId): 14, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 88 Simple DeviceId (sdId): 23, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 89 Simple DeviceId (sdId): 24, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 9 Simple DeviceId (sdId): 28, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 90 Simple DeviceId (sdId): 25, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 91 Simple DeviceId (sdId): 26, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 92 Simple DeviceId (sdId): 27, Product: Smart Dimmer, Gen: 2, Channels: 2
Connected Device: 93 Simple DeviceId (sdId): 28, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 94 Simple DeviceId (sdId): 29, Product: Smart Dimmer, Gen: 2, Channels: 1
Connected Device: 95 Simple DeviceId (sdId): 30, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 96 Simple DeviceId (sdId): 31, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 97 Simple DeviceId (sdId): 32, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 98 Simple DeviceId (sdId): 33, Product: Plug-In Socket, Gen: 1, Channels: 1
Connected Device: 99 Simple DeviceId (sdId): 34, Product: Plug-In Socket, Gen: 1, Channels: 1
This is very strange indeed.
It’s the same things listed over and over again (sdId)
Firstly check you haven’t got multiple things (as your doing through paperui) - they maybe called different names where I changed the labelling between versions and you have discovered and added.
Secondly:
Stop openhab
Delete:
userdata\tmp
userdata\cache
Mine normally takes about 10 minutes to do this (over 1500 files)
Restart openhab.
Then check the account properties again
I honestly think you have multiple things of the same item.
This is why I do text based things files, the names/labels will always be the same
Also did you delete your items (added through paperui) before you added them as text items?
Also, it only polls for ‘linked channels’. So if you only link the switch channel to items it would ignore the others like identify, protection etc
@xela @pentiumdb do you experience any of these issues above?
I can’t seem to re-produce it, I’ve added the bridge multiple times etc, but I don’t see the same block being called repeatedly
