openhab> bundle:list | grep -i ama
216 x Active x 80 x 3.0.1 x openHAB Add-ons :: Bundles :: Amazon Echo Control Binding
it is now the old one ![]()
I have cleared the cache and rebooted, and the “old” Binding is active.
Yes. After clearing the cache you get the distribution Version.
ok, thanks for the hint. But after update to:
update org.openhab.binding.amazonechocontrol https://janessa.me/esh/org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar
i cannot access the amazonechocontrol
and it says
Thing ‘amazonechocontrol:account:6c171fb8’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
But that snapshot JAR isn’t even available anymore, if I’m not mistaken. Try going to https://janessa.me/esh/org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar with your browser and it says no longer available.
That may explain, why nothing worked after the update.
Are there any suggestions to resolve the issue?
[ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@1921ebf’: GET url ‘https://alexa.amazon.de/api/behaviors/automations?limit=2000’ failed: Not Found
Is there an updated download link? That one doesn’t work anymore ![]()
Weird, extracted the JAR from " 3.1.0~S2222/", placed it into the addons-folder, but still have the same error. ![]()
JFrog try this
did you check which binding is the active one ?
in the openhab karaf console run:
bundle:list | grep -i amazon
Thank you, stopped the old one and activated the 3.1.0 one and now it works.
I downloaded the jar file to the addons folder.
How do I activate it?
after restart of OH service the binding should be visible in the karaf console and you should see if it is activated.
I run the command
And got empty answer…
You are on OH3 ? The owner of the jar file is user openhab and group openhab ?
This is OH3.
The output of ls -l of addons folder:
-rw-rw-r-- 1 openhabian openhab 466281 Apr 1 08:14 org.openhab.binding.amazonechocontrol-3.1.0-SNAPSHOT.jar
Do I need to change the owner from openhabian to openhab?
Does anyone have a current link for the updated addon? The two links mentioned in this thread no longer work.
browse through JFrog and select the directory related to the version you are looking for.
The links no longer work.
Is there another way for a normal user to get the file?
I was still using 2.5.10-1
Thanks!
You can try to download the 2.5.12 addons kar file https://repo1.maven.org/maven2/org/openhab/distro/openhab-addons/2.5.12/openhab-addons-2.5.12.kar and extract the addon ( jar file ) from this kar file.
I do not know if 2.5.12 addon is compatible with your 2.5.10-1 instance.
