Platform information:
- Hardware: _CPU i3/RAM 8 g/storage 1tb
- OS: Debian 9
- Java Runtime Environment: _openjdk 1.8.0.181
- openHAB version: latest stable
Issue of the topic: I have a Linear HUSBZB-1, it worked in OpenHAB running in Windows but I can’t get it to work in debian
Detailed explanation: I had openHAB running on a Windows 8.1 desktop. Purchased and installed HUSBZ-1 with windows driver. Installed binding in paperUI, discovery found both controllers. com3 and com4. Next discovery found two motion sensors iris and smartthings. I was so delighted, I purchased a dedicated pc to run openHAB on. I have linux experience, mostly CentOS, fedora, RedHat but have run Ubuntu and installed Debian. Up and running, installed openHAB via openhabian docs.
I’m almost certain this is something I’m just not getting in either the operating system configuration or my java configuration because I’m rusty with linux. -
Things I have tried:
- Install Chris’s great binding in paperUI
- add openhab user to tty and dialup
- edit /etc/default/openhab2 to add EXTRA_JAVA_OPTS=“-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyUSB1”
- run lsusb
- run dmesg | grep tty
- restart system & openHAB
Errors and logs:
- in paperUI things
Status: OFFLINE Failed to initialize ZigBee transport layer
Status: OFFLINE - COMMUNICATION_ERROR Serial Error: Port /dev/ttyUSB0 does not exist
- chunk of log
2018-10-21 14:57:10.251 [ERROR] [ding.zigbee.handler.ZigBeeSerialPort] - Serial Error: Port /dev/ttyUSB1 does not exist.
2018-10-21 14:57:10.252 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unable to open Ember serial port
2018-10-21 14:57:22.305 [ERROR] [ding.zigbee.handler.ZigBeeSerialPort] - Serial Error: Port /dev/ttyUSB1 does not exist.
2018-10-21 14:57:22.306 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unable to open Ember serial port
2018-10-21 14:57:45.932 [ERROR] [ding.zigbee.handler.ZigBeeSerialPort] - Serial Error: Port /dev/ttyUSB1 does not exist.
2018-10-21 14:57:45.932 [ERROR] [zigbee.dongle.ember.ZigBeeDongleEzsp] - Unable to open Ember serial port
2018-10-21 14:58:57.968 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyUSB0'
thanks for any help
