My Linux time differs from my Openhab time with one hour, after installing Openhabian 1.9b a week ago. What to do about that?
- Platform information:
- OpenHabian 1.9b (32bits)
- Hardware: Raspberry PI 3b/1GB RAM/ 16 GB storage
- OS: Raspian 12 (Bookworm)
- Java Runtime Environment: openjdk version “17.0.11” 2024-04-16
- openHAB version: 4.1.3
Linux time and timezone:
$ timedatectl
Local time: Tue 2024-07-09 17:48:52 CEST
Universal time: Tue 2024-07-09 15:48:52 UTC
RTC time: n/a
Time zone: Europe/Berlin (CEST, +0200)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
But whether I use the default situation (i.e. setting no timezone in Openhab, OH should take over the Linux timezone), or even when I manually configure to Athens instead of Berlin, the logfile and time in Openhab remains on +1 instead of +2 where it should be now.
Top of the log when restarted at 17:35:
2024-07-09 16:35:51.501 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.1.3 (build Release Build)
2024-07-09 16:35:52.567 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Athens'.
2024-07-09 16:35:52.590 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'nl_NL'.
202
Also dates in items (like LastUpdate values) are one hour off.
By the way, it is a remote system (no access to the ui), so I changed the timezone using openhab-cli:
openhab> config:edit (service.pid=org.openhab.i18n)
openhab> config:property-set timezone Europe/Athens
openhab> config:update
openhab>
I did this before and this used to work.
- What to do to fix this?
- What to check?
I’d appreciate any help!
