LIRC binding missing
I feel like I a missing something obvious, but I’ve got openHAB installed and I was able to find some of the key bindings I was looking for, but not LIRC. On the list, it indicates it’s since 2.x and install auto,which I thought meant it should be in the binding list without having to do something to add it manually, but it goes from LIFX to Lutron.
Any help is appreciated.
Hello
I am not sure but when the binding is not in the paper-ui list to install it should be integrated by default ?!
Some Bindings are installed by default so you dont have to install it … maybe this is one of them ..
Just follow the Binding description and try it.
http://docs.openhab.org/addons/bindings/lirc/readme.html
Lirc binding is present in the SNAPSHOT builds: https://community.openhab.org/t/major-esh-upgrade-in-2-2-0-snapshot/31884
You, probably, run openhab 2.1 STABLE release…
Thanks for the updates, not sure why I didn’t see these posts earlier when I searched, but it looks like this is only included in the v2.2 releases, grabbed the latest snapshot thanks to OH2 LIRC binding?
and then updated a system.properties issue based on Initialization problem with openHAB 2.2 Build 1017 on Windows 10 - #27 by jkarsten
