vzorglub
(Vincent Regaud)
1
List of Units
List of the unit available with the UoM (Unit of Measurement) types
Imperial:
| Type |
Unit |
Symbol |
| Pressure |
Inch of Mercury |
inHg |
| Temperature |
Fahrenheit |
°F |
| Speed |
Miles per Hour |
mph |
| Length |
Inch |
in |
| Length |
Foot |
ft |
| Length |
Yard |
yd |
| Length |
Chain |
ch |
| Length |
Furlong |
fur |
| Length |
Mile |
mi |
| Length |
League |
lea |
SI:
| Type |
Unit |
Symbol |
| Acceleration |
Metre per square Second |
m/s² |
| Acceleration |
Standard Gravity |
ɡₙ |
| AmountOfSubstance |
Mole |
mol |
| AmountOfSubstance |
Deutscher Härtegrad |
°dH |
| Angle |
Radian |
rad |
| Angle |
Degree |
| Angle |
Minute Angle |
| Angle |
Second Angle |
| Area |
Square Metre |
m² |
| ArealDensity |
Dobson Unit |
DU |
| CatalyticActivity |
Katal |
kat |
| DataAmount |
Bit |
bit |
| DataAmount |
Megabit |
Mbit |
| DataAmount |
Kilobit |
kbit |
| DataAmount |
Gigabit |
Gbit |
| DataAmount |
Terabit |
Tbit |
| DataAmount |
Byte |
B |
| DataAmount |
Octet |
o |
| DataAmount |
Kibioctet |
Kio |
| DataAmount |
Mebioctet |
Mio |
| DataAmount |
Gibioctet |
Gio |
| DataTransferRate |
Bit per Second |
bit/s |
| DataTransferRate |
Kilobit per Second |
kbit/s |
| DataTransferRate |
Megabit per Second |
Mbit/s |
| DataTransferRate |
Gigabit per Second |
Gbit/s |
| DataTransferRate |
Terabit per Second |
Tbit/s |
| Density |
Microgram per cubic Metre |
µg/m³ |
| Density |
Kilogram per cubic Metre |
kg/m³ |
| Dimensionless |
Percent |
| Dimensionless |
Parts per Million |
ppm |
| Dimensionless |
Decibel |
dB |
| ElectricPotential |
Volt |
V |
| ElectricCapacitance |
Farad |
F |
| ElectricCharge |
Coulomb |
C |
| ElectricConductance |
Siemens |
S |
| ElectricCurrent |
Ampere |
A |
| ElectricInductance |
Henry |
H |
| ElectricResistance |
Ohm |
Ω |
| Energy |
Joule |
J |
| Energy |
Watt Second |
Ws |
| Energy |
Watt Hour |
Wh |
| Energy |
Kilowatt Hour |
kWh |
| Energy |
Megawatt Hour |
MWh |
| Energy |
Kilovar Hour |
kvarh |
| Force |
Newton |
N |
| Frequency |
Hertz |
Hz |
| Illuminance |
Lux |
lx |
| Intensity |
Irradiance |
W/m² |
| Intensity |
Microwatt per square Centimeter |
µW/cm² |
| Length |
Metre |
m |
| Length |
Kilometre |
km |
| LuminousFlux |
Lumen |
lm |
| LuminousIntensity |
Candela |
cd |
| MagneticFlux |
Weber |
Wb |
| MagneticFluxDensity |
Tesla |
T |
| Mass |
Kilogram |
kg |
| Mass |
Gram |
g |
| Power |
Watt |
W |
| Power |
Kilovar |
kvar |
| Power |
Decibel-Milliwatts |
dBm |
| Pressure |
Pascal |
Pa |
| Pressure |
Hectopascal |
hPa |
| Pressure |
Millimetre of Mercury |
mmHg |
| Pressure |
Bar |
bar |
| Pressure |
Millibar |
mbar |
| Radioactivity |
Becquerel |
Bq |
| RadiationDoseAbsorbed |
Gray |
Gy |
| RadiationDoseEffective |
Sievert |
Sv |
| SolidAngle |
Steradian |
sr |
| Speed |
Metre per Second |
m/s |
| Speed |
Millimetre per Hour |
mm/h |
| Speed |
Kilometre per Hour |
km/h |
| Speed |
Knot |
kn |
| Temperature |
Kelvin |
K |
| Temperature |
Celsius |
°C |
| Time |
Second |
s |
| Time |
Minute |
min |
| Time |
Hour |
h |
| Time |
Day |
d |
| Time |
Week |
week |
| Time |
Year |
year |
| Volume |
Litre |
l |
| Volume |
Cubic metre |
m³ |
| VolumetricFlowRate |
Litre per Minute |
l/min |
Cubic Metre per Second |
m³/s |
Cubic Metre per Minute |
m³/min |
Cubic Metre per Hour |
m³/h |
Cubic Metre per Day |
m³/d |
Prefixes:
| Name |
Symbol |
Value |
| Yotta |
Y |
10²⁴ |
| Zetta |
Z |
10²¹ |
| Exa |
E |
10¹⁸ |
| Peta |
P |
10¹⁵ |
| Tera |
T |
10¹² |
| Giga |
G |
10⁹ |
| Mega |
M |
10⁶ |
| Kilo |
k |
10³ |
| Hecto |
h |
10² |
| Deca |
da |
10 |
| Deci |
d |
10⁻¹ |
| Centi |
c |
10⁻² |
| Milli |
m |
10⁻³ |
| Micro |
µ |
10⁻⁶ |
| Nano |
n |
10⁻⁹ |
| Pico |
p |
10⁻¹² |
| Femto |
f |
10⁻¹⁵ |
| Atto |
a |
10⁻¹⁸ |
| Zepto |
z |
10⁻²¹ |
| Yocto |
y |
10⁻²⁴ |
To use the prefixes simply add the prefix to the unit symbol (Above).
Examples:
- milliAmpere - mA
- centiMetre - cm
- kiloWatt - kW
Many thanks for this overview!
One question:
Could this be ElectricResistance?
Not sure about it.
Maybe this would be good as a wiki post, which can be improved/adapted by others as well.
I’d say it’s a great candidate for a section in an official documentation
Here you can modify that page - Sign in to GitHub · GitHub
Melkor
(Marco Salinardi)
6
This is not working, correct one is
ElectricPotential
And Power should be comprensive of VA for apparent power and VAR for reactive power. W is only for the actual active Power
rossko57
(Rossko57)
7
Late update … it seems the year Time unit is year not y
