since yesterday evening I am observing following behavior on myopenhab.org accounts:
I tried to log in with my admin account (as admin account I mean the first account you create when signing up on myopenhab.org). The login did not work, even it did last week (I think it was Thursday). I used the functionality for sending mail to reset the password and supplied the correct email address. An email never arrived (I checked as well spam/junk folders on my mail box).
The very same happens for an user account with admin grant.
A “normal” user account (not admin, no admin grant) works without any problems.
A connected IFTTT account using the myopenhab admin account is working fine as well.
So I guess there is something wrong with my “admin” accounts.
Did someone else experienced this behavior recently too?
since a couple of Days i have the same issue.
I can’t login with my Account and the password reset function do nothing. I also get a HTTP-401 error message when i try to use the android app over the myopenhab remote server. I think it has something to do with the last myopenhab.org update.
same here - can’t log in. I was able to request a “lost password email” today - but after changing the password , no luck. Still can not log in. What is going on?
I’m having the same problem… Can’t login with my credentials. Resetting the password seems to work but even then i can’t login. New Account creation doesn’t work either because my uuid is already in use…
Maybe it’s my gmail address?!? harry+myopenhab@gmail.com
Yes but in my email adress there is no “+”… Does anyone have a clue what is causing this and how to fix it? Because the location where the openhab is running does not yet have heating in it and it is freezing cold to work in that building
I do not know what’s going on but I can not connect. 24 hours of waiting have passed. Message received: ”Unknown user or incorrect password.” But they are entered correctly.
It is frustrating! If I want to make another account with another email address I can not because it tells me that the UUID code has been used by someone else (that is me with the current e-mail address).
Yesterday I tried 3 times to change my password, but it seems this is not a solution.
Do you have any idea what’s going on and how can you solve the problem? Is there any length-of-password restriction?
If you need another UUID then uninstall and reinstall the openhab cloud binding to generate a new UUID that you can use. The UUID is found at /var/lib/openhab2/uuid and I would verify the number before uninstalling and check that it’s changed after installing.
