If I am understanding you correctly, you have the two wires in the switch box, like they ran a single run of (dual conductor) romex down from where the power is just for the switch. So if the switch is not on, then no power at all is going up to the fan/light, correct? And when you turn it on they both come on?
So assuming that, you are going to have to do whatever control you wish to do either up at the fan, or in the attic. And then just wire the switch straight through and put a blank cover plate, or as you say “the Post-It method” and leave the switch on all the time.
You could add local control back to your wired-through switch by sticking some button(s) back on the cover plate. I know these come in 433mhz because I just ordered some from AliExpress not too long ago (I have this same problem in one room). They come in white and black (and other colors) and 1-3 “gang” options. I cannot vouch for how well they work because I haven’t received them yet, but they are cheap (only few dollars each). I think some other systems also offer this sort of stick on button functionality, but I wanted to start experimenting with 433mhz stuff because it is so cheap. Another option is some of the big box options also come with remotes. Picking these signals up to update openHAB though is another story.
Next issues: do you want to control the light mainly? You seem perhaps like you could live without the fan. Maybe you mean just leave the fan on all the time? If that is the case, as you say a “smart bulb” might be the best solution. Generally speaking, I don’t like them either, but they do have their place, and your situation is it.
Next, do you want to control the speed of the fan or just on/off? I am assuming you know that being able to control fan speed is a little more complicated due to reasons I won’t get into unless you are interested. Hence the recommended device, or something similar.
Once you decide how and what you want to control exactly, then you can decide on what “transport layer” for lack of a better term. The fan control devices I have seen have been 433mhz. Smart bulbs come for pretty much every system I think. Then it is a question of what sorts of gateways and devices you may have already, and/or what direction you want to move in the future. Luckily, with openHAB as your controller, you have a lot of options to tie dissimilar systems together.
But the bottom line is, there is no way to control everything (separately) from the switch. Only both on, or both off. So really the question becomes: what tradeoff do you want?
- Less control for less installation hassle (switch everything on/off together at switch, control fan speed manually with pull chain)
- Full control of everything separately and remotely, for slightly more installation hassle (climbing through attic, etc.)
Unless I have misunderstood something?
EDIT: Also those fan controls are not really that big, and they are made not to go in the box above but wedged inside the fan bracket bolted to the ceiling (the one that holds up the main weight of the fan). That is why they are sort of long and skinny. Usually there will be some cosmetic cover at the ceiling, pull that down and you will see where the wires all connect, that is where you install the fan contol box. Pretty easy actually, Or maybe in the bottom part where the pull chain switch is located (depending on model; also it’s been a while since I did one).
